PSU for AOUT Module
orange_hand
Hi guys,
I am currently looking for a PSU suitable for an AOUT module. I saw the bulk order for the Meanwell RPT-60B and wonder if this works well together with the AOUT:
Meanwell RPT-60B
http://www.meanwell.com/search/RPT-60/RPT-60-spec.pdf
Can anybody confirm whether this works fine on an AOUT module or not ?
I also found a linear bipolar one from Doepfer, which is very expensive and I wonder if there are other options out there:
Doepfer A-100 PSU2
http://www.thomann.de/de/doepfer_a_100psu2.htm
I would appreciate if we could collect the PSU’s in this thread suitable for the AOUT
Cheers
orange
AOUT only requires +12v, GND and -12v, +5V is delivered by the Core in the default configuration. Any PSU that delivers those voltages will work. If you choose a switching PSU like the Mean Well it is good practice to place some capacitors between the PSU and your project. Also mind the switching frequency.
The Mean Well has a separate +5v line that could be connected to the AOUT board, but then it would be wise not to connect the +5v from the Core to the AOUT.
ok, so you can supply the core32 as well as the AOUT with one PSU ? It is just important to connect the +5V for the AOUT either directly from the Meanwell or indirectly through the Core32, correct ?
If you supply the Core32 from the +5V rail of the meanwell, do you still need a voltage 5V regulator on the core board ?
Cheers
orange
Edited by orange_hand
@mwidhalm: the datasheet says nothing about the switching frequency of that PSU (or at least I couldnt find it). Beware that it might be in the audio range.
@latigid on: if it would be possible to create -12v from +5v with your suggested solution, you still would need to power additional modules that you need the CV signals for. If those are in another box with a separate PSU it might work, I'm no expert. At least I would rather buy a known good psu than tinker with something else, I've had too many PSU related issues that put me off completely for a good while.
I'm about to use Recom RS-0512D in another project (being able to convert 5V to +/-12V), also, it's being used in mistralXG design (and I assume successfully) that was discussed some time ago. Maybe definitely worth a try but it's only up to 3W, which still should be plenty for few opamps.
Hope this helps,
freddy
From Mouser there are 0.5W and 1W solutions for 10,39 and 18,26€ respectively. 70 kHz switching frequency, which I would hope to be high enough to avoid problems, but I'm not sure! The Recom unit seems to have a higher switching frequency of 100 kHz or more, so it is probably better in that regard.
http://eu.mouser.com/ProductDetail/Murata-Power-Solutions/NMJ0512SC/?qs=sGAEpiMZZMtwaiKVUtQsNdN9l48nzt7a%252bz8taXcceL0%3d
http://eu.mouser.com/ProductDetail/Murata-Power-Solutions/NMS0512C/?qs=sGAEpiMZZMtwaiKVUtQsNcW9zb9tavYg9JdPS%252b2oOa4%3d
http://www.mouser.com/ds/2/281/kdc_nmj-19483.pdf
Edited by latigid on
