Screaming_Rabbit
Frequent Writer-
1,431 -
Everything posted by Screaming_Rabbit
Hey SmashTV You always impress me with your knowledge in all those aspects! Â :o ... but I hope d2k's thread doesn't go in a wrong direction, since the cause of the implementation of touchpads isn't patent but cost dependent. Again: I always apprechiate your comments, this isn't an offense! Greets, Roger
You don't have to calculate: 10k Lin http://www.ucapps.de/mbhp/mbhp_ainx4_orderlist.txt Greets, Roger
Touchpad for surround control
Screaming_Rabbit replied to Screaming_Rabbit's topic in Design Concepts
Lately I was at a Digidesign D-Control demonstration (they call the controller now "D-Control" and the whole system ProTools/MicPres/Intrefaces is "Icon"). They still didn't implement the touchpads but the digi-guy showed me the physical sice of the pads with his hands... it seems, they'll be about 6 Inches of sice. Greets, Roger -
Harrison patented joysticks FOR MIXING APPLICATIONS not joysticks at all  ;) 1996 Harrison introduced first automated jostick in mixers (patent pending) 2000 Harrison is awarded the patent for automated motorized joystick innovation http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1084655389;start=6#6 http://www.glw.com Me personally don't care about patents, since I don't sell my MidiBox. But the price smells much better than the one for motorized joysticks.  :P ... I think it's not the same junk-feel as on a laptop because the resolution of the distance of movement can be much bigger than the max. controller value range. Or like it bigger? http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1098688897;start=0#0  ;D Greets, Roger
Hey Seppoman ... just bought two of them ;D Thanks for the information and the tipp Greets, Roger
... for PC or MIOS? Greets, Roger
... Geld ist schon wieder zurück gekommen... und wieder minus CHF 50.00 >:(  >:(  >:(  >:(  >:(  >:(  EDIT1 Werde nächste Woche mal bei der Bank vorbei gehen und nehme die Unterlagen mit. Dann sollen sie die Zahlung (mit den entsprechenden Daten) ausführen. EDIT2 Habe das mal auf 2005 verschoben... musste mich über die Festtage wieder mal mehr um meine Familie fümmern ;)
... search the archive for "low power" or "PIC18LF452 I/P". There have been some articles about that. Greets, Roger
... please keep us informed ;) Greets, Roger
http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1080247144;start=5#5 Greets, Roger
You can download their CAD Software, plan your stuff and the Software will tell you the price. - So you can try out different designs fitting your budget. Greets, Roger
http://www.ucapps.de/midimon_en.html ... den Timecode lässt Deine Host-Software raus. Eine andere Lösung fällt mir nicht ein (sonst vielleicht mit MIDIOX). Greets, Roger
Thanks A tile cutter is not a high RPM saw right? And it has much finer teeth (if even) than my blade. My plade is hardend steel. It's o.k. for aluminum but for epoxy :-/??? I think I give it a try, while hiding my face behind a wall ;D Greets, Roger
Thanks a lot! ... I thought, that theoretically it shouldn't be a problem, since I use the LEDs only for light emission and not as a diode function. I also know, that there is more to think about than just within the fences of my basic electronic understanding ;D... that's why I asked ::) Thanks guys... I'll give it a try for LED rings in my MIDI-Box LC design. Greets, Roger
Hello Can one of the electronic experienced guys tell me, about it's a problem to use this LED (BR2262S)from "Voti" with the DOUT module, since the reverse voltage rating is only 4V? http://www.stanley.co.jp/device/pdf/led_lamp03/2262s.pdf THX in advance Roger
Hey Vercengetorex I'm also thinking about some modular parts for a LC. Where are you standing with your project? Did you experience any trouble with the cable lengh of 4ft? Does anybody know, about I could run into trouble, when I split the Motorfaders (4 and 4) too and mount them in different cases? - I expect a max. cable lengh of 3ft. Greets, Roger
Well I have a vacuum cleaner attached to my saw. But before I try to cut them with the saw, I wanna be shure, that there is no risk that the epoxy boards break in small peaces and them sticking in my face :-/
Hi I never cut PCBs by myself. What's the "right" way for pertinax and epoxy? Can I use a high RPM circular saw like this one: http://www.selbst.de/fstart.php4?inhaltURL=/flexgrund.php4&links=http://www.selbst.de/8lexikon/heimwerker/lexikon.php4?id=900&rechts=/8lexikon/sucheheimwerker.php4 What are you using? Greets, Roger
... warten wir doch mal ab, ob die Ware überhaupt kommt (bin zwar zuversichtlich) und ob die Dinger dann mit MBox auch laufen :) Falls dies alles erfüllt ist, werde ich zuerst SmashTV kontaktieren. Er hat mir mitgeteilt, dass er Interesse für seinen Web-Shop hat... das würde das ganze vereinfachen, da er für "Sammelbestellungen" eingerichtet ist. Greets, Roger PS: Ich melde mich dann, wenn ich die Displays habe oder wenn's wieder Komplikationen geben würde.
@Jack Sorry, habe ganz vergessen Deine Bestellung zu quitieren. - 8 Stk. für Dich sind bestellt. Du brauchst mir nur die Kosten für den "in-Europa" Versandkosten und die Ware zu bezahlen. Die Banküberweisungs- und Überseeversand-Kosten werde ich übernehmen. Je nach Preis für eine eventuelle Grossbestellung, werde ich dann versuchen, die Promärkosten abzuwälzen... mal sehen. Greets, Roger
Heya Jack Another project? Developing on accoustics and psychoaccoustics? ... oh my god...please not! - I hope to get my LC Controller finished before MIDI 1 dies and my host SW doesn't support this control protocol anymore ;D :-/ :-[ ::) Greets, Roger
@Seppoman ;) yes.... how did you guess? @AndrewMartens ... if it works for you and you're work/product is exactly the way you want... You must be the happiest audio engineer around ;D A petty for me is, that I'm doing a big range of audio material. Professional: speach, layout and drama production / parttime professional: music / and now: (not making money yet  ;) ) movie sound. I think this gave me an even harder time selecting than I experienced ever before.  ??? I hope I stay happy with my Tannoy Ellipse system  8) Greets, Roger
... this one is easy to answer... good luck  ;D :-* ;D Greets, Roger PS: I think the questions will follow later...???  8) EDIT ... now you posted the questions ;) Yes: http://www.ucapps.de/mbhp_lcd.html don't know Traktor http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=parts_q;action=display;num=1100192720 Greets, Roger
