Screaming_Rabbit
Frequent Writer-
1,431 -
Everything posted by Screaming_Rabbit
Thanks a lot! Roger
Thanks Duggle and Moebius ... the problem with that is, that I'm using square LEDs for the meters and don't have a clue, where to get brighter ones. But since the clipping LED is the only RED one in the meterbridge, I wouldn't care to much when it's duller than the GREEN and YELLOW ones. Do I understand it right, that I could wire them in parallel, use the regular square one for the meter and buy high density ones for the clip-LED next to the fader. I then could raise the resistor value for the high density LED. As higher the resistor is, the less dull the one in the meterbridge would get? ... I don't really understand your description (language barrier or electronic dummy) Â :-[ Greets Roger
Thanks Moebius ... so your friend didn't mount any shielding plate between display and inverter? Roger
Link for DIY MIDI through module
Screaming_Rabbit replied to Screaming_Rabbit's topic in Miscellaneous
Thanks That's good! I don't want a delay. I was afraid that I would get a delay... I want to feed more devices in parallel. - The lower the delay, the better. Greets, Roger -
aaaahhhh.... found one: http://tomscarff.tripod.com/midi_distribution/midi_4way_dist.htm Does one of you electronic cracks know about this cirquit gives me any latency. I mean: Is it refreshing the data (and needing processing time) or does it just amplifie the signal? -
Does anybody have a link for a DIY MIDI through module construction page? Something like 1IN to 4 ore more OUTs. Thanks and greets Roger
I bought a LVDS flat panel with CRT-converter and inverter. I think they were thought to fit into laptops (exept of the converter). Could it be a problem, when I mount the inverter in the housing right behind the flat panel (like disturbing the picture)? Is it more clever to mount it at the base? Greets, Roger
Hi there Is it possible to connect LEDs parallel in a matrix... for example: In the MidiBox LC application, having the matrix for the LED meters. Then connect for the clip LED a second one to mount right above the fader and connenct it parallel to the clippinfg LED of the meter bar? If possible, would it also work with buttons? Thx and greets Roger
When I washed my hands after having a long session on the toilet, this guy walking by, asked me: "Ooohhh wasn't there any toilet paper?" ;D
Depends on what kind of soap you're using. The soap needs water, otherwise the OH- Ions don't have any effect on spliting the organic dirt. Greets, Roger
Fader hugues and gilles ( help in deutch)
Screaming_Rabbit replied to rocofolie's topic in Parts Questions
... the Faders are 5KOhms linear. They should be 10K. I read some posts, that this wasn't a problem for rotary pots. But I wouldn't take the risk... MFs are to expensive and TK's statement is clear: 10k/linear Greets, Roger -
anyway of building a midi version of this?
Screaming_Rabbit replied to banneduser's topic in Design Concepts
... can this be done with a software? - Which one? Greets, Roger -
Werde die Displays am Montag bestellen. - Ohne Rahmen. Bekam folgendes Angebot: - Ohne Rahmen $2.80 / 60$ shipping - mit Rahmen $3.20 / 80$ shipping @Jack: Hast Du ein funktionierendes Core Board? Würdest Du Dich zur Verfügung stellen, um die Displays zu testen? ... falls sie je aus China ankommen :P Greets, Roger
I think that they have the Alps N-Type faders... you have to check the type and/or have to measure the resistance. You propably can't use the original PCBs for the encoders and switches... I could imagine, that they implemented one big PCB for everything... perhaps you can customize it ??? I also think, that you don't have enough space inside to pack the MB-Boards into the case. ... and why would you wanna take the original Behringer case? - It looks so cheesy ;D Greets, Roger
http://www.doepfer.de/sonder.htm 2-fach-Netzteil, Eingang 230V AC, Ausgang +5V/2.5A und -24V/50mA, stabilisiert, eingebaut in hellgraues Kunststoffgehäuse (ca. 16 L x 10 B x 7 H cm), Netzzuleitung mit Eurostecker, die beiden Spannungen stehen an einem Kabel in Form einer 3-poligen DIN-Kupplung zur Verfügung, bei größerer Abnahmemenge fordern Sie bitte ein Angebot an (ca. 100 Stck. vorrätig, bei Komplettabnahme 2.00 pro Netzteil)
... this might be pretty hard. Since you propably don't have the source code. :-/ Greets, Roger
Was it factory installed or is it possible, that your pickups are connected "out of phase". - So when your balance pot is in the middle position you'd get something like a humbucking noise cancellation? Greets, Roger
Fände cool, wenn Ihr das im Forum diskutieren könntet.... wäre somit dokumentiert und für ander Marimbianer zugänglich. - Was meint Ihr? ;) Greets, Roger
Grounding analog multiplexers sockets in the AINX
Screaming_Rabbit replied to intosite's topic in Design Concepts
LFO = Low Frequency Oscillator Greets, Roger -
Also dann... ich geh das Risiko ein 8) 1: Meine Freundin erzählte mir, dass es sehr gut möglich sei, dass die Post von China so extrem Teuer sei. - Ihre Eltern bestellen des öftern Homeopathische Heilmittel von China und das Porto sei "schweine teuer". 2: Bei den Angeboten auf E-Bay (welches ja auch nicht die original Displays sind), sieht man praktisch keine schlechten Bewertungen. was die Anzeige-Qualität betrifft. Man liest ab und zu, dass das Display nicht funktioniere... kann aber auch bei der Selbstmontage passiert sein. 3: Falls ich verars...t werde, ist der Verlust nicht wenig aber auch nicht wirklich ein Vermögen. Wenn's klappt, ist dafür der Gewinn enorm. No risk - No fun ;D Ich werde den Typen, welchem ich zuerst geschrieben habe, mal nach dem Porto für eine Bestellung von mehreren Sücken anfragen. Ich nimm nicht an, dass dies z.B. 50 Stk. x 60$ sein wird. Greets, Roger
... habe von diesem Anbieter keine Antwort bekommen >:( Roger
...nein in einer handgeflochtenen chinesischen Strohhalmtasche, parfümiert mit Grüntee-Blüten ;D :-X 8) Ich würde gerne vorher noch so ein Ding auf Ebay kaufen und mich nur kurz von der Anzeige Qualität überzeugen lassen ... sollte kein Problem sein. Ich würde 50 Stk. nehmen, Jack möchte 30 Stk. ... und wenn wir ein Posting im internationalen Forum machen, vermute ich, dass wir locker 100 Stk zusammen kriegen. Problem: Je grösser die Bestellung, desto grösser der Verlust, wenn wir über's Ohr gehauen würden :-/ Greets, Roger
MIDIbox of the Week (MB64 Traktor Controller of Martin)
Screaming_Rabbit replied to TK.'s topic in MIDIbox of the Week
Nice! And good idea with the fader start switches. My mothertongue is german (Swiss) but I had to try the translation link... whooaaahhh :-/ almost not readable... so I decided to translate your text for our english speaking friends... even thought my english isn't perfect at all.... but I think I beat the fckn computer.... yessssss :-* Greets, Roger -
Cheap ALPS MF Faders and MF Pots
Screaming_Rabbit replied to Screaming_Rabbit's topic in Parts Archive
I don't know, just try... they only can say: "No, fuck you". Then you answer: "Yes, Fuck you too" ;D ... know what I mean? Greets, Roger -
... da wäre nur eines gemeint  :-/ Irgend etwas muss da ja faul sein, denn die abgebildeten Rahmen haben alle den NOKIA Schriftzug eingestempelt. Ich glaube nicht, dass NOKIA das zulassen würde. Ich denke da läuft die selbe Sache wie das Kopieren von Schweizer Uhren. - Fakes... aber funktionstüchtig. Ich denke, dass diese billigen Ersatz displays alle aus der selben Fabrik in China oder Korea kommen. http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=40568&item=6327764329&rd=1 Was haltet Ihr davon: Von obigem Ebay-Anbieter ein Display als "Sample" kaufen und falls es i.O. ist, von China eine Bulk Bestellung machen. Greets, Roger
