Zam
625 -
26
Everything posted by Zam
yes you use 2 core... KB+NG what about KB remote from NG for those particular function ? I mean a button at NG that send CC, nrpn or sysex to KB core that flip/change those functions (with dummy led or button receiver that handle the status, used as conditional like I explain before) Right now I don't see how to format note transpose at NG without a keyboard directly hooked to it (with functions named below) Best Zam
I'm not used to keyboard with MB_NG but there is kb_transpose= and kb_velocity_map= You can define multiples KB event id (same hw_id), with different map, then select the proper event with a button (if_equal=) Best Zam
Hello Frank NG offer midi router, but it seem it's not enough for your need You should then use event sender/receiver to format/forward midi event, in addition with conditional definition you can flip or select different midi mapping depending of some buttons status e.g for all notes from ch1 to ch4 if button 1 is pressed (simplified definitions) event_receiver id=1 fwd_id=sender:1 type=noteon key=all chn=1 if_equal=button:1:127 event_sender id=1 type=noteon key=all chn=4 event_button id=1 range=0:127 button_mode=toggle Best Zam
Hello You'll never know as i guess you don't test the chip before soldering I tend to think it's an overheat soldering issue My first TLV soldering 3 years ago had a dead channel (AOUT_NG pcb), I know my soldering was not good then with no flux available and I take to long time to solder pin per pin... overheat Now I have about 6 TLV soldered in my dedicated pcb, I use lot of flux, low solder quantities and tip slip technique, soldering one side in one path, less than 2 second move for 10 pin No issue with this component since TLV don't like heat... Best Zam
Hi Andre Without looking right now at TLV spec your observations seem out of DAC spec, are you sure you don't have gain error somewhere else or load issue which sink the buffer/amp ? Do you observe the same at TLV output, unloaded ? However the interpolation maps at NG are absolutely great !!! (especially the 16bit one) and having an on the fly point value "set and save" will be more than great Best Zam
Hello Nice build ! Stud insert from Schaffer is great !!! Used it in one of my design too, I'm a "no visible screw" freak since Best Zam
Hi I also think there is a something possible with NG -individual event receiver definition for each notes forwarded to two sender, one for note one for PB -or a global receiver (note=all) forwarded to two sender (note and PB) with conditional according to receiver note value Best Zam
How many LEDs !?! ... don't know the limiting resistor value at these built but 300mA is 30 LEDs @ 10mA, easy to get ! Best Zam
Hi Theo A 2 min search at mouser return this https://nz.mouser.com/ProductDetail/ECS/ECS-100AX-1431818?qs=sGAEpiMZZMsBj6bBr9Q9ab6Q5SUOVB%2bxLBrV4K6q260= Best Zam
Hello Look like MB_NG and MB_KB only support 2 keyboard, If you need a third I guess you need another core too Best Zam
Hi Not sure "all" command work at NGR but did you try this: send NoteOn USB1 1 all 0 e.g. for usb1 chn 1, if it work you just have to write few for the 3 port and two channels you use Best Zam
hello Your code look ok so far ... I'm not used to KB so I can't say for sure... can you try something like this instead? RESET_HW SRIO num_sr=4 KEYBOARD n=1 rows=8 dout_sr1=1 dout_sr2=2 din_sr1=1 din_sr2=2 \ din_inverted=0 break_inverted=0 din_key_offset=32 \ scan_velocity=1 scan_optimized=1 make_debounced=1 break_is_make=0 note_offset=36 \ delay_fastest=0 delay_fastest_black_keys=0 delay_slowest=100 KEYBOARD n=2 rows=12 dout_sr1=3 dout_sr2=4 din_sr1=3 din_sr2=4 \ din_inverted=1 break_inverted=0 din_key_offset=32 \ scan_velocity=1 scan_optimized=1 make_debounced=1 break_is_make=0 note_offset=28 \ delay_fastest=1 delay_fastest_black_keys=0 delay_slowest=140 MAP1/BYTEI 0:0 1:20 20:60 60:90 90:110 118:127 EVENT_KB id=1 hw_id=1 fwd_id=sender:1 type=NoteOn chn=1 key=any use_key_number=1 range=0:127 kb_velocity_map=map1 kb_transpose=0 ports=0000000000000000 EVENT_SENDER id=10 hw_id=1 type=NoteOn chn=1 key=any range=0:127 ports=1000110000000000 EVENT_SENDER id=11 hw_id=1 type=NoteOn chn=4 key=any range=0:127 ports=1000110000000000
Ok, but you should have also a map (you use one map...) and kb srio definition? Is RESET_HW specified ? Please post the full .NGC so we can have a look ... Best Zam
Hello Hard to say without more of your .NGC I don't get how you change event status here as you don't have any bank, radio group, or conditional definition ? Best Zam
Is that 3 bits definition at .NGC ?? DIO define emulated SR, you have direct access with the hooked button and corresponding hw_id I guess your first DIO button is hw_id=33 and last is hw_id=48 (if SR 5 and 6) But if I get it right you want to use 3 button to define 8 keyboard states ? 000 is all button off 001 is button n°3 on 011 is button 2 and 3 on etc... 111 is all button on can you confirm that is the logic you want to implement ? Best Zam
What is DIO-000, DIO-100 etc... ? Button on a matrix ?
Yes set active work too ! But if you need to select 16 ch, the NGR will be consequent (16 'if' with 16 'set_activ' each) 256 line at least Best Zam
Hello You can change config with LOAD command at .NGR You should be able to select a keyboard event definition with conditional. EVENT_KB hw_id=1 id=11 type=NoteOn chn=1 key=any use_key_number=1 range=0:127 if_equal=button:1:1 EVENT_KB hw_id=1 id=12 type=NoteOn chn=2 key=any use_key_number=1 range=0:127 if_equal=button:1:2 EVENT_KB hw_id=1 id=13 type=NoteOn chn=3 key=any use_key_number=1 range=0:127 if_equal=button:1:3 map1 1 2 3 EVENT_BUTTON hw_id=1 id=1 value=1 range=map1 button_mode=toggle Banking or radiogroup should work too, it depend how you want to select the channel Best Zam
Hi At mios32_timestamp.c does this can be used ? ///////////////////////////////////////////////////////////////////////////// //! Use this function to get the delay which has passed between a given and //! and current timestamp. //! //! Usage Example: //! \code //! u32 captured_timestamp = MIOS32_TIMESTAMP_GetDelay(); //! // ... //! // ... do something ... //! // ... //! u32 delay_in_ms = MIOS32_TIMESTAMP_GetDelay(captured_timestamp); //! MIOS32_MIDI_SendDebugMessage("Delay: %d mS\n", delay_in_ms); //! \endcode //! \return the delay between the given and the current timestamp ///////////////////////////////////////////////////////////////////////////// s32 MIOS32_TIMESTAMP_GetDelay(u32 captured_timestamp) { // will automatically roll over: // e.g. 0x00000010 - 0xfffffff0 = 0x00000020 return timestamp - captured_timestamp; }
For sure 65ms period for blinking led is fast... I'll see what I can try too Maybe TK will chime in and give us some clue Best Zam
side note I just have a look, Also at mbng_dout.c , maybe another route is to have a non static value for DIM function or to add a condition at LED set for a specific value ? I'm thinking out loud... Best Zam
My C skill is not that good, but that's a good idea, I'll give a try asap Best Zam
Hello Fantom No I don't try with optocoupler, but I try at 31.25kb standard speed, I'm able to reach the slave core as loading .NGC in the file browser (very slowwwwwwww) but unable to update without trouble. I don't think it's the issue, as my cores share same PSU and stand side by side so UART direct interconnection is less than 10 cm Also if I have to choose I prefer to have the actual 10x speed 312.5kb than abilities to reach the core... I have no pull up resistor neither current limiting, maybe I can try that. But as usual midi data is fine, maybe it's something with the long sysex for MIOS command, I'll will investigate more around buffer or if there is a special handler for those sysex when using UART in/out ... Anyway thanks for your idea Best Zam
mmm... not that good finally, I'm not able to update or upload .NGC without disconnection and data lose whatever UART speed I set. so, need further investigation ... Best Zam
