15,247 -
Thanks for the detailed report! :) I noticed that aside from FWD_MIDI, also AUTO_START and STEPS_PER_KEY are not stored, it's now on the wish list and should be possible with the next release Best Regards, Thorsten.
The SID Player is only available for MacOS, and can't be migrated. However, the "ASID Application" for the Elektron Sidstation might work at your side, it can be downloaded from the Elektron support page Best Regards, Thorsten.
"Upgraded" forum complaints/suggestions
TK. replied to latigid on's topic in MIDIbox Documentation Project
Concerning the character issue: this is a known migration issue, and we can't fix it. Actually Twin-X asked me if it's ok for me to bring the forum back online without solving this issue - I agreed because I had no better idea. We can edit the subjects and manually correct the characters this way - just need help from people who can give us a template ;) To the other issues: I need your help to find out, how to configure this, resp. how to fix this The IPS Support forum is here, maybe you will find the answers? I will change on demand, but I've no time to search for solutions: -> https://community.invisionpower.com Best Regards, Thorsten. -
Getting Analog(J5) to work on CORE8 Mios8 Midio128
TK. replied to Johannus OP240's topic in MIDIfication
Hi, I received your PM this Thursday, but usually work through various requests only on Sundays, that's the reason for the delayed reply. Here is a quick&dirty hack which should send CC#16...CC#23 over MIDI channel 1 on pots connected to J5.A0...A7 -> http://www.ucapps.de/mios/midio128_v2_2c__ain_enabled.zip Please note that unused analog inputs have to be clamped to ground, otherwise they will cause random MIDI data. Best Regards, Thorsten.- 18 replies
- analog pots
- midio128 pots
(and 1 more)
Tagged with:
Unfortunately we can't save the settings due to memory limitations. With MBSEQ V4+ (running on a STM32F4) this should be possible, but it will still take some months until the extended firmware version will be available (and it won't run on a STM32F1 or LPC17 based core...) Best Regards, Thorsten.
Angeblich unterstuetzt der neue Standard USB MIDI Treiber unter Win10 nun Multi-Client und geringe Latenzen. Also aehnlich wie unter MacOS Kann das jemand bestaetigen? Wenn das so ist, sollte man am besten keinen zusaetzlichen Treiber installieren, sondern einfach den nehmen, der nach dem Einstecken des Moduls automatisch ausgewaehlt wird. Gruss, Thorsten.
Since USB is interrupt driven, it's for me another indicator that the issue is caused by a stack overflow. I just added too many features which don't fit into the RAM of LPC17 anymore... In order to check if this assumption is true, please try this version: http://www.ucapps.de/mios32/midibox_seq_v4_089_pre6__undo_disabled.zip I disabled the UNDO function which saves around 1.5k If this version is working stable at your side, I've to think about feature reduction for the LPC17 firmware (because I guess that most LPC17 users would like to get back the UNDO function) Best Regards, Thorsten.
Yes, as explained at the bottom of the "installation" section in the user manual: http://www.ucapps.de/midibox_seq_manual_in.html Best Regards, Thorsten.
Thanks for the hint, the issue should be fixed in this version: http://www.ucapps.de/mios32/midibox_seq_v4_089_pre6.zip Best Regards, Thorsten.
Den Kommentaren nach handelt es sich bereits um PM, und nicht FM // calc 32bit increment (phase_increment * fm_ratio >> 8) Gruss, Thorsten.
Hi, great! :) Currently it's only possible to mute entire tracks via CC. I'm unsure if it makes sense to mute individual notes, such a generic filter capability would be very costly (128 * 16 CCs required) Maybe trigger layer mutes could be controlled via CC (currently only possible from the UI), this would fit with your intention? This is possible: press & hold the SELECT button. Change mute states for tracks or parameter/trigger layers (press&hold MUTE button in addition to see them) Release SELECT button to take over the change. I've to check this (added to the long wish list) However, double-click is no option, too risky during live situations Best Regards, Thorsten.
:-( Could you please check if this also happens with the latest pre-release version? -> http://www.ucapps.de/mios32/midibox_seq_v4_089_pre5.zip Which core module are you using? If it's a MBHP_CORE_LPC17, I fear that it's caused by the stack overflow issue that we had some versions ago, with the result that I've to start to remove features for this core (because of missing RAM space) yes, this should work to recover the core. Best Regards, Thorsten.
Update: the copyright message is originated from 2012 - seems that you missed an important bootloader update! Last update 2012 was v1.010 (at this time w/o version information displayed in MIOS Studio) Current version is V1.018 (2014 release) If previously a version before V1.010 was installed, please follow this process: Best Regards, Thorsten.
Unfortunately not from a user documentation: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Finclude%2Fmios32%2Fmios32_midi.h -2 means: more bytes have been received than expected -4 means: write access (to flash) failed, which is just the result of -2 Which MacOS version are you using? I'm a MacOS user as well, and never got this error code... and I upload code to different core modules very frequently ;-) Best Regards, Thorsten.
But you can't do this in the additional note layers of a track - here you've to disable the note by setting it to the lowest value (which is displayed as "---"), and if you want to play the note again it's better if it starts from C3 I'm wondering, why you've to set the note to the lowest at your side? Actually I would like to avoid too many (confusing) options. I will only add it if there are good reasons, and if multiple users confirm that it makes sense. Best Regards, Thorsten.
This was a special user request, I haven't made it optional. I don't know the new Elektron sequencers, but I guess that you mean the "delay" parameter, which can be assigned to a parameter layer. It allows to adjust the delay from 1..96 microticks for each individual step. Alternatively (and that's the way I prefer) create a custom groove template with a certain length (e.g. 4), and set individual delays for each groove step, it will then be applied to all tracks which are assigned to the groove template Best Regards, Thorsten.
Steps duplication: I've implemented this feature - could you please help me to test it? -> http://www.ucapps.de/mios32/midibox_seq_v4_089_pre5.zip Best Regards, Thorsten.
Always a pleasure to watch your videos and listen to your music! :) Best Regards, Thorsten.
Hi Jasper, unfortunately it won't be so easy to add such an option to the firmware. However, if you are already using a STM32F4 core module, there is hope that the MIDIbox SEQ V4+ Firmware could support "free-style" tracks :) But I won't start to work on this before end of this year (and I already postponed the start of development by +1 year) Best Regards, Thorsten.
Thank you for the video, more please! :) I will collect them and publish in the tutorial: http://www.ucapps.de/midibox_seq_manual_tut.html Best Regards, Thorsten.
Hi Bartosz, do you still notice the issue? If not, I will push the release button. Best Regards, Thorsten.
I'm not aware of this - maybe the MIDI load is too high on each port, and the I2C peripheral of STM32F4 can't handle the throughput anymore? Does this only happen under high load, resp. does the problem disappear if you change certain tracks to other MIDI ports? Best Regards, Thorsten.
Tja, ich verstehe das leider auch nicht. Microsoft hat es auch nach 15 Jahren noch nicht geschafft, einen stabilen USB MIDI Treiber bereitzustellen, und bei den Herstellern gibt es viele Dilettanten, die ein Produkt ohne ausgiebige Qualitaetssicherung auf den Markt werfen... die dann leider auch noch jahrelang auf Ebay rumgeistern, weil sie niemand gebrauchen kann. Das perfekte Fertig-Produkt war bisher das Neusonik uMIDI/O22 fuer 15 EUR. Leider war es auch schnell ausverkauft, nachdem wir es auf die Whitelist gesetzt haben. Seitdem habe ich nichts vergleichbares in dieser Preislage gesehen. Gruss, Thorsten.
Alright, the new version is released now: MIDIbox KB V1.016 ~~~~~~~~~~~~~~~~~ o Support for AINSER8 module It has to be connected to J19; chip select line RC1 will be used (set jumper J4 accordingly) In the AIN configuration it can be selected as pin 128..135 o added 4th AIN pin for "expression pedal" (CC#11 by default can be re-assigned). and the documentation has been updated: http://www.ucapps.de/midibox_kb.html This was already described with some examples in the documentation (search for "midi_ports") Best Regards, Thorsten.
