TK. Posted April 9, 2006 Report Posted April 9, 2006 After a lot of beta testing (which was hopefully enough) I just have released MIOS V1.9See the ChangeLog for details:http://www.ucapps.de/mios_changelog.htmlThe biggest benefit of the changes: more memory free for applications -> more features! :-)An update to the new MIOS and Bootloader version is strongly recommented, since newer releases of MIDIbox SID/SEQ/FM/64/64E won't be compatible to MIOS V1.8 and lower!!! They will get use of the upper 1k block, which was allocated by bootloader V1.1b beforeIn addition, following programs have been updated:skeleton_v1_9: contains new copyright messagesdcc_skeleton_v1_9: contains new copyright message, function declaration for MIOS_IIC_SendByte changedchange_id_v1_9: allows to change the MBHP_IIC_MIDI ID in the ID headermidi_router_v1_0: the MIDI router project, which is unfortunately not documented yet, but which runs stable since weeks. :) It could also be interesting as example, how to combine C and assembly codeBest Regards, Thorsten.
stryd_one Posted April 9, 2006 Report Posted April 9, 2006 AWESOME!!! In awe of your work as always :D[glow=red,2,300]THANKS TK!![/glow]Edit: WOW wow WOW I've just read a bit and WOW TK you really have been busy!
Tanstaafl Posted April 9, 2006 Report Posted April 9, 2006 YOU ROCK, TK!!!now i just need to update my 5 or 6 cores.... grrrrrr :)thanx,gb
drin Posted April 9, 2006 Report Posted April 9, 2006 Just finished reading the changelog - this is GREAT!Thanks TK! As always, amazing work!-drin
ilmenator Posted April 9, 2006 Report Posted April 9, 2006 Thanks,now I know what I am going to do in my Easter holidays... ;DBest regards, ilmenator
audiocommander Posted April 9, 2006 Report Posted April 9, 2006 wow,the c function reference addition is also very welcome!Thanks TK!! :)
moxi Posted April 11, 2006 Report Posted April 11, 2006 i've burned the new bootstrap on a fresh PIC and uploaded the new mios without problems.great thanks TK!
Jaicen Posted April 13, 2006 Report Posted April 13, 2006 I guess the burning question here is, will SmashTV now be including MIOS 1.9 on his pre-burned pics??
smashtv Posted April 13, 2006 Report Posted April 13, 2006 I guess the burning question here is, will SmashTV now be including MIOS 1.9 on his pre-burned pics??Yes. :)
Twin-X Posted April 13, 2006 Report Posted April 13, 2006 huh? I thought you only had the bootloader on it?Impressive customer support ;)
smashtv Posted April 13, 2006 Report Posted April 13, 2006 huh? I thought you only had the bootloader on it?Impressive customer support ;)Whoops I mis-spoke, I meant the chips will have the new bootloader only.Reason: If a builder can't get MIOS loaded, not too likely to get an app loaded either etc.... Best to get the MIDI ports to a known-working state early on, MIOS pre-loaded would make that process harder. ;)Best!Smash
OrganGrinder Posted May 22, 2006 Report Posted May 22, 2006 Reason: If a builder can't get MIOS loaded, not too likely to get an app loaded either etc.... Best to get the MIDI ports to a known-working state early on, MIOS pre-loaded would make that process harder. Winkthis i agree with,, as murphy said "a $3000 picture tube with save a 1/2 cent fuse by blowing first"
goule Posted August 23, 2006 Report Posted August 23, 2006 Is there a way to know wich version of the bootloader is installed ?
TK. Posted August 23, 2006 Author Report Posted August 23, 2006 It's described in the READMEif you want to determine it from the program side, just do a table read at 0x404, if the two bytes are 0x11, 0x47, bootloader v1.2 is installedBest Regards, Thorsten.
