Hawkeye
Administrators
    3,632
    36
Everything posted by Hawkeye
  1. Hawkeye
    midiphy MatriX :)
    From the album: Hawkeyes MB stuff
    Hola, it sure has been a while - but finally the new midiphy MatriX has been launched - with full BLM 16x16+X support, so all MIDIbox SEQ v4 can be attached. More info: https://www.midiphy.com/en/matrix/ Best regards, Peter
  2. @UnUnUniumthanks for your kind words - and your SEQ v4+ looks great - cheers to #46! :) Best regards, Peter
  3. @UnUnUnium should be no problem, modding is great! No physical changes either on the PCBs or case were made which changed anything about the MEC switches. I've not tried that mod, so i can't tell you if the parts are correct. Best regards and have fun building! Peter
  4. That's a great plan, J! :) Game of Life should be doable! Every MatriX customer gets a free wish! ;-) Necessary restrictions in the small print: only code work, only if it can be done in reasonable time and only if others would enjoy it as well. A minesweeper clone (imagine that, with physical mechanical keyboard buttons!) was also requested and i am really tempted! :) Many greets, Peter
  5. Yes! Tetris was requested quite often! Technically it should be easy to implement, but there might be trademark problems... Many greets! Peter
  6. With a lot of hacking, it might, i heard there are even C64 doom versions! :) Many greets, Peter
  7. From the album: Hawkeyes MB stuff
    Well done, it's looking great! I'm still working on the software side (dual device support and LoopA support), but we're definitely getting closer to the release date! Many greets, Peter
  8. Thanks Dave, also for this fantastic sequencing demo from you! Glad to see a LoopA used properly, how it was intented to be used: Best regards and have a happy weekend! Peter
  9. @Smithy as a note, we only sell the latest, matching revisions in the shop - the shown V1.0 is a "Neaderthal" :) one from the beta-test days, the first revision of the SEQ v4+ :). I hope Andy can tell you a bit more about it, otherwise we can just send you a new version. Best regards, Peter
  10. @silverlight2004 Thanks a lot for the suggestions, Dave! The dynamic memory allocation feature is on the to-do list (but it's not easy to implement...) Multi MIDI channels per track/clip unfortunately most likely cannot be supported, as the whole architecture of LoopA is based on having a single MIDI OUT or a single instrument per track - basically all code relies on that. Supporting notes with potentially different MIDI channels within a single clip would both consume more memory (which is quite maxed out already) and would make it super difficult to visualize what is going on using the OLED. Supporting this would also make it impossible to remap existing clips to other instruments (which have only a single OUT/CHN pair). Ultimately, i think it could confuse users, when some notes in a clip are played, back while others are not played (i.e. because there is no synth listening to "their" MIDI channel). For multi-recording two synths at once (i.e. two keyboards), it would be easiest to rely on a second LoopA, that is MIDI-synced to the first - which also doubles the amount of parallel tracks available. I know at least one power user (not me), that uses two LoopAs for this :). Many greets, Peter
  11. Great job! Have a nice weekend! Many greets, Peter
  12. @latigid on congrats to #44, well done and looking good! :-) (it's really true, it's his first one. he basically designed the PCBs and supported it for all those years without actually fully building one... hats off!) Many greets, Peter
  13. @mex very cool! We're still sourcing a few parts and finalizing documentation, as well as expanding the software a bit - so it will still require some time, but it's working nicely (the build is also already externally verified :)) @Phatline yes, 32-bit :) Many greets and have a nice weekend, Peter
  14. @Cysex Thanks for the nice words regarding the video tutorial - good, that it worked out! And a +1.000.000 fan bonus from me for running OctaMED on an Amiga :) Best regards, Peter
  15. Super small demo of the newest hardware variant: Enjoy the weekend and many greets! Peter
  16. @armandhammer cheers, great it worked out in the end! Enjoy your new LoopA! Best regards, Peter
  17. Looks very nice, both your new Euro Modules and the rack! Cheers and best regards! Peter
  18. @wavewalker - it has been delayed due to too many projects brewing in the kitchen :). Maybe, one day... :) Best regards, Peter
  19. @m00dawggreat job with your new album (listening now! :)) and very nice use of the SIDs! :) Best regards, Peter
  20. How about multitasking? In app_init you could create a thread/task that updates the user interface and screen and which is responsive, directly after app start. Then, you could create another "heavy lifting" task that does calculations/sd card operations etc as needed by your app. That task will probably need mutex locks, but can do the copy operations in the background while you can show the progress "on screen" in the first task. Best regards, Peter
  21. Hi Matt, great to hear that your LoopA works now and sorry for the late reply, there's a lot going on at the moment :). Basically the LoopA has now maxed-out memory for everything (i see no chance for multiple UNDO levels) and it has been quite complex to fit every feature in 192kB RAM. I've added your requests on the development wishlist, but we're currently and still working hard to finally release the MatriX, so can't promise any direct LoopA code work in the immediate future. You can save a lot of power, by using the new "OLED off" screensaver mode i think present since v.207 - a few single LEDs that are illuminated won't draw too much power, especially if the LoopA is stopped and you only have a single active track with no other mute/unmute LEDs being lit up. Note clean-up, de-duplication and pedal handling is a tricky process, would need to look into it in more detail. For the time being, we're discussing with Thorsten on how to proceed with general code releases (expect a statement from him in March 2021). Many greets, Peter
  22. @flyweight hopefully there's no need to be disappointed - when you use the SEQ v4/v4+ with long pattern lengths (e.g. 256 steps instead of 16) and a clock divider set up to play back the individual steps quickly, this is very close to unquantized recording. If unquantized recording is your top item, i would recommend to additionally add a LoopA to your sequencer setup - it is optimized for that, but can't do a lot of things the bigger v4/v4+ can do. Our "dream" sequencer setup would be one v4/v4+, one LoopA and one MatriX (BLM) connected to both, for 16 tracks of step-sequencing plus 6 tracks of unquantized note-roll sequences plus hands-on-control with a large button matrix. @srmaietta can't really speak for Thorsten, but i believe the v4/v4+ was basically developed as a step sequencer with rigid timing, basically for electronic music. With the availablity of long sequences AND clock dividers, it is absolutely possible to record "human" sequences that are not consisting of 16th notes or 16th note positions. This method avoids introducing the "delay-per-step" parameter layer, which is difficult to interpret - i.e. what happens when swing is applied, what happens with other fx (like echo) and non-linear sequence progression modes and so on. Best regards, Peter
  23. Hawkeye
    midiphy MatriX :)
    And here's the final MatriX production case and looks - hope you like it! All kudos fly out to @AdrianH and @latigid on - thanks for the great case and the great hardware! :) Many greets, Peter
  24. @cit very well done - cheers to #40! Many greets, Peter
  25. @doc007 It's coming in early 2021 - sorry, in these times everything takes longer than before and longer than anticipated - here's a super-short teaser video for you (you can watch it also without a facebook account): https://www.facebook.com/257188091723567/videos/867640500697077 Best regards and have a happy 2021! :) Peter
