127 -
Everything posted by nuke
ouch... 10v directly connected to pic-pins, never a good idea...should be limited in some way to avoid burning your pic...
just to report... i´ve found another bug...using "pitch" as parameterlayer, and then changing values, leads to "grabage" values like it did before with the CC layers... confirm anyone? smi;)e
huh? as long as i know, you can delay midiclocks in ableton in both directions negative/positive...is this not working for your needs? sometimes i needed to push them real hard like 50 ms or so to...at least they stay in sync.
@midilab why would you do that ? i had latency issues when using midiseq with cubase, but in the opposite direction... everything was too early... to manage these "audio delays" i had to implement the midibox as an "instrument" but with audio not connected. when then routing the "not connected" audiochannel to the same bus as my vsti, the delay is gone... maybe you could also try "custom grooves", setting them to a negative value... like tk said, this is only midi ticks not ms/us. sm:)e , n:k
that´s good, so it won´t get lost... :ahappy: greetz...nik
heyho... i found some spare time to convert the scales in SeqV4 into graphics... :rolleyes: maybe someone will find it usefull... i do ;) scalesMidiboxSeqv4.pdf feel free to report errors. sm:)e , nik
yep...thats what i meant... i just noticed a "rolling" with overlapping notes and echos, when using heavy shuffles with 16th echoes... ok...won´t work :ermm: ...is it because of different/mixed timesignatures that it can´t be snapped into groove grids? ...btw. i think i found another bug: i get a crash with "!! HARD FAULT !! at PC=0x0802fc3e , when trying to save track-presets. i can load my previous presets just fine,i also can save and load pattern and sessions without problems... only saving presets gives me that crash, have to switch off and on then... :fear: greets, nik
hey... i realized that echo fx on a track doesn´t react to grooves anymore...wasn´t that working before? greets, nik ...mm... back on v47 (just for testing) now i´m pretty unsure, if it ever was working with grooves!? :blink: maybe i never noticed it, since never used it so excessive like i did yesterday... hehe
hallo... also ich vermute ja , dass du einen wichtigen schritt vergessen hast :rolleyes: nachdem du den bootloader in den pic gebrannt hast (bootloader_v1_2b_pic18f452.hex), solltest du hinterher noch mios aufspielen, bevor du irgendeine applikation hinterher schickst. das ist das hex im "midi" ordner (mios_v1_9g_pic18f452.hex). das spielst du mit mios studio ein, danach erst ebenfalls mit mios-studio (gleiche prozedur) kommt deine applikation. die device id brauchst du solange nicht ändern, bevor du nicht vorhast mehrere pics in kette zu betreiben, erst dann brauch jeder pic seine eigene id. kannst diese also ruhig auf standard 00 lassen. wennde die jetzt schon geändert hast , is auch latte, mach einfach mit mios 1.9g weiter, danach die app nochmal hinterher. falls es immer noch nich gehen sollte, würd ich zuerst nen anderen optokoppler 6n138 nehmen, hatte mal n paar die zwar irgendwie liefen, aber immer midi-time-out produzierten... da kann schonmal nen faules ei dabei sein. :ahappy: gruss, nik
hallo andreas...und willkommen meinerseits :ahappy: ich geh mal davon aus, dass du nicht versuchst, ne mios8 applikation auf den lpc17 zu laden, der ist nämlich mit mios32 zu "bestücken"... also versucht du gerade nen pic zu bespielen...evtl nen pic 18F4620 od. 18F452?... der bootloader ist drauf? das ist das hex-file im ordner "burner" wenn du dir das mios_v1_9g.zip gezogen hast. nach dem der bootloader drauf ist (über nen pic-brenner deiner wahl), musst du das mios einspielen, am besten über mios-studio. aber das hast du ja bereits in verwendung, oder? dazu darfst du, meines wissens her, nur midi-in 1 und midi-out 1 benutzen (eigentlich hat das core-board auch nur 1 rein und 1 raus)...andernfalls gibts keine "bootloader"-kommunikation. evtl. versuchst du´s mal so: core-modul bleibt ausgeschaltet...midi-in in den 1.port, midi-out ebenfalls in den 1. port ...dann hexfile laden über "browse", "start" drücken, danach erst das core-modul anschalten, dann müsste der bootloader ne anfrage senden und automatisch den upload starten...wenn mios drauf ist, kannst du via "browse" deine applikation hinterher schicken. wenn du allerdings das LPC17 meinst, solltest du mios32 stattdessen benutzen....momentan gibt es midibox_seq4, midibox_seq4L und midiox_128_v3 für den LPC17 als applikation...alles andere lauft (noch) nur auf dem PIC-board... hau rein, und sach bescheid wie´s gelaufen ist... gruss, nik
ok ...here´s another one... :rolleyes: go in "songmode" and instead of loading Pattern "A1" on Position A1, you choose "Mutes" with the "Actn."-encoder before loading your pattern. so Pos. A2 will then be your pattern "A1"...then choose "mutes" again on Pos. A3 and on Pos. A4 your same pattern again (A1)....Pos. A5 is a jump to pos. A1...that´s how you can automate mutes in song-mode, but dealing still with the same pattern...so in songmode you can also put in tempochanges and mixermaps... :sorcerer: sm;)e , nik
mmm...it seems that you´re messing up things... :laugh: let me make it a bit clearer.... the 16 tracks you get when starting the seq_v4 are not 16 patterns nor is this a "whole" pattern... these 16 tracks are divided into 4 groups, each group consists of 4 tracks which is then called a pattern. so when you save a "pattern" A1 = (group1->track 1-4) and load another pattern A2, your tracks A1(1-4) are now replaced by A2(1-4)...so is group2->track 5-8...group3->track 9-12 and so on...so by loading a pattern you will replace 4 tracks at a time on your chosen group. if you , what i think you did, want to change back and forth between track1 to track4, this can be done by muting them, best with synced mute/unmutes enabled ((util./opt.)...but for now you can also save your "patterns" as A1,A2,A3,A4 and copy each wanted track to track1 and clear the other 2-4 after. before that, you should backup your pattern to an unused placeholder like B1 or so...so you can always return to where you´ve started, in case something goes wrong... :cool:
ah...now i got it...hehe óf course you can force the pattern playing to end...go in utilities-option (Opt.)....there u can define if it should sync the patternchange to bars or not...with measure u define how many bars a pattern should play before it jumps to the next. even with a 16steps-pattern, you can force it to play 4 times before changing by setting measure to 64 steps. in pattern-mode you can then switch pattern in sync with the gp-buttons. :cool:
great...works again flawless....good job! thanks a lot... :thumbsup:
hi there, and... ....what do you exactly mean with basic pattern? a pattern can be up to 256 steps long, that´s 16 bars...if you need more, you could use the "song-mode" which you have to switch to "song-mode", ´cause default is "phrase-mode", which is not what you are after... you can save a pattern then, let´s say you´ve saved pattern a1, a2, a3...in songmode you can then chain them...choose a song , a position (maybe a1-a4 <-these are not pattern but song positions), set youre pattern on each position... example: Pos. A1 - Pattern A2, Pos. A2 - Pattern A3, Pos. A3 - Pattern A2, Pos. A4 - Pattern A1, Pos. A5 - Jump Pos. A1 ...then youve created a loop from pos. a1 to a4... what´s importand is , you must be in "song-mode" not "phrase-mode", don´t forget! :cool: sm;)e , nik ps.: more here in the manual under "song-screen".
i updated my stm32 with bootloader 1.007. i noticed an issue when uploading "older" apps like "midibox_seq_v4_047", after re-powering the midiseq , windows has an "unknown device" with a quotationmark in devicemanager. then i can only update mbseq_v4 via midi and no usb midiports are available. with "midibox_seq_v4_051" it´s running fine, but i like to use v47 for now, cause of no issues with CCevents with that version. is there something to "set" or enable-disable after uploading bootloader 1.007 to make it backwards compatible? sm;)e ,nik
i noticed some strange behaviour when using CC´s as enventtype...the values are somehow jumping and affecting other steps too. but this happens to version v50 also, dunno about versions before, haven´t tested yet. looking forward for the new humanize features ;) ok tested v51, v50, v49(the crashing version) all no good with CC events v48 i don´t have , so couldn´t test this v47 works flawless with CC´s ...maybe that helps a bit ;)
hey , i have another feature request... maybe for future updates, but only if it makes sense and fun... ;) in the fx section , theres the humanizer which now can "randomize" notes, vel/cc and length...but since the whole right screen is empty, wouldn´t it be cool to have the trigger layer "humanized" also?...maybe with a percentage-value like probability... so it would be possible to have some nice variation with accent, slide , rolls, random value etc... each with it´s own amount...?! ...just another latenight-idea 8) sm:le, nik
All the possible reasons for LCD showing only blocks/bars
nuke replied to Tim B's topic in Testing/Troubleshooting
can also be a dead lcd...i remember once feeding the wrong pwr-pins with my psu, resulting in a dead pic and a dead lcd, showing only blocks...maybe you´ll need another one to test... -
...just make an own package in library and move the led off the center to the right, then you can use the angle tool to rotate them around that centerpoint... 360/ amount of leds = angle :ahappy:
ja...hast recht...ich vergaß... :logik:;)
hau doch den "toggle-mode" raus...einfach in MBSEQ_HW.V4 auf null setzen, dann wirkt "all" nur solange du´s gedrückt hältst. "all" ändert man sowieso nur mit einem encoder-dreh, somit hat man die andere hand frei zum taste halten. ;) gruss, nik in MBSEQ_HW.V4: BUTTON_BEH_ALL 0
the anode of the led should be connected to +5V, while the cathode is connected to 470 Ohm...the 470 Ohm resistor goes to ground. so the led isnt connected directly to ground, only via the resistor. check the schems again.
hehe...no, don´t stick them in the wrong direction, but maybe they are reversed... i´m just trying to minimise the possiblities of false operations... ;) so when u got 5v after 78L05, the green powerled must be lit, since its only connected to 5v-rail and gnd via a resistor. mmm...btw , what do you mean with "yellow" led...from the schematics? or the pics on ucapps?... on the pictures the lit "green" powerled looks a bit yellow...
the "green" power led has to be lit when psu is connected...do u get +5 after 78L05 ? led´s reversed?
