![](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Screaming_Rabbit
Frequent Writer-
1,431 -
Everything posted by Screaming_Rabbit
... ja, da müsstest Du mächtig kühlen :) Grüsse, Roger
Witch motorized potentiometers should i use?
Screaming_Rabbit replied to Karl Johan's topic in Parts Questions
http://home.datacomm.ch/screamingrabbit/Pages/UCAppsBulk_Order/ALPS/Datasheets/RK25T12MO.PDF You get that from Albs.de... I couldn't find them on the Alps site anymore, so I don't know if they're still available. Fairlight uses them for the DREAM consoles http://www.fairlightau.com/downloads/public/NEW%20Constellation%20brochure%20for%20WEB%20VIEW.pdf Greets, Roger -
... you can buy the ALPS highspeed pot. Problem: nobody tried it yet expensive possibly hard to control with the current fader driver and implementation (see ucapps/MF) Greets, Roger -
Hey I'm looking for a Tascam PCI-822 or similar TDIF card (must be XP campatible/driver) for a good price. Greets, Roger EDIT: Found one on E-bay
Hehe... schon vom MIOS-Virus erfasst. Dir ist schon klar, dass es da kein Zurück mehr gibt? :D
... think about the cable length! Greets, Roger
Search the forum... I think there are some threads around about Freescale. Greets, Roger
I don't like Vista at all but I use it on my tablet to stay up to date and since Vista is very advanced in touch features compared with XP-Tablet. But I have to say, that it runs very stable here. A problem I see for developing is, that a lot of nice and pretty freeware developing tools are not running on Vista yet or even might never be adapted. Greets, Roger
MB-LC: Multipleyfrequenz der 7-Segment Anzeige
Screaming_Rabbit replied to Amiga-Falcon's topic in Deutsch
... weiss nicht genau, was das mit der MUX Frequenz zu tun haben soll. Normalerweise ändert man da die Pulsweite und nicht die Frequenz. ... die Matrix ist ja auch fast doppelt so gross wie die der 7Seg ... hääähhh? ??? Wie wärs, wenn Du die Dinger einfach mal bestromst und mal schaust, was sie ziehen wenn die gewünschte Helligkeit (Widerstand) erreicht ist? (... oder eben im Datasheet schauen) Grüsse, Roger -
Was sagt denn das Datenblatt der "schlechten" LED-Displays? - Leuchtstärke, Strom... Dass die LEDs nicht "mitkommen" sollten, kann ich mir nicht vorstellen. Wenn Du die Frequenz herunter schraubst, wird es einfach länger gehen, bis die entsprechende Diode wieder dran kommt... also nicht wirklich was gespart. Grüsse, Roger -
http://www.netzmarkt.de/thomann/prodbilder/151261_manual.pdf Start auf Seite 119 (Save usw. auf Seite 122) Grüsse, Roger
... er hat ja nicht nach dem 452er gefragt, sondern nach dem 4685er. http://de.farnell.com/microchip/pic18f4685-i-p/8bit-flash-mcu-smd-18f4685-dip44/dp/1332274 ... bei mir heisst es: 110 Stk. verfügbar Grüsse, Roger
... so why are you asking us?
... very valuable reply on a post which is 4.5 years old ::) It seems to me a bit like you're replying to many posts with nonsense comments. If you're hunting for stars, I actually don't care but it pisses me off to read through the forum and look for "new" posts, just to find "sweet" and "cool" or other BS. Greets, Roger
1. Yes they exist without detends too 2. I wish you happy implementing ;D 3. What advantages should it bring besides being just much more expensive than encoders? ::) Greets, Roger
... absolut berechtigte Frage. - Select per FaderTouch ist nur eine Option...also Böhrerchen und Feile raus aus der Schublade und... ch...ch...ch...ch... messen und wieder ch...ch...ch...ch... :P Grüsse, Roger
... deshalb meine Antwort :o: Grüsse, Roger
Hast Du nun Logic oder noch nicht? Wenn ja, probier es doch einfach aus. Der Touch für z.B. Track1 im Mackie Protocoll ist default [$90 68 7F]. Du kannst das z.B. mit einer Shareware PC-Keyboard-to-MIDI Software über MidiYoke tun. (Ich weiss nicht, ob man auch mit MIDIOx befehle senden kann... denke aber schon) Grüsse, Roger PS: Bei Sequoia muss ich es definieren, ist es also eine Mode, ob der Track bei FaderTouch selektiert wird.
... auf jeden Fall aber das = $$$ ;) Grüsse, Roger
I have no idea about the compatibility. If I look at the Microchip site, I don't see a reason, why they should not deliver you a PIC18F452 from their Singapore office. Greets, Roger
Rein evolutionstechnisch braucht da auch nichts mehr zu stehen... die Arbeit ist geleistet :D. Alles weitere ist Luxus ;D
... warum? Auf dem Foto stehen sie doch wieder und wieder ;D @tongenerator: ... nicht ernst nehmen, nur ein kleiner Scherz
Der Abgriff ist in jedem Fall [2]. Gnd & 5V kommt drauf an, wie Du den Fader einbaust (was oben/unten ist). Grüsse, Roger
... here is the example for what Cimo is talking about. http://ucapps.de/mios/j5_din_v1b.zip Greets, Roger
