grizz
Programmer-
201 -
Everything posted by grizz
We're at 70 chipset orders... Order NOW!
MBHP_ETH, MBHP_SDCARD, SSM2044, SSM2164 PCB Bulk Order
grizz replied to seppoman's topic in Bulk Orders
Cool, thanks for the info... I haven't ordered from futurlec before so I will check them out. I'm not horribly rushed, since I haven't gotten my pcb's yet, and I want to avoid placing as many orders as I did while building my MB808... I kept realizing I needed 1 or 2 more things... My own fault. Plus I still have to silkscreen or get a vinyl for the MB808... I almost wished I had just forked out the money to have FPE engrave it... I also cannot seem to figure out why my AOUT_NG will work with my MB6582, but will not budge with my MBSEQ... all loose ends I should probably fix before beginning a new project... cheers, grizz -
Thanks for the response Altitude... Here is what I have completed as far as sourcing for the VCF... There is a column for Mouser and one for Newark... Fuzzylizard gave me his order invoice from his VCF mouser order which helped a bunch... I'd be interested in what you (or anyone else for that matter) thinks... I didn't bother sourcing the resistors yet through Newark... I can't imagine that taking very long... Also, I hope it is not improper of me to use this thread for this... if so sorry! Cheers, A Parts List SSM2044 VCF Part Value Reichelt No. Newark Part # comments Mouser part # Comments C1,C2 220 uF RAD 220/25 38M3184 140-XRL25V220-RC C3,C4 10uF RAD 105 10/63 70K9680 140-XRL25V10-RC C5-C12 100nF Z5U-2,5 100N 85K9474 140-50U9-104Z-RC C13,C14 100pF NPO-2,5 100P 46P6382 581-SR151A101JAR C15-C18 470nF Z5U-5 470N 97K4543 581-SR205E474MAR C19-C24 10nF STYROFLEX 10N 97K0250 80-C331C103J1G5CA C25,C26 820pF STYROFLEX 820P 97K0287 81-RPE5C1H821J2P1A03 D1 1N4148 1N 4148 33C2680 78-1N4148 IC1,IC2 SSM2044 IC3 LM13700 LM 13700 DIL 41K3507 backordered 513-NJM13700D IC4 TL072P TL 072 DIP 76C6659 backordered / min order of 400 595-TL072CP K1 G6K-2P G6K-2P 12V 36K1951 653-G6K-2P-DC5 P1,P2 10k 64W-10K 03F6588 652-3296W-1-103LF P3,P4 500 64W-500 03F6584 652-3296W-1-501LF R1-R6 220 METALL 220 271-220-RC R7-R13 1k METALL 1,00K 271-1K-RC R14,R15 100 METALL 100 271-100-RC R16,R17 10k METALL 10,0K 271-10K-RC R18,R19 24k METALL 24,0K 271-24K-RC R20,R21,R24-R27 47k METALL 47,0K 271-47K-RC R22,R23 27k METALL 27,0K 271-27K-RC R28,R29 100k METALL 100K 271-100K-RC T1 BC547 BC 547C 58K0094 512-BC547ABU PS... sorry about the jumbled nature.. It looks different in the preview window... oh well -
Is there anyone in Germany that would be willing to let me piggyback on their Reichelt VCA and VCF orders, and then ship me my parts? There are some parts that are either back ordered, or seemingly unavailable (styroflex caps) from Mouser, digikey etc. PM me if that sounds doable. I'd be thankful! Cheers, Grizz -
I second that bump... even though the "bump" seems to be frowned upon.. We are at 63 orders, so we're getting close. grizz
Thanks nILS! I was hoping for something I could just build on breadboard!!!! Cheers, grizz
I hadn't seen that page... I must of overlooked it. I'll look into getting a JTAG wiggler here in the States. Thanks for the help. grizz
We did some more troubleshooting on this Core32, and we found some new things out. First off, all the voltage checks are fine, and we replaced the crystal... which didn't do the trick. Next we stuffed J27, and what we got was a solid green LED. This leads me to think that the main Core32 software has crashed. My understanding is that we need a JTAG or a CAN interface, both of which I have very little knowledge of. I am going to do some research when I get some free time, but if anyone has any suggestions I'm all eyes. Also, if we do indeed need to burn the Chip again and someone has the proper hardware I'd be very thankful if I could send the Core32 off to you. Cheers, Grizz
Hey all, I'm just checking in just in case my question got lost in the busy shuffle of things since it took me awhile to respond with my voltage test results... basically a veiled *BUMP*...;-) cheers, grizz
So I ended up using 99% Isopropyl alcohol and distilled water, and it worked beautifully!! Thanks for the tips. Cheers, grizz
Thanks for the replies. I use 60/40 rosin core solder... I'll do a little more in depth research to find the right cleaner... cheers, grizz
Hey, I am gearing up to clean the flux off my MB-808 board... I'm nervous! Can anyone tell me that this product will or will NOT work? Mouser # 577-1631-5S I'm pretty sure its fine from looking at the datasheet, but I just want to have a second, third, etc. set of eyes verify that it won't destroy anything.... Cheers, Grizz
We're now at 48... still a ways to go... *BUMP*
Hi again, So we installed the external psu, and no luck. The green light no longer even blinks three times. J23 was stuffed and that was causing the LED to not blink. So what happens when powered up is that the LED blinks 3 times slowly and then turns off. It seems like it could be the crystal or the 33 caps? I tested the voltage at J2, and get 5.04 volts. SO it is not a power problem... another edit: So when we connect the midi in and out of the core32 to my computer, power it up, and query when the LED is blinking we get: Operating Systen: MIOS32 Board: MBHP_CORE_STM32 Core Family: STM32F10x Chip ID: 0x00000000 Serial: #35FFFFFF5836393645612543 Flash Memory Size: 524288 bytes RAM Size: 65536 bytes MIOS32 Bootloader © 2009 T. Klose After the LED has blinked 3 times and turned off, then there is no response when running a Query. cheers, Grizz BTW: This is a second core32, not the first one that we are troubleshooting the AOUT_NG with.
I do own one... Results: A)J19:SO: When powering up: 3.89, and after the SD card is found .10 J19:SC: When powering up:4.55, and after the SD card is found .11 J19:RC1: 3.93 steady. J19:RC2: 3.93 steady. B)J19:SO: 3.89 J19:SC: 4.55 J19:RC1: 3.93 J19:RC2: 3.93 Cheers, Grizz
I used another SD card, and here are the steps I took: I have two SD adapters and two micro SD cards at my disposal, both of which are soldered correctly and worked prior to upgraded from Beta20 to Beta21. Tests: 1. I removed the microSD card (SD1) from the adapter attached to J16 and inserted the second (SD2) microSD card. Result: Same error 2. I removed the adapter from J16 put the other adapter in place and inserted SD1 into it. Result: Same error 3. I inserted SD2 into the adapter. Result: It successfully created a new session. 4. I switched adapters again, and this time put SD1 in place (this is the original configuration that was giving me problems) Result: It successfully created a new session. So it seems to be intermittent. Its possible that the IDC connector got jingled around moving it between my house, practice space, and shows... But I would think that it wouldn't switch between already created sessions if that was the case. I'll mess around with it a bit more, but I just got a new resistor network for the AOUT_NG jumper, and I want to try that out. Cheers, grizz
Okay here is the error that I get. It flashed really quick so it took some time... SD Card Error Fat32 E 3 (Fat FS: D1) Cheers, grizz
I have noticed something strange that is happening with beta 21 on my SEQ. When I try and create a new session I get a SD card error. Unfortunately I don't have my sequencer here with me as its at my practice space because I have a show tonight. It gives some sort of FAT32 message. I can however open and save already existing sessions. I will edit this post tomorrow with the exact error message that I get. Cheers, grizz
I updated to V4.0BETA21 successfully today! :-) The only issue I had was these messages: [101205.130] [sEQ_FILE_C] ERROR: unknown parameter: MIDI_IN_Channel [101205.132] [sEQ_FILE_C] ERROR: unknown parameter: MIDI_IN_Port [101205.134] [sEQ_FILE_C] ERROR: unknown parameter: MIDI_IN_TA_Split [101205.136] [sEQ_FILE_C] ERROR: unknown parameter: MIDI_IN_TA_SplitNote Is this a problem? I'm thinking it has to do with settings that I have that are no longer compatible or relevant with the new version? Cheers, Grizz
Thanks for the help. I got a kit from SmashTV, so the style of resistor network should be right, so I think I either got a defective one or fried it somehow. It is definitely the correct value RC as well. I'll look up directions on how to build a RC myself with 4 resistors and see if that does the trick. Cheers, grizz
So i guess it is update time... I still can't get the AOUT_NG to work with my MB-SEQ, but it works fine with my MB-6582. SO where I'm at is that I know the problem is somewhere on the SEQ end. I get a 5 volt reading on the 5v power rails on the AOUT_NG when it is hooked up to the SEQ, and I know that I have it connected correctly. Also When I have my multimeter clamped to the CV pins on the AOUT_NG I get a reading of 0.02... Questions: Is there a method to test the resistor network without de-soldering it? Would someone be willing to post me a copy of there MB-SEQ V4 files that they are using successfully with Wilba's control surface and an AOUT_NG? I know that's an annoying request, but for the life of me I can't figure this out. Cheers, Alex
Thanks for the replies. I like the chip search... I'll be using that in the future I'm sure. I went with these 771-74HC165N from Mouser. Cheers, Grizz
Sorry, 6-10 was quantity, and the other was part of the mouser #. I copied and pasted and then forgot to edit. Thanks! I can't read German, but I think I can figure out of to purchase them. Cheers, grizz
Hey all does anyone know where I can get a hold of 6-10 511-M74HC165 shift registers? Digikey and Mouser are out, and the estimated ship date is sometime in October... I might die of impatience before I get my MB-808 done :-) cheers, grizz
Hey. I am using my laptop USB, so I'll try out a hub with enough juice and see if that does the trick. Thanks, grizz PS: I can't wait to build and play with the 16x16 BLM... Nice work!
