Janis1279
287 -
Everything posted by Janis1279
Controlling Virtual DJ - New MIDIBOX - Help & Input Needed
Janis1279 replied to jbaldwinroberts's topic in Design Concepts
16 LEDrings : http://www.ucapps.de/mbhp/mbhp_doutx4_ledrings.pdf -
ok, im stuck. What is the next step for my midibox64 build?
Janis1279 replied to kingnerk's topic in MIDIbox HUIs
You can made your own MB64 configuration in the setup_midibox64.asm file (open it in the Word Pad , easy to edit) . Regards, Janis -
Building bigger Jog wheels - check my design!
Janis1279 replied to kingnerk's topic in Parts Questions
I could be wrong, but for another MBHP projects may be similar data velocities from the MIDIO128 design page : "The software captures all 128 inputs within a period of 1 mS. If the status of an input pin has been changed, the program searches for the predefined MIDI event in a big table and sends it out" -
for right soft choice : http://www.sprut.de/electronic/soft/index.htm
Options for driving common anode LED digits?
Janis1279 replied to WickedBlade's topic in Design Concepts
1. 74HC595 + ULN2803, 2. TPIC6B595 from: http://www.edaboard.com/topic293467.html -
B40C800 0,8A 100V from datasheet. W04 to be better and can be used instead of B40C800.
midibox_lc_v1_6c\src\lc_io_table.inc
:D Hi, Wilba, Chips arrived . Thank you very much ! ! ! Regards, Janis
I think, you mean a double pole power switch. It's enough for switching on and off two separate secondary voltages as 5VDC and 9VAC simultaneously. Regards , Janis
Received unexpected Upload Request[Solved]
Janis1279 replied to AC's topic in Testing/Troubleshooting
for the audio on the PC: - In the Mios Studio > Options > Midi Device Routing > You need connect left side Midi Device-Readable : Mios Studio Out Port with Midi Device-Writable : ..... ( in my computer it's Microsoft GS Wavetable SW Synth ) - For MB 64e is possible up to 8 pots in unmuxed mode(J5), editing in : setup_midibox16e.asm file -
Is a plus sign is near pin 2 ? Electrolytic capacitor value partly depends on which : external or internal 5 volts PSU will be used.
From the DOUT Module additional info section : http://www.ucapps.de/mbhp/mbhp_doutx1_reed_relays.pdf
If you now using yours 5V psu with J2 its quite so ,redraw a schem without the power supply stuff at the bottom right on this schematic: http://www.ucapps.de/mbhp/mbhp_core_v3.pdf on a new maded pcb.
In the midibox tutorials may be you read about a special feature which will be assigned to the buttons : Toggle value - Send learned value with the first keypress, send zero value with the second keypress.
Help me identify LCD + troubleshooting.
Janis1279 replied to questionable's topic in Testing/Troubleshooting
Hi. Mios suports your's Epson SED1278 chip LCD display. You need compare are you soldering wires as in : http://www.ucapps.de/mbhp/mbhp_lcd.pdf In your case LCD pins are grouped in the odd and even columns, but pin meanings are the same as in a one row, I think. Regards , Janis -
Yes, it's right. Only , when mirrored text, pots connections looks like reversed. Redrawing some lines for better understanding. Regards, Janis
If you returned to the scheme MBHP_CORE_V3 to the connector J15, will see pins in the two columns. Right sizes first 2 upside pins are marked : B+ , B-. These pins supply voltage "+" and "-" polarity ( or need suplly voltage ) to the yours LCD backlight pins. I have simpler this part of the scheme with only one 10E resistor , but its not so important. Regards, Janis
Why 12volts to the LCD module ? If you see scheme of MBHP Core , you see only +5V and gnd connections, right? Your comments about more than 1 amp of the LCD backlight current sounds : all is not so good. You need against checked every connection to the LCD module . Regards, Janis
I could be wrong. You can use LTC out, 2nd Midi out from MBHP_LTC_V1a sch. and also add in a similar way 3rd Midi out. I think you may connect additional 74HC00 i-c to J1 MI , MO pins as in scheme are connected IC3 , R7, R8, J5 , socket components for getting needed out. Hope, you will find solution ! Regards, Janis
hey for members of another forum only, many as one year old info : http://launch.groups.yahoo.com/group/midiguitar/message/27224?l=1 but for free find only Microswitch Charts for MG-500/510 : http://jpsongs.com/troubadortech/casmgtr.htm Regards, Janis
As I understand from Pic Burner manual and : http://www.sprut.de/electronic/soft/pbrenner.htm I say : YES Regards, Janis
crimp sockets made in copper and soldering well. I made in some steps : - at first cuting and soldering ribbon cable leads,but very short lenght! When heating , insulation decreases fast, - puting on working place all needed crimp sockets together in one peace, fixing it, - then acurately soldering one by one, - after, working with a pair of flat pliers. Regards, Janis
Similar size crimp sockets I made with a soldering iron and with a pair of flat (~5mm width), long pliers. It's simply, only sometimes, need more patience. Result is fine , too. Good luck, Janis
