Hey people,
I have a strange problem. I have a PCB with 9 encoders. This PCB is connected to another PCB with 27 switches. In total there are 8 SR. 4 on the button-PCB and 4 on the encoder PCB. Everything works fine except the very last encoder. The encoder is connected to pin4 and pin5 of the HC165. MIOS Studio shows fine that it toggles input 62 and 63 and depending on the direction the encoder is moved, either 62 or 63 will get triggered first. So this seems to be correct. In the NGC I wrote
ENC n=9 sr=8 pins=6:5 type=detented1
But for some reason NG doesn't take those events as encoder events. This is the output of the terminal:
[1406781.497] MBNG_DIN_NotifyToggle(62, 1)
[1406781.497] No event assigned to BUTTON hw_id=62
[1406781.503] MBNG_DIN_NotifyToggle(63, 1)
[1406781.503] No event assigned to BUTTON hw_id=63
[1406781.654] MBNG_DIN_NotifyToggle(62, 0)
[1406781.654] No event assigned to BUTTON hw_id=62
[1406781.662] MBNG_DIN_NotifyToggle(63, 0)
[1406781.662] No event assigned to BUTTON hw_id=63
But it should like this (just with another id though):
[1406866.814] MBNG_ENC_NotifyChange(7, 1)
[1406866.814] No event assigned to ENC hw_id=7
[1406867.121] MBNG_ENC_NotifyChange(7, 1)
[1406867.121] No event assigned to ENC hw_id=7
[1406867.446] MBNG_ENC_NotifyChange(7, 1)
[1406867.446] No event assigned to ENC hw_id=7
[1406867.747] MBNG_ENC_NotifyChange(7, 1)
[1406867.747] No event assigned to ENC hw_id=7
Any ideas? I use the stock NG-firmware for this test. I've also tested to set pins=6:5 to all another combination like 4:5, 6:7, etc. But none of them works.
Thank you very much!
Best,
Chris
Edited by FantomXR
I just see that MIOS Studio gives me an error message:
[1416035.046] [MBNG_FILE_C:303] ERROR: invalid pins for ENC n=9 ... pins=5
[1416035.046] [MBNG_FILE_C:303]        (expecting 0:1, 1:0, 2:3, 3:2, 4:5, 5:4, 6:7 or 7:6)
I thought that this isn't relevant. So it seems I need to change the wiring :-(
btw.: @TK. I can not find the code for the different detented-types in the firmware. In which file are they defined?
I ask because it seems that my encoders don't work properly. I use PEC11L from Bourns:
https://www.bourns.com/PDFs/pec11l.pdf
I use them in relative mode. CW 1, CCW 127. When turning fast CW I also get 127 from now to then. So it seems to bounce...
cant speak for MB NG... but
http://www.midibox.org/mios32/manual/mios32__enc_8h.html#aee5965aaa49ffc200ccb21763546635c
http://www.midibox.org/mios32/manual/group___m_i_o_s32___e_n_c.html#gac8d4a1c02157a171de0059047a99c815
Quote
DISABLED
NON_DETENTED
DETENTED1
DETENTED2
DETENTED3
DETENTED4
DETENTED5
found in /home/inet-stick/midibox/mios32/trunk/mios32/common/mios32_enc.c
how many pulses a detended type have?  i remember in the forum there was a question about alps types... cant find it right now...
Edited by Phatline
Hm, thanks for your help. Detented5 seems to work best. But not perfect though. Still it's jumping from now to then.
But there must be some kind of code where those detent-modes are defined. And I can't find it.
Some of mine were jittery as hell. I opened them up and cleaned them with isopropyl and the brass contacts. There was far too much grease in them. All good now with a tiny bit of Teflon grease at the shaft point. No more jitters
Take a look in mios32/common/mios32_enc.c - the "state machine" code is in MIOS32_ENC_UpdateStates(), there you should find the logic.
You could also try to swap around pins 2 and 3 of the encoder, had to do this a while back for smaller 12mm ALPS encoders to work properly, otherwise would observe random jumps, back then the wiring was incorrect, as i installed 12mm Alps STEC encoders in 16mm encoder slots :).
Have a good weekend!
Peter
Peter
Well that is due to a different pinout if STEC12 and 16. On 12 the C terminal is in the middle while it's on the outside on 16 iirc.
I'll check again and report back.
I think I'll try to add capacitors to pins A and B since this is the fastest fix I could do.
In the long run I'll change the layout, adding caps to ground and two 10k resistors as in the datasheet + 74HC14 to create nice and sharp results.
