Antichambre Posted September 22, 2017 Posted September 22, 2017 Hello, I've got a quotation for 100 pieces of 12PLRGBSD1VBF-D-15F-2B10K-001-6H from TOP-UP It's a linear 10K Potentiometer with RGB Led Shaft and Push-Switch of 0.3mm travel. Price is 3.90$ each. 100 pieces is a minimum and this is not very big. I haven't got shipment price for the moment.Specifications: The shaft type: Flatten(F) shaft length: 15mm Taper: Linear(2B) resistance value: 10KDrawing(pdf) / Specs(pdf) / Taper(pdf) Who wants some?
jojjelito Posted September 26, 2017 Posted September 26, 2017 I'd be down for 20 of those post for some tinkering
Antichambre Posted September 27, 2017 Author Posted September 27, 2017 25 minutes ago, jojjelito said: I'd be down for 20 Great! I need 25 but I can take 30 moreThen 50 pieces! Anyone else?
Antichambre Posted September 29, 2017 Author Posted September 29, 2017 I need it, I propose it, so I offer shipping to and from my home. I hope this will help some to decide and reach this small amount!50/100 for the moment... Someone? Best regards Bruno
Zam Posted September 30, 2017 Posted September 30, 2017 Bonjour Bruno No really need for this now, but for the record I'm curious to know what knob/caps option is available for this ? Best Zam
Antichambre Posted September 30, 2017 Author Posted September 30, 2017 (edited) Everything is from ebay. And from djtechtools Second column are transparent and glow in the dark. All rubber. As you can see they have got encoder knob too. They sent me some samples to try it... Edited September 30, 2017 by Antichambre
Antichambre Posted September 30, 2017 Author Posted September 30, 2017 (edited) I will probably use this Led Driver from TI. It's a One Wire daisy-chain with Internal clock and 8bit PWM to relieve CPU. For 0,8Euro each. You're sure you don't want some? ;) Best Bruno Edited September 30, 2017 by Antichambre
Zam Posted September 30, 2017 Posted September 30, 2017 Hi Never looked at this, tks for the pic, seems like lot of knob design today offer transparent option! Truly interesting ;) but sorry no need for this right now Best Zam
Antichambre Posted September 30, 2017 Author Posted September 30, 2017 About djtechtools, they provide me some samples and the contact for bulk discount...
ilmenator Posted September 30, 2017 Posted September 30, 2017 4 hours ago, Antichambre said: I will probably use this Led Driver from TI. It's a One Wire daisy-chain with Internal clock and 8bit PWM to relieve CPU. For 0,8Euro each. How many different RGB LEDs (=encoders) can you drive using one of those?
Antichambre Posted September 30, 2017 Author Posted September 30, 2017 2 minutes ago, ilmenator said: How many different RGB LEDs (=encoders) can you drive using one of those? Using TLC59731 ? One RGB Led, This is 3 channels driver. A 32-Bit Data Packet. 8bits command + 3x8bits(RGB). The goal is to relieve the CPU and facilitate the design of the layout. It requires 3 resistances too, but it's only one line between each driver, between each RGB pot. It's 8 pins SOIC package, not too big or too small. In datasheet page 18, it says "There is no limit on how many devices can be cascaded, as long as proper VCC voltage is supplied." Best Bruno
ilmenator Posted September 30, 2017 Posted September 30, 2017 I see, doing the $$ math I rather stay with regular encoders - but thanks for the idea!
