doc007
49 -
Everything posted by doc007
Happy new year in the hope of tne new BLM CI Pierre
- 13 replies
- calculation
- cost
(and 2 more)
Tagged with:
Thanks the_duckchild thank you for the address
hello, Looking for sid 8580 R5 for my synth I fall on the following site " www.supplygoodsstore.eu " that offers 788 pieces at 12 € each. Has anyone tried to order on this site? What do you think about this site ? Thank you for the answer. Pierre
Building the MB-6582 Control Surface - Photo Tutorial
doc007 replied to Hawkeye's topic in Tips & Tricks
Hello, I would like to have an acrylic window made by Schaeffer to give a more professional look. For good alignment on the front face, this plate should have 1.5mm thickness. However, the minimum thickness by Schaeffer is 2 mm. Has anyone found a solution? -
Thanks Pierre -
Hello Oeil de Faucon Can I have the schematic diagram of your new PSU ? Thank you -
Hello, Je serais vivement intéressé par le CI de base pour midibox SID. Merci de m'indiquer la démarche à suivre. Cordialement Pierre
Hello friends I am building midibox FM and i have a small problem. For troubleshooting I use a minimal configuration with only MBHP_CORE module with 18F452 and MBHP_OPL3. At first I burned my pic ( bootloader_v1_2b_pic18f452.hex ) with an external programmer. With Mios Studio 2 I tested the midi connection that works. I have loaded with mios application mios8_v1_9h_pic18f452.hex and then setup_pic18f452_mbfm_v1.hex. The restart is done with display of mios version 1.9h C 2014 T KLOSE then MIDIBOX FM V1.4i permanently -------->NO BOOT WINDOW But if I disconnect J2-2 (D2 to D7 duYMF262) I get my boot window on the display ?????? Of course I checked all the connections between the PIC and the OPL3 module. Do you have research leads to give me ? Thank you for the answer
Hello, TK, Andy and Others I see that this magnificent project does not move any more. As many of us are waiting for the PCB and the case, how can we help to move the project forward Pierre
Hello flyweight Unfortunately all boxes have been sold. sorry
Thank you for the answer Pierre
Hello Friends, My Midibox SEQ V4 is finished and works really well . I have a question regarding one midi output. I have a question regarding the midi output. Can I connect any midi output without using a synthesizer to an analog amplifier using the module AOUT_NG or another DAC ? Pierre
Hello Yannick, the box is available immediately and can be sent quickly. Pierre
Hello friends, I received the boxes Heidenreich today. The quality is really good. I'll dispatch the parcel and send it to you tomorrow. Good night Pierre
Hello, Next week is week 13. I think heidenreich should send me the boxes. As soon as I receives, I forward them to you. Happy Easter Pierre
Since I changed my SD card I can upload MBSEQ_HW.V4 and save it on my sd card to use my wilba's frontpanel. But later if I try for example to change the midi port ( pressed MENU + MIDI and select Midi Router on the left LCD ) I have an error : [16338.948] [SEQ_FILE_C] Failed to open/create config file, status: -11 [16338.949] [SDCARD_ERROR:-11] DFS_OpenFile(..DFS_WRITE..) failed What do you think ? hardware or software error ? Thanks for the answer
The Frontpanel engraved by schaeffer costs about 200€ and the backpanel engraved also by schaeffer 76€.
It's one original Heidenreich black case with a blank back panel without the frontpanel . The price is 127€28 + shipping costs.
Hello For sale 1 SEQ4 Heidenreich box that will be delivered in April. It's the rest of the Batch#4.
Here are the bills heidenreich Untitled_20160307_145614.pdf Untitled_20160307_145614_001.pdf
hello, Today I had the final price of 8 boxes Heidenreich with a surprise. In Fact the price of 89€ was excluding VAT so that the price including all taxes by boxing amounts in reality to 89 € + 19% VAT = 105.91 + shipping to my home = 112€.28. With my one-off handling fee of 15€ (gas, package, time) the price is 127.28 per box + shipping costs + PayPal fees if you pay with Pay Pal. I send to each purchaser in PM a copy of the bill of Heidenreich and I await your answers . Pierre
Hello TK I changed my SD card and everything is back to normal Thank you Pierre
Hi Quadram and Reboot You can still join the batch on the same terms as that organized by Kristal ( 3 boxes ) 1x black case á 89€ (with a blank back panel) 4-5 weeks manufacturing time one-off handling fee 15€ (gas, package, time) Colissimo for France payement by SEPA / IBAN system ( no fees ) confirm me by MP Pierre
Hello I just finished Midibox SEQ V4 based on Wilba's frontpanel and it seems to work. My little problem concerns the SD card reader. At start "searching sd card" is displayed; but it is never detected. If I reset, it is still not found .But if I take out the card and I put it back in the drive it is directly detected. But to have the changes to the cfg Wilba saved on the SD card, I still have to reset the core. Is this normal?
You can choose the payment method depending on whether you are in the eurozone or not
