TomViolenz Posted April 1, 2014 Posted April 1, 2014 Hey Jerome, I had contacted you before for this board and I am very happy to read that new bulk orders are comming up for an improved version. I want to use these boards to built a controller with as many led lit encoders with a push functionality for 8 channels as possible (I'm refering to 8 columns here, so just like your board). So here come a few questions from a noob :-) 1) How many of these boards can I stack on top of each other at the maximum, 4 or 8?! (I think if I understood you right, the last version allowed for 4 while this one allows for 8 - is this right?) So this would then be at maximum 8 columns of 16 encoders each, correct?! (If it's just 8 columns of 8 encoders each that would also be very usefull) 2) I didn't quite get how far these new boards come already pre-assembled. Are the Leds already functionaly applied (i.e. soldered)? How about the encoders(with push functionality?)?! Not that I necessarily expect that, but the wording in one of your post made me think that this is an option. Since this would be my very first forray into building a controller, I would of course welcome that. 3.) What other hardware would I need to get these boards to work? Could you point me into the right direction for the necessary information? 4.) Is there a possibiltity to add one 60 or 100mm fader per channel ( meaning 8 in total) directly below the last encoder in each column? What would I need for this. and 5.) Somewhat unrelated (though if this was something that I could incorporate into the same controller that would be even more awsome, especially if it could follow somewhat the same dimensions) I was looking into building a controller with 8 small (non springloaded) joysticks, so that I can adjust the x-y stereo placement of 8 channels precisely (using the Panorama 5 plug-in that has this functionality, so this should be a Midi joystick). What kind of board would I need for that and could this be still controlled with the same controll board as the above mentioned encoders and faders.? Thank you ever so much for your great work and your responses :-) Cheers Tom
Fairlightiii Posted April 1, 2014 Author Posted April 1, 2014 Hi Tom. Some answers: 1)How many of these boards can I stack on top of each other at the maximum, 4 or 8?! 8 with Midibox NG. 2)I didn't quite get how far these new boards come already pre-assembled. Are the Leds already functionaly applied (i.e. soldered)? MB-LRE8x2CS has notthing pre-assembled. If you want the LEDs already soldered, go for MB-LR4x2CS / MB-E4x2CS. 2)How about the encoders(with push functionality?)?! Typically you can configure this to switch between the different modes (speed) of the encoder but you can assign any parameter to the command. 3.)What other hardware would I need to get these boards to work? Could you point me into the right direction for the necessary information? Minimum: 1 core (any model: PIC, LPC17 or STM32F4 based core). In case you want to use the built-in switch of the encoders, you need to add a DINx2 module for each MB-LRE8x2CS. You can find the different Cores and the DIN modules in the SmashTV's shop. 4.)Is there a possibiltity to add one 60 or 100mm fader per channel ( meaning 8 in total) directly below the last encoder in each column? What would I need for this. The faders and a AIN module (also in in the SmashTV's shop). and 5.) What kind of board would I need for that and could this be still controlled with the same controll board as the above mentioned encoders and faders.? You should consult the midibox page about the AIN module and use the search function of the forum to see if someone as already tried this type of use. Best regards, Jerome.
TomViolenz Posted April 1, 2014 Posted April 1, 2014 Thanks a lot for your response :) I will look into all this gear, and come probably back with some more questions :) Cheers
jobi Posted April 2, 2014 Posted April 2, 2014 Hi jerome, I would like to join the list with : MB-LRE8x2CS rev 4.6 x 1 MB-LR4x2CS_RED x 1 MB-LR4x2CS_Blue x 1 MB-E4x2CS x 1 16mm Encoder 25mm Schaft 25Stk. Cheers from Seine et marne! Jobi
Fairlightiii Posted April 2, 2014 Author Posted April 2, 2014 MB-LRE8x2CS rev 4.6 x 1 MB-LR4x2CS_RED x 1 MB-LR4x2CS_Blue x 1 MB-E4x2CS x 1 16mm Encoder 25mm Schaft 25Stk. Done. Cheers from Seine et marne! :smile:
Fairlightiii Posted April 3, 2014 Author Posted April 3, 2014 This is some pictures of the PCBs. You will find more pictures in my gallery. Best regards, Jerome.
jobi Posted April 4, 2014 Posted April 4, 2014 Hi jerome, Could you please add one more MB-E4x2CS x 1 for me. Thanks!
Fairlightiii Posted April 4, 2014 Author Posted April 4, 2014 Hi jerome, Could you please add one more MB-E4x2CS x 1 for me. Thanks! Done. Best regards, Jerome.
crunchie Posted April 7, 2014 Posted April 7, 2014 Great work on the PCB's Jerome! Glad to see how far these have come. Can't wait to get my hands on these =]
Fairlightiii Posted April 8, 2014 Author Posted April 8, 2014 (edited) I posted a in the gallery. The camera has created a "halo" around the LED. The brightness is perfect ! Best regards, Jerome. Edited April 8, 2014 by Fairlightiii
m00dawg Posted April 8, 2014 Posted April 8, 2014 It looks quite pretty!I'm personally not a fan of blue LEDs for interfaces and, in fact, there have been a few epic discussions on these forums about them. Both in terms of practicality and in terms of posing an increased risk for long term vision problems.Not trying to sway anyone one way or another. I just personally stick to red, orange, or green for most things that are at least in direct line of sight.
Fairlightiii Posted April 10, 2014 Author Posted April 10, 2014 It looks quite pretty! I'm personally not a fan of blue LEDs for interfaces and, in fact, there have been a few epic discussions on these forums about them. Both in terms of practicality and in terms of posing an increased risk for long term vision problems. Not trying to sway anyone one way or another. I just personally stick to red, orange, or green for most things that are at least in direct line of sight. I have read more or less the epic discussion you speak about but this is a only a prototype for the moment (I could choose 2 different colors for the 3 prototypes I ordered), my plan would be to add a semi-transparent acrylic panel in front of them and I planned in all the case to point members on the risk using blue LEDs when the things will begin serious during this BO. Best regards, Jerome.
Fairlightiii Posted April 15, 2014 Author Posted April 15, 2014 Some pictures of 2 chained boards in the Best regards, Jerome.
fabcoulon Posted May 19, 2014 Posted May 19, 2014 (edited) Hi jerome Please, could you add me to the list for 8 x mb-lre8x2cs. Many thanx Fabrice Edited May 19, 2014 by fabcoulon
Fairlightiii Posted May 19, 2014 Author Posted May 19, 2014 Hi jerome Please, could you add me to the list for 8 x mb-lre8x2cs. Many thanx Fabrice Done. Best regards, Jerome.
Macotronic Posted June 4, 2014 Posted June 4, 2014 Hi Jerome im interested in the pcb's but dont find prices just to know what I can get. Thanks
ioannis taf Posted June 20, 2014 Posted June 20, 2014 Hello Jerome. Am I late? If no,please, add: 2 x MB-LRE8x2CS , 1 x MB-LR4x2CS, 2 x MB-E4x2CS . Can't register on wiki. Thank you so much, Ioannis T.
Imp Posted January 11, 2015 Posted January 11, 2015 Is this still happening? You know, i got a school project due tomorrow, and i desperately need this!!!1111 :tongue:
All2u Posted March 17, 2015 Posted March 17, 2015 (edited) Hello have you planned to build 8x1 pcb ? Best regards Edited April 1, 2015 by All2u
Aki Posted September 20, 2015 Posted September 20, 2015 Hello. Is there any chance to get this PCBs? Or maybe get eagle files?Best wishes,Micha?.
