d2k
Frequent Writer
    912
Everything posted by d2k
  1. Hey... I tend to print to a PDF (keep everthing vectorised) then open in ie, Illustrator retrace quickly (smart guides ;p) then export to dxf or whatever... Best
  2. yup ;) i musta had an old link - refound and pdf's nabbed :D Great stuff! D
  3. Hey Bauman!! welcome to midibox :) Your master plan sounds similar to console I've been recently dreamin of - especially after gettin my toes wet with some tasty analog outboard (daArry on lab 'ere btw ;p) Have u peeped that SSL AWS 900? Summing like I was thinking, but in a modular approach like u mentioned :D What 'appen to that sontec page btw :P
  4. http://notapplicable.co.uk/mbhp/PSU-aout_SolderSide.pdf http://notapplicable.co.uk/mbhp/PSU-aout_CheckPlot.pdf goodluck!
  5. the joystick will effect whatever params u assign to it (not just filter/cutoff like shown in the code) after power on yes...just put whatever u want to control in the 2 (joystick=2 pots) top most entries in 'SID_AIN_POT_ASSIGN_TABLE'
  6. hehe, now that is off the hook! ;p very imaginative :)
  7. Hey... Here is my sid_ain.inc: ; ; Enhanced AIN Driver for MIDIbox SID ; which allows you to change Control Surface Parameters via Pots ; Layers are not supported here, instead every menu parameter can be assigned ; to a single pot. ; ; Up to 64 entries can be added to SID_AIN_POT_ASSIGN_TABLE (see below) ; ; 19 entries are predefined here ; ; Open sid_init.inc and configure the AIN driver in the following way: ; ; ;; initialize the AIN driver ; movlw 19 ; use 19 pots ; call MIOS_AIN_NumberSet ; call MIOS_AIN_Muxed ; service the multiplexer interface ; movlw 0x07 ; movwf MIOS_AIN_DeadbandSet ; configure deadband for 7-bit values ; ; ========================================================================== ; ; Copyright (C) 1998-2003 Thorsten Klose (Thorsten.Klose@gmx.de) ; http://www.uCApps.de ; ; ========================================================================== ; ; This file is part of MIDIbox SID ; ; MIDIbox SID is free software; you can redistribute it and/or modify ; it under the terms of the GNU General Public License as published by ; the Free Software Foundation; either version 2 of the License, or ; (at your option) any later version. ; ; MIDIbox SID is distributed in the hope that it will be useful, ; but WITHOUT ANY WARRANTY; without even the implied warranty of ; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the ; GNU General Public License for more details. ; ; You should have received a copy of the GNU General Public License ; along with MIDIbox SID; if not, write to the Free Software ; Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA ; ; ========================================================================== ;; -------------------------------------------------------------------------- ;; This function is called by MIOS when a pot has been moved ;; Input: ;; o Pot number in WREG and MIOS_PARAMETER1 ;; o LSB value in MIOS_PARAMETER2 ;; o MSB value in MIOS_PARAMETER3 ;; -------------------------------------------------------------------------- USER_AIN_NotifyChange SID_AIN_NotifyChange ;; store pot number in TMP1 movwf TMP1 ;; get 7-bit value of pot (number already in WREG) call MIOS_AIN_Pin7bitGet ;; store it in MIOS_PARAMETER3 movwf MIOS_PARAMETER3 ;; get offset to SID data base call CS_MENU_MS_GetSIDNumber call CS_MENU_MS_GetSIDBase ;; prepare CS parameters depending on pot number ;; read it from table for an easy customization TABLE_ADDR SID_AIN_POT_ASSIGN_TABLE ;; select entry (pot number * 4) movf TMP1, W ; pot number stored in TMP1 mullw 4 movf PRODL, W addwf TBLPTRL, F movf PRODH, W addwfc TBLPTRH, F ;; get function and store it in TMP1 tblrd*+ movff TABLAT, TMP1 ;; get parameter value and add it to FSR0L tblrd*+ movf TABLAT, W addwf FSR0L, F ;; get menu number and store it in TMP2 tblrd*+ movff TABLAT, TMP2 ;; get menu offset and pos tblrd*+ ;; store cursor position in MIOS_PARAMETER1 movf TABLAT, W andlw 0x0f movwf MIOS_PARAMETER1 ;; store page offset in MIOS_PARAMETER2 swapf TABLAT, W andlw 0x0f movwf MIOS_PARAMETER2 ;; absolute value already in MIOS_PARAMETER3 ;; now branch depending on function swapf TMP1, W andlw 0x0f JUMPTABLE_2BYTES 4 ; entries rgoto SID_AIN_Modify_Sys rgoto SID_AIN_Modify_Osc rgoto SID_AIN_Modify_LFO rgoto SID_AIN_Modify_Env ;; --- SID_AIN_Modify_Sys ;; just modify current parameter movf TMP2, W ; load menu number rgoto SID_AIN_ModifyValue SID_AIN_Modify_Osc ;; add voice offset call CS_MENU_Hlp_AddVoiceOffset ;; and change parameter rgoto SID_AIN_Modify_Sys SID_AIN_Modify_LFO ;; add LFO offset call CS_MENU_Hlp_AddLFOOffset ;; and change parameter rgoto SID_AIN_Modify_Sys SID_AIN_Modify_Env ;; add ENV offset call CS_MENU_Hlp_AddENVOffset ;; and change parameter rgoto SID_AIN_Modify_Sys ;; the pot assign table ;; similar to the table which can be found in cs_menu_enc_table.inc ;; (read the comments there) ;; NOTE: this version can only be used for changing control surface ;; parameter. It doesn't allow you to send CC values or whatever. ;; feel free to enhance the code like in cs_menu_enc.inc if you ;; want to control also other parameters CSAIN_ENTRY MACRO function, parameter, menu, page_offset, cursor_pos db function, parameter, menu, ((page_offset&0x0f)<<4) | (cursor_pos&0x0f) ENDM ;; available functions: ;; CSENC_ENTRY parameters: ;; - the ID itself ;; - the variable offset (see app_defines.inc, variables begin with CS_SID_*) ;; - the menu in which the variable is located (see cs_menu_tables.inc) ;; - the page offset (which menu item should be at the left border) ;; - the cursor position of the menu item #define CS_MENU_AIN_CHANGE_SYS 0x00 ; to change any internal parameter directly #define CS_MENU_AIN_CHANGE_OSC 0x10 ; to change parameter of currently selected OSC #define CS_MENU_AIN_CHANGE_LFO 0x20 ; to change parameter of currently selected LFO #define CS_MENU_AIN_CHANGE_ENV 0x30 ; to change parameter of currently selected ENV SID_AIN_POT_ASSIGN_TABLE ;; every pot has it's own entry ;; no layer handling supported here! ;; up to 64 entries are allowed for various parameter values ;; Function name parameter menu offset cursor pos CSAIN_ENTRY CS_MENU_AIN_CHANGE_SYS, CS_SID_FILTER_CUTOFF, CS_MENU_FIL, 0x00, 0x01 CSAIN_ENTRY CS_MENU_AIN_CHANGE_SYS, CS_SID_FILTER_RESONANCE, CS_MENU_FIL, 0x00, 0x02 CSAIN_ENTRY CS_MENU_AIN_CHANGE_OSC, CS_SID_VOICEx_DECAY, CS_MENU_OSC, 0x03, 0x05 CSAIN_ENTRY CS_MENU_AIN_CHANGE_OSC, CS_SID_VOICEx_SUSTAIN, CS_MENU_OSC, 0x03, 0x06 CSAIN_ENTRY CS_MENU_AIN_CHANGE_OSC, CS_SID_VOICEx_RELEASE, CS_MENU_OSC, 0x03, 0x07 CSAIN_ENTRY CS_MENU_AIN_CHANGE_OSC, CS_SID_VOICEx_TRANSPOSE, CS_MENU_OSC, 0x09, 0x09 CSAIN_ENTRY CS_MENU_AIN_CHANGE_OSC, CS_SID_VOICEx_FINETUNE, CS_MENU_OSC, 0x09, 0x0a CSAIN_ENTRY CS_MENU_AIN_CHANGE_OSC, CS_SID_VOICEx_PORTAMENTO, CS_MENU_OSC, 0x09, 0x0b CSAIN_ENTRY CS_MENU_AIN_CHANGE_OSC, CS_SID_VOICEx_ARPEGGIATOR,CS_MENU_OSC, 0x09, 0x0c CSAIN_ENTRY CS_MENU_AIN_CHANGE_OSC, CS_SID_VOICEx_PULSEWIDTH, CS_MENU_OSC, 0x09, 0x0d CSAIN_ENTRY CS_MENU_AIN_CHANGE_LFO, CS_SID_LFOx_RATE, CS_MENU_LFO, 0x00, 0x02 CSAIN_ENTRY CS_MENU_AIN_CHANGE_LFO, CS_SID_LFOx_DEPTH, CS_MENU_LFO, 0x00, 0x03 CSAIN_ENTRY CS_MENU_AIN_CHANGE_OSC, CS_SID_VOICEx_DELAY, CS_MENU_OSC, 0x03, 0x03 CSAIN_ENTRY CS_MENU_AIN_CHANGE_OSC, CS_SID_VOICEx_ATTACK, CS_MENU_OSC, 0x03, 0x04 CSAIN_ENTRY CS_MENU_AIN_CHANGE_ENV, CS_SID_ENVx_DEPTH, CS_MENU_ENV, 0x01, 0x01 CSAIN_ENTRY CS_MENU_AIN_CHANGE_ENV, CS_SID_ENVx_ATTACK, CS_MENU_ENV, 0x01, 0x02 CSAIN_ENTRY CS_MENU_AIN_CHANGE_ENV, CS_SID_ENVx_DECAY, CS_MENU_ENV, 0x01, 0x03 CSAIN_ENTRY CS_MENU_AIN_CHANGE_ENV, CS_SID_ENVx_SUSTAIN, CS_MENU_ENV, 0x01, 0x04 CSAIN_ENTRY CS_MENU_AIN_CHANGE_ENV, CS_SID_ENVx_RELEASE, CS_MENU_ENV, 0x01, 0x05 ;; -------------------------------------------------------------------------- ;; This function modifies a given parameter which is indexed like shown ;; here: ;; ID of CS_MENU in WREG (example: CS_MENU_OSC) ;; table (cursor) position in MIOS_PARAMETER1 (example: 0x01 for waveform) ;; page offset in MIOS_PARAMETER2 (example: 0x00 begins at first line) ;; 7-bit value in MIOS_PARAMETER3 ;; -------------------------------------------------------------------------- SID_AIN_ModifyValue ;; save WREG movwf TMP5 ;; change to menu movwf CS_MENU call CS_MENU_Page_Init ;; set new page offset and cursor pos movff MIOS_PARAMETER1, CS_MENU_CURSOR_POS movff MIOS_PARAMETER2, CS_MENU_PAGE_OFFSET ;; select parameter call CS_MENU_EXEC_SelPar ;; copy value into the appr. CS register ;; here we could scale the value over the whole pot range, ;; but to keep it simple we just limit it to the max value movf MIOS_PARAMETER3, W cpfsgt CS_MENU_PARAMETER_MAX_L, ACCESS ; (IFLEQ) movf CS_MENU_PARAMETER_MAX_L, W movwf CS_MENU_PARAMETER_L call CS_MENU_ParameterUpdate ; update parameter call CS_MENU_EXEC_Hlp_ChangeMenu ; deselect parameter ;; force a display update and exit bsf CS_STAT, CS_STAT_DISPLAY_UPDATE_REQ return in sid_init.inc: ;; initialize the AIN driver movlw 2 ; use 2 pots call MIOS_AIN_NumberSet call MIOS_AIN_UnMuxed ; don't service multiplexer interface movlw 7 call MIOS_AIN_DeadbandSet After u made those changes - u build a new .hex file then convert that to .syx - this proceedure has been covered many times and is also on the main ucapps.de site :)
  8. d2k
    MIDIbox FM preview
    Hey... Howzabout getting a list together of the soundcards/devices these chips are on...? Great stuff!
  9. coo, single DIN it is then :)
  10. d2k
    MIDIbox FM preview
    ohoh! is it time to dust off that old SB awe32?? :)
  11. Hey... Can a single encoder be connected to core:j5 to save on a dinx1? thanks!
  12. They are for the touch sensi ye, just regular takt switches that are small enuff to fit in that space at the bottom of those pana faders... I ebayed all the control stuff - but the switches (aprt from the square ones) seem to be regular types that u can buy from various electronic stores. the encoders are panasonics types, but I think they share same pinout with most alps ones used too - the scrubb wheel is the same as the vpots (just has a big knob) well if u really want it but i dont see the point tbh, these are not good pcbs! I made some mistakes and had to cut a cpl of tracks on the vpot control pcb (u can see a lil in the pics)... http://www.holtbs.co.uk
  13. save your money on say gettin a proper panel and artwork done I'd day, these are nice switches but u can save alot if u say use takt switches then improvise a lil... I've been using takt switches then using rubber feet as caps - very nice indeed :) plus u can get all manner of types - black, clear (leds shines thru nice), square, round, matt, gloss etc etc...
  14. d2k
    Bits for sale >
    Hey man more or less all from that page has since gone - just aint updated it in a long while...so no mo motofaders soz!
  15. I used these without probs - http://alltronics.com/images/22P010.jpg
  16. Hey... I been tiding up my seq box and modified the psu/aout/bankstick brd I done for the sid a while back to include also the dc-dc convertor (based on LT1054 chip) for the +/-12 too. I used a 7806 in place of the 09 on the sid psu so got 11V which i fed to the LT, then just used a regular 78/912 after - aint been under much test but seem to be workin fine so far (gate leds are lighting when they should neways ;))
  17. ...luck of the gnd gods? ::) connected direct to master core yes, cap between +5 and gnd on the joystick itself. the cable i used is that from old serial mice...
  18. did this guy ever come through for anyone? just wondering why this thread is always right up the top...
  19. hey drum, great stuff :) I'll be etching that buffer brd upped on the portal next time the fC is out!
  20. i used an additional joystick to control cut/res on my quad sid and it works fine :) info and code on forum sumwhere - search 'sid' 'joystick' or whatever and by username...
  21. i dont know but they also had a Gyraf G9 listed too!! full story: http://www.prodigy-pro.com/forum/viewtopic.php?t=2313
  22. hey drumwilde, so you have workin mios drum triggers already then!? Have u made any hardware changes? Can put thise peizos and bean cans to use now ;)
  23. Hey ye soz, pics got dashed - never continued with this project as (..i remember - was a while bak) I couldnt get it workin when I desolderd the components from the mouse and made up new brds - got messy and I was even more of an amature then ;p...neways it was lotta work and whats the point of that when u can get encoders for so cheap! chek smashs' site - he's knockin em out for a nugget! D
  24. y0 axel, sum prik is bootleggin ur design on ebay: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41784&item=3749189689 this takes the piss man
  25. right, but does that mean the aout module can be used here?? I dun know c/v and aint really used proper h/w analog synths before, and I def aint a patcher...so whats the hookup proceedure? from 1 of the 'V' pins on the aout brd to the cv input on the vcf? then i can make an encoder or whatnot control the freq?
