ganchan
Programmer-
473 -
3
Everything posted by ganchan
i've re enclose the encoder, now it's like new but the grease that was inside is very dense and make a good resistance. i need to found a good dense grease. my grease is to soft and the encoder now turns too fast for me :) so scream, tnx for the input but i've just put my grease inside :P. very few, i'm so careful doing this, but i think i must use another type. any suggestion?
I had a big problem with my XT. He is hard used and the cutoff encoder do not run the value step by step but, it jump to max to quite min if i turn up fast and vice-versa. i've open it and clean, now it work but: what kind of 'oli' (grease) is the one that is inside? new encoders have too. this kind of encoders are hard to close like was by manufacturers. now there is a micro tic because the little metal enclosure are not so heavy. some photos. more photos later.
for rare parts absolutely not :) this type is the one that waldrof use in him synths :) nice
Still need some ALBS knobs for the MB-6582? 2nd European order.
ganchan replied to Goblinz's topic in Bulk Orders
i need 6 of that, i can exchange with some x0x rare or.. who knows! -
sure, i will :) x0xBOM updated on 03 06 2008 for prices and obsolete. here there is my BOM for mouser of all the parts that you can buy, hope will help. there are 2 kind of resistors, 1% less noise, 5% original 303 ones. there are 40 + resistors 10k ohm for leds, you can mange them. there are fo 74HC* different options by manufacture. include the Pots, so if you don't want the x0x original you can omit. obsolete parts are replaced. just copy/paste into mouser inport BOM from the 2 columns like this example: 595-CD74AC174E 1 mouser# (space) Qt must go to work now 8)
hey Goblinz, i've PM you too 'for a while'. :P where i suggest you to take part on mouser if Prof do. it's cheap than digikey. i've a list of all parts that you can buy on mouser if you need, only few things are digikey 'only' but Prof probably can order over it too. so i can stop waiting for you on my bulk? ;) i'm collecting some rare too, let me know.
somebody interested in x0xb0x PCB`s (BATCH CLOSED)
ganchan replied to Sasha's topic in Miscellaneous
who do you translate "I've used the same part but with the metal bushing and it works fine - the bushing clears the panel. "? i'm not sure about clears the panel. it seems that the metal bush fit exactly with the bottom of the panel touching it? ??? -
ops sorry, haven't read this last post! i will up a .zip ok? do you use win or mac or linux? http://www.inventati.org/ganchan/tmp/digikeyBOM.tar.gz inside there are, ODS XLS HTML PDF of the BOM. updated n°4 1% resistors like ladyada BOM list suggest and final price too. i would advise against buy all parts on digikey, they are too expensive compared to mouser. here some replacement for out of stock parts on digikey: original: Panasonic Part #EVU-F2LFL3B54 Digikey Part #P3K1503-ND out of stock. replacement: (probably) Panasonic Part #EVU-F3LFL3B54 Digikey Part #P3I9503-ND with midpoint detent. Panasonic Part #EVU-F2MFL3B54 Digikey Part #P3G7503-ND metal bush Panasonic Part #EVU-F3MFL3B54 Digikey Part #P3E5503-ND metal bush mid det original: Panasonic Part #EVU-F2LFL3D54 Digikey Part #P3L2503-ND out of stock. replacement: (probably) Panasonic Part #EVU-F3LFL3D54 Digikey Part #P3J0503-ND (not RoHS) with midpoint detent. Panasonic Part #EVU-F2MFL3D54 Digikey Part #P3H8503-ND metal bush Panasonic Part #EVU-F3MFL3D54 Digikey Part #P3F6503-ND metal bush mid det http://www.panasonic.com/industrial/components/pdf/aok0000ce4.pdf can be the detent removed? -
from the ladyada forum: "1% resistors are less noisey and less prone to drift so if you want the original noisey and out of tune characteristics of the 303 you should get the 5% but i cant imagine why youd want that." "yes you'll be alright. If you want a true 100% clone then you'de have to go with the 5% carbon - at least in the analog voice circuits (vco/vcf/vca etc..). Probably the difference in tolerance is the biggest thing. You'll be absolutely fine with the 1% metal film." -
probably i will order original one pcb for friends in the next month. if any one want one i will order for him too. stay tuned.
SoundWell rotary encoders (like ALPS STEC16B, "Voti" encoders)
ganchan replied to Wilba's topic in Bulk Orders
i will make some goodest photos and update the wiki. ;D -
they are perfect. there is no reason to remove completely the iron round of the mechanism. just beat it and make flat. here some pics, not very good but this is the way. -
hi! nice.. i love waldorf sound from ever. absolutly not like 'standard'. at now all MEGA synths are going to be too similar in sounds, they have no original timbre, 1000 voices, 2000 LFO, 3000 OSC etc. wft i don't need an orchestra. waldorf synths have many but not excessive module, but instead extreme matrix and stuff like that. my favourite XT rack, and Micro Q rack (the yellow!). so, had you make a photo of that little button under the panel? it seems like the MQ ones. i haven't now a MQ under my hans, but they seems cool and much little to use for DIY. thankyou! p.s. i've an XT, will make some photos but i know there are't much things inside. :p
yes i'm crazy: link updated to post #290 at digikey for 1 x0x all parts are €88. just left 2 dual pots, stereo jacks, socket. at mouser for 2 x0x all parts are $97 (€63). just left digikey only parts and some minor stuff. the digikey only parts are €37.66. the toggle switch, tantalum & cercamic capacitors are present in digikey and mouser both, in ladyada site are just specific. -
;) no prob. i'm waiting for some estimates. italian seller are slow, they don't itch to work. i've bought some parts for testing instead.
http://www.inventati.org/ganchan/tmp/x0xRareParts.xls micro$oft excel http://www.inventati.org/ganchan/tmp/x0xRareParts.ods OpenOffice Calc download, insert the n° of needed parts, send to me by email. i will calculate the final price and i will tell you. 8)
alè! che cosa hai realizzato fin'ora? :) io di elettronica so molto poco, da quello che ho capito tu invece ne sai, quindi verrai tempestato di domande! almeno da parte mia. ;D a presto! io sono di RM cmq. piacere Giovanni.
update: 2SC536F at €? (€0.10) & 2SC945P at €0.10. Shipping €6.50. (i'm buying some for test if are genuine). 2SC2219 at €1.54. Shipping €10.00. (if i buy 10 will be €2.10 each). 2SC1583 at €1.40. Shipping €12.00. (if i buy 30, x0x need 3, will be €1.80 each). 2SC1583 at $0.73 (if n°30). Shipping $8.35 or $12.45. (if i buy 30, x0x need 3, will be $1.028 each. The source is cpcare). 2SK30A(Y) at €0.84 & 2SK30A(0) at €0.76 & AN6562 at €1.25. Vat 17.5%. Shipping £5.50. (This are the only things that i haven't find for cheap in IT. The source is dalbani). AN6562 at €2.10. Shipping €3.90. (if i buy 20, x0x need 2, will be €2.295 each). LA4140 at €0.43 & BA6110 at €0.86. Shipping €4.00. (they have just 8 ). 2SA733AP i've requested many quotes, buy just one had answer: 2SA733AP NEC NEW 100 6-9 days 3.05$ each -> 305.00$ 2SA733AP NEC NEW 500 6-9 days 0.73$ each -> 365.00$ Please don't PM me! I will post an .xls .ods soon. Just read and think about!
ciao ris8, finalmente un altro italiano, e che a quanto pare ne sa! :)
that was something sound france, in italian sound perdonami :) -
ops sorry! i've do a mistake, pardon me. my english it's not good so i always think that people don't understand me so much ;) -
thankyou, they are cheap but have you test them? asaf i was talking about tact swiches, not the waveform toggle switch. :) B12AB-RO-ND this one is suggested on the ladyada site, do you think that it's not replecable? it's out of stock for now at digikey like the 16pos. -
what do you think about replaceing the tact switch with the omron B3W-4050 or B3W-4055? some people had wrote on the x0x forum about some problem with the original ones, from e-switch i think? -
Nice game LoopStar! I know the big change is from some of the 2SA733AP or P or.. in some Qx position in the x0x, all documented on ladyada site, so i don't explain here a second time :p Wich one do you had used for this 2 x0x? Thankyou for the waves. ;)
wow 51GBP! :o
