Zam
625 -
26
Everything posted by Zam
That's promising... is this new work around mios32 or did I miss this time ago ? I'm in standby right now with all this (my fader automation, which work great by the way...) and busy at the studio, but definitely interested... I'll come back to you when I have time, and if I'm not able to build mios32 by myself with all info at your link ! Best Zam ps: how is the physical wiring around J18 for two or more cores ?
Ok, what i suppose is possible :) Alternate mios32 to flip I2C to extra uart midi I/O is fine I don't use optocoupler, but direct J11 connection (at 10x midi speed) in a design where 3 core (later 4) are linked together Your design can potentially reduce a lot of space if I want to fit everything in a one U rack (now it's a 3U...) Best Zam
Hello Very interesting compact design ! Is there a way to have 4 midi IO with this 64pin version ? Best Zam
Ok... I'm not aware that you can define the midi note from an event... maybe try with a delay (1ms) just before looping the section with exec_meta command. What the debug say before the crash ? Best Zam
Theses two line are not valid ! check manual for -send- command best Zam
No you can only load a full set of files (NGC,NGR etc...) BUT i think you can trick this by having twice the same .NGC (with different name according to .NGR) Not sure it's the reason, but you don't define any note, so maybe default is C-2, try with note=all Best Zam
You can forward any event to any event, but I don't get the second part of your question, LED with different lit depending of value ? Only one fwd_id allowed, you should forward to a sender and duplicate this sender (same hw_id different id) each one sending/forwarding to a different led. Or you use meta runscript and then do your forwarding/conditional at NGR. Best Zam
Hello Out of idea right now... just make sure if your led:3228 is used for other function that it's value is not different from 0 or 127. Best Zam
Hello As I say, you can't modify the 32ch HUI limitation in PT You should be able to control way more channels in PT from your desk (remote) by using the fader bank Still I don't know how it react with 32 channels, dose the flip go per 8 meaning 1 to 32 then 9 to 40 etc... Or flip per 32, 1 to 32 then 33 to 64, you have to try. Anyway this will not be bidirectional. if you flip let say from 1-32 to 33-64, your first console channel no longer link to first PT channel which might be a problem in your use case as I understand it now. In fact the question is, do you need desk analog channel to be locked to the same PT channel all the time ? Ok, so you already hook the VCAs ? About protocol... In PT you have no options, HUI is 4, EuCon I don't know, but you won't get the protocol spec... In DP I'm able to use as many MCU modules as I want. Best Zam
Hi Ok... I was thinking you where stuck with 8, so I give a solution for 32 (max allowed simultaneously) You should be able to bank channels (zone 0a) to swap per 8 BUT in your specific use case where analog hardware can't be "relative" channel as it physically link audio to the channel you have no solution, except using a DAW that allow more controller units. Maybe you already do but did you make a call at GS or GroupDIY for the schemo Automating VCA is possible with MIOS, but without schemo and initial system spec it's difficult (need time to reverse engineer the VCA section) Best Zam
Hello PT can handle 4 HUI devices At NGC you should define events to the different midi I/O. e.g for USB: All data to/from HUI n°1 with port=1000..... All data to/from HUI n°2 with port=0100..... etc then select the corresponding midi port at HUI setting in PT Best Zam
Hello It should. Make sure your tipo is not at NGC like here... if_erqual= won't work... if_equal= will ! Can't confirm that, but if you observe this and are sure everything else is ok at your NGC then it's the case Best Zam
I guess you don't define led 2050 at NGC...
I don't get it... can you please show us the whole NGR section ? Best Zam
I repeat myself, did you define your LED in NGC ? EVENT_LED id=1001 hw_id=1001 type=cc chn=1 cc=66 range=0:127 ports=1111110000000000 best Zam
Hello There is no problem using dummy LED out of the hardware (hw_id=) count did you define your LED 1001 in the NGC ? fwd_id= send the value on the event. Best Zam
Hello don't remember that exactly, but I guess the time to reboot, with fast boot flag at bootloader it's fast IIRC you don't "have to" with reset, all previous definitions will be erased without reset they will remain after loading new files Best Zam
For info, there is also the LOAD command that can flip and change whole configuration (.ngc .ngr)
Hello Yes, bank mechanism don't store data at SD card Did you consider the snapshot mechanism ? Best Zam
Hello Frank Honestly most of your request/question here are handled by MB_NG, none will explain what is already explained at NG user manual Please have an extended read about it (i'm sure you already have some), write your .NGC / .NGR files and share when it don't work, then we can help fixing part of the configuration files. NG is powerful, sometimes there is different way available to achieve same result, it really depend of the whole picture, so again with a preliminary .NGC at your side it might help us helping you now, 1- check if_equal= parameter 2- check fwd_id parameter 3 and 4 -check meta and snapshot 5- not sure want you want here but maybe check bank mechanisme 6- I already give you some idea about it, you have to try if it work... Best Zam
Hi Welcome here. Seem non legit seller to me, the ebay description is a copy/past from the wiki ...but I can be wrong. About power supply, you need 9V 500mA, that's common, pick whatever you find (SMPS should not be an issue) Best Zam
Hello Frank Everything is well documented at the NG user manual, specifically .NGC configuration file info for matrix and AINSER, with examples For HW id, first pin first SR is ID one, second pin first SR is ID 2....first pin second SR is ID 9 etc... You can monitor SR nb in debug mode. Best Zam
You can monitor in mios studio what output to the core when you send a specific command via the terminal, you can try to copy this stream and send it with NG core in a button event type=sysex stream="..." Best Zam
Ok, my bad, I just look at MB_KB manual, I was thinking it use the same .NGC .NGR text event definition but it's only configurable via mios studio terminal. Maybe its possible from other midi device (like NG) to trick sysex stream to enter and send data/config bit like mios studio ? Best Zam
It's up to you to define the event type you want to use as a trig for other event. The idea is to have different event activated depending of button status or external midi, it work. Now for transpose (in a NG router) I maybe just find something: receiver with note=all and use_key_number=1 to process the note n° range= have to be a map like (for 1octave transpose) 0:11 11:23 23:31 etc... You can also use a button that set pitchbend to different fixed value? Best Zam
