gomiboy99
Programmer
    192
  • Gender
    Not Telling
  • Location
    Folkestone, UK
Recent Profile Visitors
2,029 profile views
gomiboy99's Achievements
MIDIbox Addict
MIDIbox Addict (2/4)
  1. If you want to modify the clock box, my visual metronome project was based on it, it has been a while since I looked at it but think there was some code for using the eeprom. Hopefully it will provide a few pointers.
  2. That port should be connected to SC on J19. Check you have soldered the joint on J19 correctly. It seems unlikely that the track is missing as my board has continuity between J19 and PB6. I assume you have a board from SmashTV.
  3. Hi All, I have a problem with my SEQV4 not communicating with an AOUT_NG. The AOUT works in my CV V1 (PIC core). The AOUT works with an LPC core running the latest SEQV4 firmware. I used the cables from my SEQ to run the test, so the cables are fine. The J19 jumper is set for 5V and the 1K SIL resistor is in place and the right way around. I have also checked the core board for shorts and disconnections, all is as it should be. I ran the testaoutpin test with these results: CS 0 voltage = 0.09 CS 1 voltage = 3.91 SI 0 voltage = 0.09 SI 1 voltage = 3.87 SC 0 voltage = 0.10 SC 1 voltage = 4.99 HIGHER than expected on this pin. I suspect I may have damaged the SC port on the STM32. Before I order a new MCU and tear the SEQ apart, is there an easy way around this problem? Thanks in advance. Tim.
  4. I have a SEQv4 with 7 outs, I used the BLM connector as normal MIDI and used an IIC module (you can get kits from http://www.midibox-shop.com/buy.html). The additional 4 ports are USB but I don't think these are designed to be connected to synths,they are used to connect to a PC/DAW.
  5. I use a Microchip ICD2, you can get cheap clones of this on EBAY, just search for ICD2. That should do the job nicely.
  6. I have fixed a couple of bugs that I discovered today. The new files are available from the wiki here.
  7. gomiboy99
    Gomiboy99's Midibox album
  8. After a year of other distractions, I have finally updated the VM project to version 0_2. Changelog: updated menu to add store, recall and format functions for eeprom added eeprom routines to store 32 presets DIN pin assignments corrected to conform with documentation I discovered a small error in main.c with the set-up of the LEDs on power-up. This is now corrected. Please note that pre-compiled hex files are in the downloadable zip file. I have tested the PIC18F4685 version but the PIC18F452 is untested as I don't have a spare chip at the moment. The WIKI has links to the updated files.
  9. OK, found the answer, it's in the manual.
  10. Nice work! I like the minimal design of the control surface. I already have a seqv4 with the wilba panel but want to build a more compact and simple version for my modular synth project. How do you select different tracks and parameter layer with the single buttons on the left side?
  11. Hi, I think I could use one of these too, if there is one available. Thanks Tim.
  12. Many thanks
  13. Hi TK, thanks for the update, I really like the new file browser. Is it possible to add the multi bank to the Blofeld librarian? I have been using this a lot since I got the keyboard version. Happy New Year Tim.
  14. 4 more PCBs added to the wiki page. Nice design.
