TK. Posted May 2, 2005 Report Share Posted May 2, 2005 New design from Finland! :)Jurbo wrote:Some details:- 2 x SID 8580, two more will fit into the case if needed- Measures 255 x 210 x 85 mm, weighs 2,4 kg- Case hand built from 1 mm stainless steel- Parts attached to case by gluing plastic sheets and rails to the steel case, parts screwed to the plastic- Case markings done with a vinyl cutter- 2x20 lcd and modules as kits from Claudia- Push buttons, encs and leds from Voti- Filter joystick from Elfa- Enc knobs from Farnell- Uses C64 PSU- Built between August 2004 and April 2005 with a slow and unsteady pace- Build time around 100 hours- Parts cost 400 euros- Planned upgrades: expression pedalThank you Thorsten for making this instrument possible, as I have loved the SID sound since childhood and have always thought how cool it would be to actually play the chip with my own hands. Now I have a beautiful synthesizer module sitting on top of my Korg X2 pushing out those lovely sounds. Thank you! Quote Link to comment Share on other sites More sharing options...
Steven_C Posted May 4, 2005 Report Share Posted May 4, 2005 treasure! :o Quote Link to comment Share on other sites More sharing options...
ma9 Posted May 4, 2005 Report Share Posted May 4, 2005 se on hyvä! ;) Quote Link to comment Share on other sites More sharing options...
MMorph Posted May 4, 2005 Report Share Posted May 4, 2005 Quite nice looking thing, good job! The joystick is neat idea but how useful is it? It appears that there are few of these implementations done in past as well.Regards, Petri Quote Link to comment Share on other sites More sharing options...
Jurbo Posted May 4, 2005 Report Share Posted May 4, 2005 Thanks, guys! 8)@ Meta: About the filter joystick - yep, it's not all that original, and I couldn't have implemented it in the first place without the help from the people who had done it earlier, that's for sure... Why I just had to have it - coming from guitar background, I just knew from the start that I wanted something like a wah pedal at my fingertips (now that I think of it - I could wire a connector for a filter cutoff pedal...). It sounds very cool to play an arpeggiated chord and spice the treble end up by tiny realtime adjustments of cut/res on the stick. Adds a lot of expressiveness. I could play a single chord for hours, just wiggling the stick listening to the beautiful little alterations in the sound. ;D And I built my box mostly for realtime playing, expecting not so much use connected to sequencers and such. I'm happy with the stick, but sure, it might not be very useful for everybody. :) Quote Link to comment Share on other sites More sharing options...
MMorph Posted May 5, 2005 Report Share Posted May 5, 2005 Maybe I have to give it a try as well! I know there are synthesizers with similar joystick implemented but I have never had chance to use one. Without knowing any better I've always been just happy with all these knobs and clutches. ;D However I think that top priority thing is to get everything into box now instead of my desk. I just haven't made up my mind on certain decisions and this could be one more thing to try at.Regards, Petri Quote Link to comment Share on other sites More sharing options...
mr_chombee Posted May 5, 2005 Report Share Posted May 5, 2005 the box looks beautiful. can you send the joystick data to the midi out port? and how have you done the case markings? (what is a vinyl cutter?) Quote Link to comment Share on other sites More sharing options...
Jurbo Posted May 5, 2005 Report Share Posted May 5, 2005 @ Mr Chombee: I don't know about the joystick data being sent out, but I suppose it should be possible if it already isn't working. After all, the analog signal from the pot is turned into digital data on the PIC, so it should be "just" a matter of programming. :PA vinyl cutter is a computer controlled machine that cuts images or text or whatever on a sheet of thin adhesive vinyl with a tiny blade. After cutting, you manually dig or weed away the parts of the vinyl you don't want on the design. Then you stick the weeded design to the target surface with the help of transfer tape (a bit like masking tape but as a sheet of suitable size). So basically the lettering on my MBSID is tiny letters that are cut out of adhesive tape. Seems to be durable, but it's possible to scrape it away using your fingernails with some force. And you can't do as small letters as you can with some other methods. But it seems to work just fine for me! Quote Link to comment Share on other sites More sharing options...
Jidis Posted May 6, 2005 Report Share Posted May 6, 2005 I was going to ask about that lettering as well. Great looking box by the way! I've gotten some OK results on metal with the toner transfer method described at http://www.fullnet.com/u/tomg/gooteepc.htmIt's not as consistent as doing the boards, but it looks like it works for certain things. I recently tried to re-label the control panel on my kitchen stove, which looks like a similar surface to Jurbo's box. I got about 95% of the label on, but kept peeling off corners and stuff. You can rub away failed attempts and retry. If (or when) I get them on there, I'm going to try to mist them with some light coats of clear acrylic or something. That may be enough protection against the "scratchability" problem. Quote Link to comment Share on other sites More sharing options...
mesak Posted August 17, 2005 Report Share Posted August 17, 2005 A vinyl cutter is a computer controlled machine that cuts images or text or whatever on a sheet of thin adhesive vinyl with a tiny blade. After cutting, you manually dig or weed away the parts of the vinyl you don't want on the design. Then you stick the weeded design to the target surface with the help of transfer tape (a bit like masking tape but as a sheet of suitable size). So basically the lettering on my MBSID is tiny letters that are cut out of adhesive tape. Seems to be durable, but it's possible to scrape it away using your fingernails with some force. And you can't do as small letters as you can with some other methods. But it seems to work just fine for me!hi jurbo! where did you make it or do you have a access to use such machine by your self? (you're from finland, right?)peace Quote Link to comment Share on other sites More sharing options...
Jurbo Posted September 13, 2005 Report Share Posted September 13, 2005 From Finland, yes...I work in advertising / signmaking / decoration so we use a cutter all the time at work. Cutters use vector graphics as cutting paths so if you want to try the method, find a local signmaker's and ask what kind of file format they can use.I'm happy about using the method, but I used it mainly because I had easy access to it. Otherwise I probably would have done it some other way (printing and many other methods will surely be less work and cheaper, too). Quote Link to comment Share on other sites More sharing options...
ringmod45 Posted October 22, 2005 Report Share Posted October 22, 2005 Hi Jurbo,Great design and execution.I will be modelling my sid after your set of functions. I have a silly , could you please describe the functions of the 4buttons to the left of the rotary pot below the lcd diplay?Many thanks, I am in the planing stages fro the layout the sid module.Regards,Ringmod45 Quote Link to comment Share on other sites More sharing options...
Jurbo Posted November 18, 2005 Report Share Posted November 18, 2005 @ Ringmod45 - thanks a lot!The three extra buttons (the one next to the encoder is the menu return button) don't do anything right now, but they can be wired and programmed for extra functions. I basically added them for future expandability and cosmetics. But, as Thorsten has said, he will be making future changes to MBSID application in such a way that the default control surface will need no changes. So it's up to me to change the application if I want to use the extra buttons - they probably won't be seeing much use... ;D Quote Link to comment Share on other sites More sharing options...
euphoricgrey Posted February 7, 2007 Report Share Posted February 7, 2007 what mm leds should i use? Quote Link to comment Share on other sites More sharing options...
stryd_one Posted February 8, 2007 Report Share Posted February 8, 2007 Is it just me or did the pic disappear? Quote Link to comment Share on other sites More sharing options...
Lall Posted February 8, 2007 Report Share Posted February 8, 2007 It's for me as well :(Given the comments above, I can hardly stand waiting to them...Bring back the pics, bring back the pics!! :D Lall Quote Link to comment Share on other sites More sharing options...
stryd_one Posted February 8, 2007 Report Share Posted February 8, 2007 Yeh a friend of mine told me recently that she has access to a vinyl cutter, and I had been thinking about using it for labels or for masking out airbrushing/spraypainting, so I am just dying to see those pics! Quote Link to comment Share on other sites More sharing options...
Wild_Weasel Posted February 8, 2007 Report Share Posted February 8, 2007 Where is the pic??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ???#Oh. This post is from 2005. Quote Link to comment Share on other sites More sharing options...
stryd_one Posted February 8, 2007 Report Share Posted February 8, 2007 Hah nicely spotted... euphoricgrey has been away for a year and suddenly comes back and posts in a year old post... did you get abducted by aliens or something man? maybe that's what the nick means? ;)Edit fixed links Quote Link to comment Share on other sites More sharing options...
dj3nk Posted February 8, 2007 Report Share Posted February 8, 2007 just lol 2005 :D Quote Link to comment Share on other sites More sharing options...
Jurbo Posted February 19, 2007 Report Share Posted February 19, 2007 Heh, it's nice to see my box getting some attention again! Not that there's much going on with it, just some occasional, pleasurable jamming.Euphoricgrey - Don't know what size leds you SHOULD use, but I used 3 mm ones. ;D Quote Link to comment Share on other sites More sharing options...
