FantomXR Posted June 21, 2019 Posted June 21, 2019 (edited) Hey people, I'd like to add one or two chip-selects for the AINSER8. I've already made a few changes to the firmware but it's not working yet. Under modules I've edited the ainser.c: { switch( module ) { case 0: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE1, value); // spi, rc_pin, pin_value case 1: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE2, value); // spi, rc_pin, pin_value case 2: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE3, value); // spi, rc_pin, pin_value #if AINSER_NUM_MODULES > 3 # error "CS Line for more than 2 modules not prepared yet - please enhance here!" #endif } and ainser.h: // Which RC pin of the SPI port should be used for the third module // allowed values: 0 or 1 for SPI0 (J16:RC1, J16:RC2), 0 for SPI1 (J8/9:RC), 0 or 1 for SPI2 (J19:RC1, J19:RC2) #ifndef AINSER_SPI_RC_PIN_MODULE3 #define AINSER_SPI_RC_PIN_MODULE3 2 #endif and mios32_spi,h #define MIOS32_SPI2_RCLK1_PORT GPIOA // RC1 #define MIOS32_SPI2_RCLK1_PIN GPIO_Pin_15 #define MIOS32_SPI2_RCLK1_AF { GPIO_PinAFConfig(GPIOA, GPIO_PinSource15, GPIO_AF_SPI3); } // only relevant for slave mode #define MIOS32_SPI2_RCLK2_PORT GPIOB // RC2 #define MIOS32_SPI2_RCLK2_PIN GPIO_Pin_8 #define MIOS32_SPI2_RCLK2_AF { } #define MIOS32_SPI2_RCLK3_PORT GPIOC // RC3 #define MIOS32_SPI2_RCLK3_PIN GPIO_Pin_1 #define MIOS32_SPI2_RCLK3_AF { } #else MIOS32_SPI2_RCLK1_AF; MIOS32_SPI2_RCLK2_AF; MIOS32_SPI2_RCLK3_AF; MIOS32_SPI2_SCLK_AF; MIOS32_SPI2_MISO_AF; MIOS32_SPI2_MOSI_AF; if( slave ) { // SCLK and DOUT are inputs assigned to alternate functions GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_SCLK_PIN; GPIO_Init(MIOS32_SPI2_SCLK_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_MOSI_PIN; GPIO_Init(MIOS32_SPI2_MOSI_PORT, &GPIO_InitStructure); // RCLK (resp. CS) are configured as inputs as well GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_RCLK1_PIN; GPIO_Init(MIOS32_SPI2_RCLK1_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_RCLK2_PIN; GPIO_Init(MIOS32_SPI2_RCLK2_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_RCLK3_PIN; GPIO_Init(MIOS32_SPI2_RCLK3_PORT, &GPIO_InitStructure); // DOUT is output assigned to alternate function GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_MISO_PIN; GPIO_Init(MIOS32_SPI2_MISO_PORT, &GPIO_InitStructure); } else { // SCLK and DIN are inputs GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_SCLK_PIN; GPIO_Init(MIOS32_SPI2_SCLK_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_MOSI_PIN; GPIO_Init(MIOS32_SPI2_MOSI_PORT, &GPIO_InitStructure); // RCLK (resp. CS) are configured as inputs as well GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_RCLK1_PIN; GPIO_Init(MIOS32_SPI2_RCLK1_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_RCLK2_PIN; GPIO_Init(MIOS32_SPI2_RCLK2_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_RCLK3_PIN; GPIO_Init(MIOS32_SPI2_RCLK3_PORT, &GPIO_InitStructure); // DIN is input with pull-up GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Pin = MIOS32_SPI2_MISO_PIN; GPIO_Init(MIOS32_SPI2_MISO_PORT, &GPIO_InitStructure); } #else switch( rc_pin ) { case 0: MIOS32_SYS_STM_PINSET(MIOS32_SPI2_RCLK1_PORT, MIOS32_SPI2_RCLK1_PIN, pin_value); break; case 1: MIOS32_SYS_STM_PINSET(MIOS32_SPI2_RCLK2_PORT, MIOS32_SPI2_RCLK2_PIN, pin_value); break; case 2: MIOS32_SYS_STM_PINSET(MIOS32_SPI2_RCLK3_PORT, MIOS32_SPI2_RCLK3_PIN, pin_value); break; default: return -4; // unsupported RC pin } break; #endif In the NGC I have: AINSER n=1 enabled=1 cs=2 num_pins=1 and nothing happens. Which part do I overlook for adding a CS? Thanks! Chris Edited June 21, 2019 by FantomXR
Zam Posted June 21, 2019 Posted June 21, 2019 Hello Chris For AINSER8 you have to define muxed=0 at NGC because it's set to 1 by default, but not sure it's your issue here Can I ask for what reason you need more lines? because you already have two line (if not using AOUT) for 16ch Also it may be a better workaround to use a muxed MCP3202 for 16ch or MCP3204 for 32ch, I suspect it will request less change at soft side... I have this in mind since time, but don't start yet...for potential project that need intermediate ADC count and to gain room compared to an AINSER64 with disabled channels. Best Zam
Zam Posted June 21, 2019 Posted June 21, 2019 I just have a deeper look even if i'm not confident with code... pin C1 is already used at J5, maybe you have to deactivate/remove something in the code, also it's the 32F4 ADC Why don't you use a free pin at j10 ? Best Zam
FantomXR Posted June 22, 2019 Author Posted June 22, 2019 10 hours ago, Zam said: Hello Chris Hi Zam! Thanks for your reply. 10 hours ago, Zam said: For AINSER8 you have to define muxed=0 at NGC because it's set to 1 by default, but not sure it's your issue here I've tried that without success. 10 hours ago, Zam said: Can I ask for what reason you need more lines? Yes. I prefer having more traces (=not muxed) instead of having less traces and more parts (=muxed). I want to get rid of HC595 and 4051. In my application I need about 20 analog inputs. So, unfortunately 16ch. are not enough. 9 hours ago, Zam said: pin C1 is already used at J5, maybe you have to deactivate/remove something in the code, also it's the 32F4 ADC I thought that too. But I comment out those lines. Also I did a double check I took these lines from mios32_spi.h: #define MIOS32_SPI2_RCLK1_PORT GPIOA // RC1 #define MIOS32_SPI2_RCLK1_PIN GPIO_Pin_15 #define MIOS32_SPI2_RCLK1_AF { GPIO_PinAFConfig(GPIOA, GPIO_PinSource15, GPIO_AF_SPI3); } // only relevant for slave mode #define MIOS32_SPI2_RCLK2_PORT GPIOB // RC2 #define MIOS32_SPI2_RCLK2_PIN GPIO_Pin_8 #define MIOS32_SPI2_RCLK2_AF { } #define MIOS32_SPI2_RCLK3_PORT GPIOC // RC3 #define MIOS32_SPI2_RCLK3_PIN GPIO_Pin_1 #define MIOS32_SPI2_RCLK3_AF { } and changed the pin for RC1 to PC1 like this: #define MIOS32_SPI2_RCLK1_PORT GPIOC // RC1 #define MIOS32_SPI2_RCLK1_PIN GPIO_Pin_1 #define MIOS32_SPI2_RCLK1_AF { GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_SPI3); } // only relevant for slave mode #define MIOS32_SPI2_RCLK2_PORT GPIOB // RC2 #define MIOS32_SPI2_RCLK2_PIN GPIO_Pin_8 #define MIOS32_SPI2_RCLK2_AF { } #define MIOS32_SPI2_RCLK3_PORT GPIOC // RC3 #define MIOS32_SPI2_RCLK3_PIN GPIO_Pin_1 #define MIOS32_SPI2_RCLK3_AF { } And this is working great (of course with cs=0 in the NGC-file). So I don't think that PC1 is somehow "blocked" for this application. It can't be to hard to add more CS. I think I just overlook something...
Zam Posted June 22, 2019 Posted June 22, 2019 Hello Chris If PC1 work for CS 1 the pin configuration should be ok 21 hours ago, FantomXR said: and ainser.h: // Which RC pin of the SPI port should be used for the third module // allowed values: 0 or 1 for SPI0 (J16:RC1, J16:RC2), 0 for SPI1 (J8/9:RC), 0 or 1 for SPI2 (J19:RC1, J19:RC2) #ifndef AINSER_SPI_RC_PIN_MODULE3 #define AINSER_SPI_RC_PIN_MODULE3 2 #endif Are you sure about the pin value here? also did you define modules number ? (ainser.h) // Maximum number of AINSER modules (1..255) // (Number of modules can be changed via soft-configuration during runtime.) #ifndef AINSER_NUM_MODULES #define AINSER_NUM_MODULES 1 #endif and ainser.c ///////////////////////////////////////////////////////////////////////////// // Internal function to set CS line depending on module ///////////////////////////////////////////////////////////////////////////// static s32 AINSER_SetCs(u8 module, u8 value) { switch( module ) { case 0: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE1, value); // spi, rc_pin, pin_value case 1: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE2, value); // spi, rc_pin, pin_value #if AINSER_NUM_MODULES > 2 # error "CS Line for more than 2 modules not prepared yet - please enhance here!" #endif } return -1; } Best Zam
FantomXR Posted June 22, 2019 Author Posted June 22, 2019 2 hours ago, Zam said: Are you sure about the pin value here? No but I followed up the logic in the code above: // Which RC pin of the SPI port should be used for the first module // allowed values: 0 or 1 for SPI0 (J16:RC1, J16:RC2), 0 for SPI1 (J8/9:RC), 0 or 1 for SPI2 (J19:RC1, J19:RC2) #ifndef AINSER_SPI_RC_PIN_MODULE1 #define AINSER_SPI_RC_PIN_MODULE1 0 #endif // Which RC pin of the SPI port should be used for the second module // allowed values: 0 or 1 for SPI0 (J16:RC1, J16:RC2), 0 for SPI1 (J8/9:RC), 0 or 1 for SPI2 (J19:RC1, J19:RC2) #ifndef AINSER_SPI_RC_PIN_MODULE2 #define AINSER_SPI_RC_PIN_MODULE2 1 #endif // Which RC pin of the SPI port should be used for the third module // allowed values: 0 or 1 for SPI0 (J16:RC1, J16:RC2), 0 for SPI1 (J8/9:RC), 0 or 1 for SPI2 (J19:RC1, J19:RC2) #ifndef AINSER_SPI_RC_PIN_MODULE3 #define AINSER_SPI_RC_PIN_MODULE3 2 2 hours ago, Zam said: also did you define modules number ? (ainser.h) Not in ainser.h, but in the mio32_config.h with: // enable three AINSER modules #define AINSER_NUM_MODULES 3 2 hours ago, Zam said: and ainser.c Sure! I did this: static s32 AINSER_SetCs(u8 module, u8 value) { switch( module ) { case 0: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE1, value); // spi, rc_pin, pin_value case 1: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE2, value); // spi, rc_pin, pin_value case 2: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE3, value); // spi, rc_pin, pin_value #if AINSER_NUM_MODULES > 3 # error "CS Line for more than 2 modules not prepared yet - please enhance here!" #endif }
Zam Posted June 22, 2019 Posted June 22, 2019 10 minutes ago, FantomXR said: No but I followed up the logic in the code above: // Which RC pin of the SPI port should be used for the first module // allowed values: 0 or 1 for SPI0 (J16:RC1, J16:RC2), 0 for SPI1 (J8/9:RC), 0 or 1 for SPI2 (J19:RC1, J19:RC2) #ifndef AINSER_SPI_RC_PIN_MODULE1 #define AINSER_SPI_RC_PIN_MODULE1 0 #endif // Which RC pin of the SPI port should be used for the second module // allowed values: 0 or 1 for SPI0 (J16:RC1, J16:RC2), 0 for SPI1 (J8/9:RC), 0 or 1 for SPI2 (J19:RC1, J19:RC2) #ifndef AINSER_SPI_RC_PIN_MODULE2 #define AINSER_SPI_RC_PIN_MODULE2 1 #endif // Which RC pin of the SPI port should be used for the third module // allowed values: 0 or 1 for SPI0 (J16:RC1, J16:RC2), 0 for SPI1 (J8/9:RC), 0 or 1 for SPI2 (J19:RC1, J19:RC2) #ifndef AINSER_SPI_RC_PIN_MODULE3 #define AINSER_SPI_RC_PIN_MODULE3 2 Ok, the logic is "0, 1 or 2 for SPI2 (J19:RC1, J19:RC2, J5A:A0(nowRC3) )", I have something else(wrong) in mind sorry. I'm afraid I can't help more on this, miss some skill, let wait for a programmer Best Zam
FantomXR Posted June 22, 2019 Author Posted June 22, 2019 11 minutes ago, Zam said: Ok, the logic is "0, 1 or 2 for SPI2 (J19:RC1, J19:RC2, J5A:A0(nowRC3) )", I have something else(wrong) in mind sorry. This seems to be a good hint! Thanks! Maybe @TK. could guide us in the right direction! :-)
TK. Posted June 23, 2019 Posted June 23, 2019 You don't need to enhance mios32_spi, just control the additional pin directly from AINSER_SetCs E.g. let's assume that J10.D0 is unused so far, then add to AINSER_Init(): MIOS32_BOARD_J10A_PinInit(0, MIOS32_BOARD_PIN_MODE_OUTPUT_PP); and to AINSER_SetCs: case 2: return MIOS32_BOARD_J10_PinSet(0, value); Best Regards, Thorsten.
FantomXR Posted June 23, 2019 Author Posted June 23, 2019 Thanks for chiming in! Is it really so easy? :-) Thanks! I'll try it!!
FantomXR Posted June 24, 2019 Author Posted June 24, 2019 14 hours ago, TK. said: E.g. let's assume that J10.D0 is unused so far, then add to AINSER_Init(): Dear TK, I undo all changes and added the lines as you suggested. Unfortunately I can not get it working. I edited the ainser.h like this: s32 AINSER_Init(u32 mode) { MIOS32_BOARD_J10_PinInit(0, MIOS32_BOARD_PIN_MODE_OUTPUT_PP); s32 status = 0; int module, pin; // currently only mode 0 supported if( mode != 0 ) return -1; // unsupported mode #if AINSER_SPI_OUTPUTS_OD // pins in open drain mode (to pull-up the outputs to 5V) status |= MIOS32_SPI_IO_Init(AINSER_SPI, MIOS32_SPI_PIN_DRIVER_STRONG_OD); #else // pins in push-poll mode (3.3V output voltage) status |= MIOS32_SPI_IO_Init(AINSER_SPI, MIOS32_SPI_PIN_DRIVER_STRONG); #endif // SPI Port will be initialized in AINSER_Update() num_used_modules = AINSER_NUM_MODULES; #if AINSER_NUM_MODULES > 8 # error "If more than 8 AINSER_NUM_MODULES should be supported, the ainser_enable_mask variable type has to be changed from u8 to u16 (up to 16) or u32 (up to 32)" #endif #if AINSER_NUM_MODULES > 8 # error "If more than 8 AINSER_NUM_MODULES should be supported, the ainser_muxed_mask variable type has to be changed from u8 to u16 (up to 16) or u32 (up to 32)" #endif for(module=0; module<AINSER_NUM_MODULES; ++module) { num_used_pins[module] = AINSER_NUM_PINS; // ensure that CS is deactivated AINSER_SetCs(module, 1); AINSER_EnabledSet(module, 1); AINSER_MuxedSet(module, 1); AINSER_NumPinsSet(module, AINSER_NUM_PINS); AINSER_DeadbandSet(module, MIOS32_AIN_DEADBAND); // clear all values for(pin=0; pin<AINSER_NUM_PINS; ++pin) { ain_pin_values[module][pin] = 0; } previous_ain_pin_value = 0; } return status; } [] static s32 AINSER_SetCs(u8 module, u8 value) { switch( module ) { case 0: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE1, value); // spi, rc_pin, pin_value case 1: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE2, value); // spi, rc_pin, pin_value case 2: return MIOS32_BOARD_J10_PinSet(0, value); #if AINSER_NUM_MODULES > 3 # error "CS Line for more than 2 modules not prepared yet - please enhance here!" #endif } But when I now connect the Chipselect to PE8, which is D0 on J10A, nothing happens. Any idea? Thanks, Chris
TK. Posted June 24, 2019 Posted June 24, 2019 Another modification in mbng_file_c.c is required where the number of CS lines is hardcoded (actually you should have seen the error message...) I put an example which works at my side into the demo/mbng_ainser_with_3_cs branch, see: https://github.com/midibox/mios32/commit/ac6151ea7012e2b3e5e6a15575b4c4f92c8ffe2f Best Regards, Thorsten.
TK. Posted June 24, 2019 Posted June 24, 2019 Additional notes: could be that you rely on 5V output - in this case change MIOS32_BOARD_PIN_MODE_OUTPUT_PP to MIOS32_BOARD_PIN_MODE_OUTPUT_OD, and add a 1k pull-up to 5V to this pin. And if J10A is already used for SCS inputs (standard), just take J10B.D0 (pin index #8) Best Regards, Thorsten.
FantomXR Posted August 14, 2019 Author Posted August 14, 2019 Hey @TK., I tried it without success. I copied the code from you into my firmware. My NGC file looks like this: RESET_HW AINSER n=1 enabled=1 num_pins=1 cs=1 resolution=7bit AINSER n=2 enabled=1 num_pins=1 cs=2 resolution=7bit I have a potentiometer connected to the first analog input of the second and another one to the first input of the third module. The first module is not used at the moment. If I "set debug on" in the terminal, I see movements if I turn the potentiometer which is connected to the second module. Anyway I can not see anything when I turn the pot which is connected to the third module. I've tried both PP and OD mode (with 1k pullup to 5V). I use PE6, which should lead to MIOS32_BOARD_J10_PinInit(14, MIOS32_BOARD_PIN_MODE_OUTPUT_OD) and case 2: return MIOS32_BOARD_J10_PinSet(14, value); Any ideas what I do wrong?
FantomXR Posted August 19, 2019 Author Posted August 19, 2019 Dear @TK., could you help on this? I have no clue why this is not working at my side but at yours.
Antichambre Posted August 19, 2019 Posted August 19, 2019 Hi Chris, Do you test it without the NG with a regular app first? Can you share the code you change in MIOS32, whole AINSER files? Best Bruno
FantomXR Posted August 19, 2019 Author Posted August 19, 2019 57 minutes ago, Antichambre said: Do you test it without the NG with a regular app first? No. As I don't use any other app and I stated above that I want to use it in NG TK surely took care of it. This is ainser.c: // $Id$ //! \defgroup AINSER //! //! AINSER module driver //! //! \{ /* ========================================================================== * * Copyright (C) 2011 Thorsten Klose (tk@midibox.org) * Licensed for personal non-commercial use only. * All other rights reserved. * * ========================================================================== */ ///////////////////////////////////////////////////////////////////////////// // Include files ///////////////////////////////////////////////////////////////////////////// #include <mios32.h> #include "ainser.h" ///////////////////////////////////////////////////////////////////////////// // Local variables ///////////////////////////////////////////////////////////////////////////// static u8 num_used_modules = AINSER_NUM_MODULES; static u8 ainser_enable_mask; static u8 ainser_muxed_mask; static u8 num_used_pins[AINSER_NUM_MODULES]; static u16 ain_pin_values[AINSER_NUM_MODULES][AINSER_NUM_PINS]; static u16 previous_ain_pin_value; static u8 ain_deadband[AINSER_NUM_MODULES]; ///////////////////////////////////////////////////////////////////////////// // Local Prototypes ///////////////////////////////////////////////////////////////////////////// static s32 AINSER_SetCs(u8 module, u8 value); ///////////////////////////////////////////////////////////////////////////// //! Initializes AINSER driver //! Should be called from Init() during startup //! \param[in] mode currently only mode 0 supported //! \return < 0 if initialisation failed ///////////////////////////////////////////////////////////////////////////// s32 AINSER_Init(u32 mode) { s32 status = 0; int module, pin; // currently only mode 0 supported if( mode != 0 ) return -1; // unsupported mode #if AINSER_SPI_OUTPUTS_OD // pins in open drain mode (to pull-up the outputs to 5V) status |= MIOS32_SPI_IO_Init(AINSER_SPI, MIOS32_SPI_PIN_DRIVER_STRONG_OD); #else // pins in push-poll mode (3.3V output voltage) status |= MIOS32_SPI_IO_Init(AINSER_SPI, MIOS32_SPI_PIN_DRIVER_STRONG); #endif // extra CS pin #if AINSER_NUM_MODULES >= 3 MIOS32_BOARD_J10_PinInit(14, MIOS32_BOARD_PIN_MODE_OUTPUT_OD); #endif // SPI Port will be initialized in AINSER_Update() num_used_modules = AINSER_NUM_MODULES; #if AINSER_NUM_MODULES > 8 # error "If more than 8 AINSER_NUM_MODULES should be supported, the ainser_enable_mask variable type has to be changed from u8 to u16 (up to 16) or u32 (up to 32)" #endif #if AINSER_NUM_MODULES > 8 # error "If more than 8 AINSER_NUM_MODULES should be supported, the ainser_muxed_mask variable type has to be changed from u8 to u16 (up to 16) or u32 (up to 32)" #endif for(module=0; module<AINSER_NUM_MODULES; ++module) { num_used_pins[module] = AINSER_NUM_PINS; // ensure that CS is deactivated AINSER_SetCs(module, 1); AINSER_EnabledSet(module, 1); AINSER_MuxedSet(module, 1); AINSER_NumPinsSet(module, AINSER_NUM_PINS); AINSER_DeadbandSet(module, MIOS32_AIN_DEADBAND); // clear all values for(pin=0; pin<AINSER_NUM_PINS; ++pin) { ain_pin_values[module][pin] = 0; } previous_ain_pin_value = 0; } return status; } ///////////////////////////////////////////////////////////////////////////// //! \return the number of modules which are scanned ///////////////////////////////////////////////////////////////////////////// s32 AINSER_NumModulesGet(void) { return num_used_modules; } ///////////////////////////////////////////////////////////////////////////// //! Sets the number of modules which should be scanned //! \return < 0 on error (e.g. unsupported number of modules) ///////////////////////////////////////////////////////////////////////////// s32 AINSER_NumModulesSet(u8 num_modules) { if( num_modules >= AINSER_NUM_MODULES ) return -1; num_used_modules = num_modules; return 0; // no error } ///////////////////////////////////////////////////////////////////////////// //! \return the enable mask for modules which should be scanned ///////////////////////////////////////////////////////////////////////////// s32 AINSER_EnabledGet(u8 module) { if( module >= AINSER_NUM_MODULES ) return 0; return (ainser_enable_mask & (1 << module)) ? 1 : 0; } ///////////////////////////////////////////////////////////////////////////// //! Sets the enable mask for modules which should be scanned ///////////////////////////////////////////////////////////////////////////// s32 AINSER_EnabledSet(u8 module, u8 enabled) { if( module >= AINSER_NUM_MODULES ) return -1; // invalid module if( enabled ) ainser_enable_mask |= (1 << module); else ainser_enable_mask &= ~(1 << module); return 0; // no error } ///////////////////////////////////////////////////////////////////////////// //! \retval 0 if 1-to-8 multiplexers disabled for the given module //! \retval 1 if 1-to-8 multiplexers enabled for the given module (default) ///////////////////////////////////////////////////////////////////////////// s32 AINSER_MuxedGet(u8 module) { if( module >= AINSER_NUM_MODULES ) return 0; return (ainser_muxed_mask & (1 << module)) ? 1 : 0; } ///////////////////////////////////////////////////////////////////////////// //! Enables/disables the 1-to-8 multiplexer handling.\n //! Use muxed=0 for AINSER8 module, and muxed=1 for AINSER64 module (default) ///////////////////////////////////////////////////////////////////////////// s32 AINSER_MuxedSet(u8 module, u8 muxed) { if( module >= AINSER_NUM_MODULES ) return -1; // invalid module if( muxed ) ainser_muxed_mask |= (1 << module); else ainser_muxed_mask &= ~(1 << module); return 0; // no error } ///////////////////////////////////////////////////////////////////////////// //! \return the number of AIN pins per module which are scanned ///////////////////////////////////////////////////////////////////////////// s32 AINSER_NumPinsGet(u8 module) { if( module >= AINSER_NUM_MODULES ) return 0; // invalid module (return 0 pins) return num_used_pins[module]; } ///////////////////////////////////////////////////////////////////////////// //! Sets the number of AIN pins per module which should be scanned //! \return < 0 on error (e.g. unsupported number of pins) ///////////////////////////////////////////////////////////////////////////// s32 AINSER_NumPinsSet(u8 module, u8 num_pins) { if( module >= AINSER_NUM_MODULES ) return -1; // invalid module if( num_pins > AINSER_NUM_PINS ) return -2; num_used_pins[module] = num_pins; return 0; // no error } ///////////////////////////////////////////////////////////////////////////// //! \return the deadband which is used to notify changes //! \return < 0 on error ///////////////////////////////////////////////////////////////////////////// s32 AINSER_DeadbandGet(u8 module) { if( module >= AINSER_NUM_MODULES ) return 0; // invalid module (return 0) return ain_deadband[module]; } ///////////////////////////////////////////////////////////////////////////// //! Sets the difference between last and current pot value which has to //! be achieved to trigger the callback function passed to AINSER_Handler() //! \return < 0 on error ///////////////////////////////////////////////////////////////////////////// s32 AINSER_DeadbandSet(u8 module, u8 deadband) { if( module >= AINSER_NUM_MODULES ) return -1; // invalid module ain_deadband[module] = deadband; return 0; // no error } ///////////////////////////////////////////////////////////////////////////// //! \return the AIN pin value of the given module and pin //! \return < 0 if wrong module or pin selected! ///////////////////////////////////////////////////////////////////////////// s32 AINSER_PinGet(u8 module, u8 pin) { if( module >= AINSER_NUM_MODULES ) return -1; if( pin >= AINSER_NUM_PINS ) return -1; return ain_pin_values[module][pin]; } ///////////////////////////////////////////////////////////////////////////// //! \return the previous value of the pin which has triggered the NotifyChanged hook.\n //! Only valid when function is called from this hook! ///////////////////////////////////////////////////////////////////////////// s32 AINSER_PreviousPinValueGet(void) { return previous_ain_pin_value; } ///////////////////////////////////////////////////////////////////////////// //! This function should be periodically called to scan AIN pin changes. //! //! A scan of a single multiplexer selection takes ca. 50 uS on a LPC1769 with MIOS32_SPI_PRESCALER_8 //! //! Whenever a pin has changed, the given callback function will be called.\n //! Example: //! \code //! void AINSER_NotifyChanged(u32 pin, u16 value); //! \endcode //! \param[in] _callback pointer to callback function //! \return < 0 on errors ///////////////////////////////////////////////////////////////////////////// s32 AINSER_Handler(void (*_callback)(u32 module, u32 pin, u32 value)) { // the mux_ctr -> pin mappin is layout dependend //const u8 mux_pin_map[8] = {0, 1, 2, 3, 4, 5, 6, 7 }; //const u8 mux_pin_map[8] = {1, 4, 3, 5, 2, 7, 0, 6 }; // reversed pins const u8 mux_pin_map[8] = {6, 3, 4, 2, 5, 0, 7, 1 }; // order of MUX channels static u8 mux_ctr = 0; // will be incremented on each update to select the next AIN pin static u8 first_scan_done = 0; static u16 link_status_ctr = 0; s32 status = 0; // init SPI port for fast frequency access // we will do this here, so that other handlers (e.g. AOUT) could use SPI in different modes // Maxmimum allowed SCLK is 2 MHz according to datasheet // We select prescaler 64 @120 MHz (-> ca. 500 nS period) status |= MIOS32_SPI_TransferModeInit(AINSER_SPI, MIOS32_SPI_MODE_CLK0_PHASE0, MIOS32_SPI_PRESCALER_64); // determine next MUX selection int next_mux_ctr = (mux_ctr + 1) % 8; // link LED will flash with PWM effect ++link_status_ctr; const u32 pwm_period = 20; // *1 mS -> 20 mS const u32 pwm_sweep_steps = 100; // *20 mS -> 2000 mS u32 pwm_duty = ((link_status_ctr / pwm_period) % pwm_sweep_steps) / (pwm_sweep_steps/pwm_period); if( (link_status_ctr % (2*pwm_period*pwm_sweep_steps)) > pwm_period*pwm_sweep_steps ) pwm_duty = pwm_period-pwm_duty; // negative direction each 20*25 ticks u32 link_status = ((link_status_ctr % pwm_period) > pwm_duty) ? 1 : 0; // loop over connected modules int module; u32 module_mask = 1; for(module=0; module<num_used_modules; ++module, module_mask <<= 1) { if( !(ainser_enable_mask & module_mask) ) continue; u8 muxed = ainser_muxed_mask & module_mask; // loop over channels int chn; for(chn=0; chn<8; ++chn) { // CS=0 status |= AINSER_SetCs(module, 0); // retrieve conversion values // shift in start bit + SGL + MSB of channel selection, shift out dummy byte MIOS32_SPI_TransferByte(AINSER_SPI, 0x06 | (chn>>2)); // shift in remaining 2 bits of channel selection, shift out MSBs of conversion value u8 b1 = MIOS32_SPI_TransferByte(AINSER_SPI, chn << 6); // shift in mux_ctr + "Link LED" status to 74HC595, shift out LSBs of conversion value u8 b2 = MIOS32_SPI_TransferByte(AINSER_SPI, ((chn == 7 ? next_mux_ctr : mux_ctr) << 5) | link_status); // CS=1 (the rising edge will update the 74HC595) AINSER_SetCs(module, 1); // store conversion value if difference to old value is outside the deadband u16 pin = muxed ? (mux_pin_map[mux_ctr] + 8*(7-chn)) : (7-chn); // the mux/chn -> pin mapping is layout dependend u16 value = (b2 | (b1 << 8)) & 0xfff; previous_ain_pin_value = ain_pin_values[module][pin]; int diff = value - previous_ain_pin_value; int abs_diff = (diff > 0 ) ? diff : -diff; if( !first_scan_done || abs_diff > ain_deadband[module] ) { ain_pin_values[module][pin] = value; // notify callback function // check pin number as well... just to ensure if( first_scan_done && _callback && pin < num_used_pins[module] ) _callback(module, pin, value); } } } // select MUX input mux_ctr = next_mux_ctr; // one complete scan done? if( next_mux_ctr == 0 ) first_scan_done = 1; return 0; // no error } ///////////////////////////////////////////////////////////////////////////// // Internal function to set CS line depending on module ///////////////////////////////////////////////////////////////////////////// static s32 AINSER_SetCs(u8 module, u8 value) { switch( module ) { case 0: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE1, value); // spi, rc_pin, pin_value case 1: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE2, value); // spi, rc_pin, pin_value case 2: return MIOS32_BOARD_J10_PinSet(14, value); #if AINSER_NUM_MODULES > 3 # error "CS Line for more than 3 modules not prepared yet - please enhance here!" #endif } return -1; } //! \} and in mios32_config.h I set #define AINSER_NUM_MODULES 3 So, it should be exactly the same as in TKs branch.
Antichambre Posted August 19, 2019 Posted August 19, 2019 ok. And physically, did you check the cs lines with the oscillo? you should see a periodic pulse.
FantomXR Posted August 19, 2019 Author Posted August 19, 2019 Yes. I did. I see the pulses on the CS line.
FantomXR Posted August 20, 2019 Author Posted August 20, 2019 Ah, no. It's SMD soldered. So, traces are given. But I double-checked the schematic and all looks well. Here is the excerpt from the PCB layout: Pin 6 of the connector comes from PE6 of the STM. The rest is the same as on the other MCP.
FantomXR Posted August 26, 2019 Author Posted August 26, 2019 Okay. I tried with a MIDIbox Core. Same: It's not working. Nothing happens... any help on this?!
