371 -
16
Everything posted by eptheca
More like 7 years later :D Update 2024 I wanted to use my MIDIbox SEQ V4 more, in different situations, and make it more portable. I have made a new case in aluminium, so I can move all the modules, the CS frontpanel and the MIDI socket panel from the suitcase to the new case easy, and connect all the in's and out's on the new case to the modules.
@xarolium I had similar list of errors the first time I compiled. I can share the changes I made in the settings from the guide if you want. Hopefully I will get permission to upload images again, that will make it easier to explain. Hal
Compiling MIOS32 apps on Windows 10 help please [solved]
eptheca replied to eptheca's topic in MIDIbox Tools & MIOS Studio
I thought this guide from 2016 maybe was too old and obsolete, but it worked in the end after adapting to the Github repositories from the old SVN. -
Hi, I am trying to add images to posts, but I get an error message : "Something went wrong, try again" When I try to add images by dragging, I get this error message : "Sorry, an unknown server error occurred when uploading this file. (Error code: -200)" When I try to add an image with "Other Media" I get this message : " [[Template core/global/forms/uploadFile is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]] I have tried to find something in the Profile and Account Settings, but I can't find anything about the Theme. Best regards, Hal
Hi, Could someone help me with compiling the latest midibox_seq_v4 app. Because I have two 4xI2C modules, I have to change this in mios32_config.h // configure IIC_MIDI #define MIOS32_IIC_MIDI_NUM 4 The 4 needs to be changed to 8 I haven't updated since V94 I used to have this set up, so I could copy paste some lines in CMD, but it doesn't work anymore. I followed this instruction when I set it up I think... http://www.midibox.org/dokuwiki/doku.php?id=windows_mios32_toolchain_core Is this still the way to do it? I think it's for Windows XP Can anybody direct me to some new current information on how to do this now? Cheers, Hal
Solved. My bad. Human error. I forgot that I had wired up output 1 and 3 for convenience, and was adjusting 1 and 2. So now I have DIN sync clock and start/stop, and it's working fine for syncing old Roland gear. Still haven't found J5C.....
Does anybody know where the J5C port is? I can't find it on the Core board, or in the schematics, but the HW config file has a setting for J5_ENABLED where DIN sync and start/stop is forwarded to J5C.
Hi, I have added a DIN SYNC out socket to my SEQ V4 It's connected to a SR on a DOUT board, Enabled and assigned SR in the MBSEQ_HW file, and configured in the CV page. It starts and stops my Roland TR-606, but the tempo is very uneven. I have tried adjusting the Width in ms, but it makes no difference. Anybody with a suggestion? Cheers, Hal
Hi Bruno, I guess there are worse problems to have ;) Thanks for the feedback from your situation. Hope you and yours are well. Best regards, Hal
Hi, I have a problem in Windows 10 when connecting my SEQ V4 and my GM5 USB MIDI interface. If I connect the GM5 it is named Ploytec. If I connect the SEQ it is named MIDIbox SEQ V4+ Depending on which I connect first, the second one is named the same as the first, even if they appear separate with their correct name in Device manager. MIOS Studio can not connect to the SEQ when they are both connected, even if I select the correct one. Anybody have a solution for this? Cheers, Hal
The HAARP, a Hardware Advanced Arpeggiator.
eptheca replied to Antichambre's topic in MIDIbox User Projects
Brilliant Bruno! I love this project Looking forward to building this Cheers, Hal -
MB SID classic with 4x20 LCD setup question
eptheca replied to Noise-Generator's topic in MIDIbox SID
Here is the instructions on how to set up the tools http://www.midibox.org/dokuwiki/windows_toolchain_quickstart -
Here's the two versions of V2_044 compiled with settings for 4x20 Enjoy :) setup_6581.hex setup_8580.hex -
in the asm file, change to this, compile, upload and Bob's your uncle: ;; number of LCD lines (supported: 2 for 2x* LCDs and 4 for 4x* LCDs) #define DEFAULT_LCD_LINES 4 ;; LCD line -> cursor offsets #define DEFAULT_LCD_LINE_Y0 0x40 #define DEFAULT_LCD_LINE_Y1 0x14 #define DEFAULT_LCD_LINE_Y2 0x00 #define DEFAULT_LCD_LINE_Y3 0x54 -
