Sign in to follow this
Followers 0
FantomXR
Push & Hold - function?
10 posts in this topic
Hey people,
maybe I missed it or it is not possible.
I'd like to set up a switch. This switch should have to functions. The first is executed as soon as I push it an release it immediately. The second one should be executed if I push the button and hold it for a given amount of time.
Any ideas?
Thanks,
Chris
Share this post
Link to post
Share on other sites
You can do something like this, I didn't test it, you will maybe have to correct it.
In your App.c
#define BUTT_PIN_NUM 0
#define HOLD_TIME 3000 // in ms cause APP_SRIO_ServicePrepare is called every ms
u8 butt_last_state;
u16 butt_hold_count;
// This hook is called before the shift register chain is scanned
void APP_SRIO_ServicePrepare(void)
	if(butt_last_state == 0){
		butt_hold_count++;
		if(butt_hold_count >= HOLD_TIME){  //3 second hold time
			// function#2 here
          	butt_last_state = 1; //avoid repetitive Function#2 and Function#1 to be triggered just after Function#2
	}else{
		butt_hold_count=0;
// This hook is called when a button has been toggled
// pin_value is 1 when button released, and 0 when button pressed
void APP_DIN_NotifyToggle(u32 pin, u32 pin_value)
	if(pin == BUTT_PIN_NUM){
		if(pin_value == 1 && butt_last_state == 0){
			if(butt_hold_count < HOLD_TIME){
				// function#1 here
		butt_last_state = pin_value;
If you need it in MBNG I don't know.
Note: If Function#2 need a lot of process you can use a task to do not delay your SRIO Process. tutorial 006_rtos_tasks
Edited by Antichambre
task note
Share this post
Link to post
Yes... I'd need to do this in NG.... hmmm
Thanks for your help!
Share this post
Link to post
I did not see that it was in the NG tree before having already written it. I really do not know anything about NG sorry.
Share this post
Link to post
I solved it!
This is the NGC part:
EVENT_BUTTON id=1 type=meta meta=runsection:1 button_mode=OnOff if_equal=127
And this is the NGR part:
if ^section == 1
    delay_ms 500
    if BUTTON:1 == 127
      SEND CC USB1 1 1 127
      exit
    endif
    if BUTTON:1 == 0
      SEND CC USB1 1 2 0
      exit
    endif
endif
This code wait's 500ms and checks if the button is still pressed. If yes it sends on channel 1, if not it sends on channel 2.
Share this post
Link to post
Great! there's both solution now in you post, Hihi
One day it will be interesting that I look a little in NG :blush:
Share this post
Link to post
@FantomXR you're my daddy. everything i wanna search on the forum i always find a thread where you found the answer 5 years ago.
Share this post
Link to post
Hello
if ^section == 1
    delay_ms 500
    if BUTTON:1 == 127
      exit
    endif
    if BUTTON:1 == 0
      SEND CC USB1 1 2 0
      exit
    endif
endif
You can reduce the time for the short push to only wait the processing when long time press
if ^section == 1
    delay_ms 50
    if BUTTON:1 == 0
      SEND CC USB1 1 2 0
      exit
    endif
    delay_ms 500
    if BUTTON:1 == 127
      exit
    endif
endif
By this you can handle both situation time in any time respond configuration you want
Note that first condition will in fact be the time you manually release the button (if shorter than second delay) + the first delay as the script will re-trig when button is off ( due to button_mode=onoff)
Best
Zam
Share this post
Link to post
Followers 0
