bosone Posted December 23, 2004 Report Share Posted December 23, 2004 only two patch submissions?! ???what are the other midiboxer doing!?anyway, thansk to thorsten for his continuous work!! ;D Quote Link to comment Share on other sites More sharing options...
pay_c Posted December 23, 2004 Report Share Posted December 23, 2004 Still takes it time, I know... I *will* send some (not many anyhow), but when? ..... ..... :-[ Quote Link to comment Share on other sites More sharing options...
Stigmata Posted December 23, 2004 Report Share Posted December 23, 2004 NICE PATCHES!!! ;DChristoffer Quote Link to comment Share on other sites More sharing options...
js Posted December 23, 2004 Report Share Posted December 23, 2004 hmmm seems like TK email doesn´t like mine, Ãll try again for the next collection then...js Quote Link to comment Share on other sites More sharing options...
Twin-X Posted December 30, 2004 Report Share Posted December 30, 2004 Thanks Thorsten! This looks great gonna apply it soon.1 thing in your next update could you consider a "create random patch" function.I am a bit lazy ;) Quote Link to comment Share on other sites More sharing options...
Julian Posted January 13, 2005 Report Share Posted January 13, 2005 i'll donate some patches as well, but first i need a new PSU (already ordered) for my SID to select wich of the patches it'll be ;)best,julian Quote Link to comment Share on other sites More sharing options...
TK. Posted January 15, 2005 Report Share Posted January 15, 2005 Fine - I'm still open to new patches. In the meantime I found the patches of js in my spamfolder (unfortunately this can happen from time to time). I will upload an incomplete second bank soon which will have enough slots for your future contributionsBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
TK. Posted April 14, 2005 Report Share Posted April 14, 2005 I'm planning to do a service update for MBSID V1.7 with following bug fixes:patch name editor bugfix for 2x16 displaysavoid crash on maximum WT rateProper handling of SusKey (automatic portamento) when Legato is active at the same timeAre there any other imperfections which need to be fixed?Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
TK. Posted April 16, 2005 Report Share Posted April 16, 2005 MIDIbox SID V1.7a can now be downloaded from http://www.ucapps.de/mios_download.htmlFixed bugs:patch name editor bugfix for 2x16 displaysavoid crash on maximum WT rateProper handling of SusKey (automatic portamento) when Legato is active at the same timeNew feature: o there is now a 6th LFO waveform which forwards analog conversion results from the first 6 analog inputs (J5 port of the core module) to the LFOs. This allows you to control the SID with analog signals The LFO Depth controls the impact on the modulation target The LFO Rate controls the update cycle - a lower rates result to very stuttering effects, the highest rate (127 -> 812 uS sample period) to a very accurate control of Frequencies/Pulsewidths/Filter Thinkable analog sources are pots, joysticks, CV outs, ...[/code]Have some analog fun! :)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
airmailed Posted April 19, 2005 Report Share Posted April 19, 2005 looks good... thanks thorsten, i think this means 3 or 4 pots on my sid, an expression pedal socket and a cv input, i have been wanting more controls like this but didn't want to build the full cs because of the cost... i started soldering today, i have only destroyed one pad through overheating on the optocoupler socket, i think this will be the slave board now ;-) and i should take great care soldering the other core...all the bestadam Quote Link to comment Share on other sites More sharing options...
tatapoum Posted May 21, 2005 Report Share Posted May 21, 2005 Thorsten,Actualy designing a complete SidBox, does this new functionnality with the sixth LFO impact the front panel design ?Should I add an input in the front ?One last question, from all SidBoxer experience, what is interesting to assign to the assignable encoders ? I don't want to write "Assign #1" on the front panel. The assigned controlers are fixed in the code, so they can't be modified without compiling the code ?Thank you for your help.ludo Quote Link to comment Share on other sites More sharing options...
TK. Posted May 21, 2005 Report Share Posted May 21, 2005 Hi Ludo,Actualy designing a complete SidBox, does this new functionnality with the sixth LFO impact the front panel design ?Should I add an input in the front ?the official release doesn't use an additional LED for the 6th LFO waveform, the "Random" and "Sine" LED will lit at the same time to notify this, and this should be okJust keep in mind that I would never change my own frontpanel, therefore you can be sure that the original design will always workBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
tatapoum Posted May 23, 2005 Report Share Posted May 23, 2005 Hi Thorsten,Thank you for your answer.However, what about Assign #n ? Is it set in the code ? What typical function can be assign to ? I parse the SID web pages without finding any details about that. And the source code didn't learn me a lot.ludo Quote Link to comment Share on other sites More sharing options...
TK. Posted May 23, 2005 Report Share Posted May 23, 2005 Hi Ludo,However, what about Assign #n ? Is it set in the code ? What typical function can be assign to ? I parse the SID web pages without finding any details about that. And the source code didn't learn me a lot.The assign function is a typical feature which has been requested by somebody, that I've implemented in an extreme flexible way to meet all possible needs, but which is in fact very rarely used (otherwise you would get an answer from people who like this feature).The upper assigns are sending CCs at channel #16, you can control functions of your host sequencer with themThe lower assigns can be used to control the 5 visible menu parameters directly (a very powerfull feature, especially when WT sequences are edited)However, this feature is full configurable. See cs_menu_enc_table.incYou can send CCs at any channel, relative MIDI events (e.g. to software from Native Instruments like Reaktor to control external effects), you can change any SID parameter, switch to menus automatically or not, or (as mentioned) you can change the visible menu parameters directly.Not sure which individual setting you would prefer, I use the default setupBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
tatapoum Posted May 23, 2005 Report Share Posted May 23, 2005 Ok, thanks Torsten !The only problem is that I never remind what is behind Assign or F1, F2, ... on my Seq.ludo Quote Link to comment Share on other sites More sharing options...
