/tilted/ Posted November 14, 2007 Posted November 14, 2007 That is good idea. If 1 picture = 1000 words then just 1 sec of motion picture should weight 25 000 words!!! (if frame rate is 25pps) ;DAnd even a webcam should be worth a couple of thousand words per second!!
stryd_one Posted November 14, 2007 Posted November 14, 2007 Here ya go Wilba, now you can keep posting :)tilt: I'm on a 1MB uplink so it's actually not too bad :)
Wilba Posted November 14, 2007 Posted November 14, 2007 I forgot to thank you TK for sharing these patches and workflow... I am a happy n00b now!
Goblinz Posted November 14, 2007 Posted November 14, 2007 I'm deleting my old posts so I can post new ones and stay on 1000 posts. Now that's lame. *whack* That' only 8 in binary though! ;D
bugfight Posted November 14, 2007 Posted November 14, 2007 That' only 8 in binary though! ;Di like showing 132 in binary with my fingers...*whack*
suital Posted November 14, 2007 Posted November 14, 2007 i like showing 132 in binary with my fingers...*whack*;D
Goblinz Posted November 16, 2007 Posted November 16, 2007 I completely forgot that this thing had a little sequencer built in to it. Do you have to hand code the sequences or is there a nice GUI that will produce them? I would be good if if there was something like a recorder setting, or a recorder app to run on a pc... So you could play a sequence on a midi keyboard and then then it could be recorded on the MDSID or a PC app could do the same but output the code to upload to a bankstick. It's times like this when I wish I could code.... going to start learning C in the new year after I've built the thing and have some spare time again. G
jovius Posted November 18, 2007 Posted November 18, 2007 love the sound tk and thanks for all the work you do with the midbox just wondering what the controller keyboard with the pads islooks relay handy
nILS Posted November 18, 2007 Posted November 18, 2007 just wondering what the controller keyboard with the pads islooks relay handyIt's a KORG microKONTROL
TK. Posted November 20, 2007 Author Posted November 20, 2007 I completely forgot that this thing had a little sequencer built in to it. Do you have to hand code the sequences or is there a nice GUI that will produce them?There is a nice inbuilt bassline and drum editor in the MIDIbox SID (control surface required).Of course, an external GUI, running on a computer, would be a good alternative solution. The basics are there (full access to sequences via SysEx), but an external editor software is not available yet...I would be good if if there was something like a recorder setting, or a recorder app to run on a pc... So you could play a sequence on a midi keyboard and then then it could be recorded on the MDSID or a PC app could do the same but output the code to upload to a bankstick. It's times like this when I wish I could code.... going to start learning C in the new year after I've built the thing and have some spare time again.A step sequencer is not a common MIDI sequencer - especially because of the quantisation.Best Regards, Thorsten.
