QBAS
211 -
Everything posted by QBAS
hi we welcome at board. You can simply connect two (or more) cores in http://www.ucapps.de/midibox_link.html qbas
Hi brother, we welcome at forum. Thank you for putting interesting links. I just looked for printed alu panel. It isn`t printer cable. It`s cable with connector for socket at pcb on PIC burner. When you will buy soket take alerady cable. 1:1 mean male - female LPT. yes. You can choose your prefer app or modify, customize. You can ground unused AINX pins for avoid problems or setting number of pots in a code. Remember to set muxed or if you not use AINX unmuxed good luck!
Browsing functions and possibilities of many ready to use programs is nice , but probubly earlier or later anybody will feel boring and need changing something. Of course programs has many options for customize, but if it is not enough for you = its time for looking better method for creating music without (or minimal) compromise. If you have a dreams about better technologies for music creation just DIY!
If you are owner and you really need run - better stay with widows.Of course you can try run it with wine or other emulator on gnu/linux ;)
henrygr, It was in assembler, 100% based on TK`s source. I plan learn C for MIOS and PD. I remember TL`s SRAM - it inpired me. thank you
hi everybody I`m go out from windows 10 mounth ago to gnu/linux. My favorities programs on windows: logic, TC plugins, reactor, kontact, wavelab... I leave them all becouse I have no money for buy. They are very good, but I need better: more plastic, open tools. Now I`m also free from cracks. :D I think that no difference between distros. If you are good, and you know how to set system - you can prepare any distro for music. Becouse I`m not an expert so I use alerady prepared: ubuntu studio and pure:dyne. PureData - it is my favorite music program now. At this time I leave others jack`s based synth`s, daw`s... and focus only at PD. I hope this will be inspire somebody
dokladnie tak ogolnie tak , ale niekoniecznie. mozna zrobic matryce - wtedy juz potrzeba 16 pinow do 64 guzikow. drozszy bo czesci wiecej kosztuja, oprogramowanie jest darmowe, niesamodzielny bo bazujemy na systemie od Pana T.K. - Zrob to sam :) http://www.ucapps.de/mios_download.html - tu sa programy. pozdrawiam
mialem na mysli DINX4 - 32piny DINX3 - 24 piny itd. dynamiczna klawiatura potrzebuje 2 przelacznikow pod kazdym klawiszem. mozesz osiagnac to co potrzebujesz za pomoca obu projektow. sa zalety jednego i drugiego. jesli chcesz to mozna nawet 1024 klawisze podlaczyc. ;) generalnie ja polubilem te modulowosc z tego projektu. dzis myslisz tylko o klawiszach , ale jutro przydadza sie tez diody - wtedy tylko zmiana w kodzie i dodatkowy modol DOTX4 i 32 diodki swieca. itd - liczba dodatkow spora, plus te wspaniale aplikacje - emulacja Logic Control. zachecam do naszego projektu. jest drozszy i niesamodzielny (bazuje on na MIOS ktorego nie mozna opatentowac - juz jest zastrzezony), ale za to jest prosciej.
tak - sa one zbedne - chyba ze w przyszlosci uzyjesz je jakos - a poki co beda np niepodlaczone. kanaly jak i wszystkie funkcje mozna po zaprogramowaniu na stale dodatkowo zmieniac np przelacznikami lub np w menu na lcd. - tak - choc mozna uzyc kazdego innego tak samo - jednak uzytwanie tego outu z core modulu daje mozliwosc bez przepinania kabli updatowac software (np wgrac nowa wersje).te 32 przelaczniki podlaczasz do DIN4. Zobacz na stronke http://www.ucapps.de/mbhp_din.html - tam jest na schemacie. Oczywiscie lepiej jest zrobic skanowanie matrycy (tak jak u J.M.- lub w innych projektach z ucapps.de) - mniej elementow itd, ale tu masz 1 pin do jednego klawisz (przy zalozeniu ze nie dbasz o to by to byla klawiatura dynamiczna). pozdrawiam
nie nie, ja raczej sugerowalem: czyli core + DIN4 + 3-do 4 midi in,out+midi in out na core module. Razem daje 4 do 5 midi in out+32 styki na oprzelaczniki :) Jest to kompletne rozwiazanie - poczawszy od poprowadzenia kabli od klawiatury do DIN4 modulu - poprzez podlaczenie 4 dodatkowych midi in out, a skonczywszy na glownym midi in out - czyli pelniacym tutaj funkcje master enterfejsu midi. Pozostaje zaprogramowanie - czyli zabawa z miosem i kompilatorem. Niepowinno byc problemu przy tak prostym ukladzie. szacunek mam dla projektu Janka Muzykanta. Tu jest wszystko proste i gotowe - szczegolnie oprogramowanie. To jest alternatywa. Ja pozostaje (narazie) przy microchipie, jak zaczynalem nie bylo az tak dokladnej strony Janka M. Na tym etapie nie przesiade sie gdyz MIOS daje mi sporo zaoszczedzonego czasu jesli chodzi o zaprogramowanie uzadzenia. Sam uznaj. NIe wczytalem sie dokladnie jak sie programuje uklad J.M. ale jesli chodzi o pica to za pomoca MIOS mozna wycisnac sporo. Niewiem czy J.M daje taki duzy support programistyczny jak to forum. zobacz dzial: assembler, C. A tak nawiasem to nie rozumiem dlaczego przekrecasz to co napisalem? jesli wczesniej napisalem 3-4 IIC midi, to czemu piszesz 2 IIC? pozdrawiam
Witamy!!! Oczywiscie ze dobrze. Wystarczy: 1 core module 1 DIN4 3-4 IIC Midi Module Pozdrawiam
spoko - ja równie? czekam. na razie montuj? w sklejko pleksi, ale to nie wygl?da dobrze.
mnie nie kusi. Oczywi?cie cz?owiek ma takie sk?onno?ci by mie? wszystko co najlepsze , ale ta p?ytka wygl?da znajomo - w sumie jakby to samo co nasz CORE. Mi wystarcza PIC18f452, jest tu dobrze udokumentowany + MIOS!!! ;D
W Conradzie zamówi?em motorfader Alpsa i po tygodniu mam go , za 99 PLN. Jeszcze nie sprawdza?em jak dzia?a itd , ale ju? le?y u mnie na biurku. ;D
Ok, I see in your pdf 1 sec, so please see to pdf from conrad site: http://www1.conrad.de/scripts/wgate/zcop_b2c/~flNlc3Npb249UDkwV0dBVEU6Q19BR0FURTAzOjAwMDIuMDE4Ny42OGNlNTJlOCZ+aHR0cF9jb250ZW50X2NoYXJzZXQ9aXNvLTg4NTktMSZ+U3RhdGU9MzY5ODYzMTg5Ng==?~template=PCAT_AREA_S_BROWSE&mfhelp=&p_selected_area=%24ROOT&p_selected_area_fh=&perform_special_action=&glb_user_js=Y&shop=B2C&vgl_artikel_in_index=&product_show_id=&p_page_to_display=DirektSearch&~cookies=1&zhmmh_lfo=&zhmmh_area_kz=62&s_haupt_kategorie=&p_searchstring=&p_searchstring_artnr=442016&p_search_category=alle&r3_matn=&insert_kz=&area_s_url=&brand=&amount=&new_item_quantity=&area_url=&direkt_aufriss_area=&p_countdown=&p_80=&p_80_category=&p_80_article=&p_next_template_after_login=&mindestbestellwert=&login=&password=&bpemail=&bpid=&url=&show_wk=&use_search=3&p_back_template=&template=&titel=&darsteller=®isseur=&anbieter=&genre=&fsk=&jahr=&jahr2=&dvd_error=X&dvd_empty_error=X&dvd_year_error=&call_dvd=&kna_news=&p_status_scenario=&documentselector=&aktiv=&p_load_area=$ROOT&p_artikelbilder_mode=&p_sortopt=&page=&p_catalog_max_results=10 http://www.produktinfo.conrad.com/datenblaetter/425000-449999/442016-da-01-en-MOTORPOTENTIOMETER_RK27112MC_10KBX2.pdf Is it conrad`s motorpot bad? -what you mean? is ALPS RSAON11M9 bad?
Hello Thorsten! I would like to include in my box section with 8 rotary pots. Becouse I will change the pages I think about to use ALPS 10KBX2 motorpot, so my question is: are they not too slow for fast operations? I worried about this becouse I read in specification that ALPS 10KBX2 need about 12 sec for 300 degree. What is your opinion? thank you qbas
100 lat, 100 lat niech ?yje, ?yje nam! 100 lat, 100 lat niech ?yje, ?yje nam! Jeszcze raz, jeszcze raz, niech ?yje, ?yje nam! Nieeeeeeeeeech ?yyyyyyyyyyjeeeeeee naaaaam! All things the best for you TK at your Birthday!!
za darmoszk? - tylko pokryj koszty przesy?ki - lub dostarcz je jako?. Mieszkam w Warszawie
witam mog? zaprogramowa? pica jak chcesz pozdrawiam
Not now, but I`m seeing that it is a good time for start using it. I`ll be informating about it. :)
SounDuke if you can help me with FATAR - I`ll happy. I`m really interested in possibility to buy one. Now I see that on the fatar.com is many different keys. So - I of course would like to buy the best hammer action keys but if this is to expensive then I`ll think about cheaper. Please, can you get all prices , or most of - if is this not to big problem for you? OK - I was lazy with find image hosting site, but now it is past. The diagram:
Yes - FATAR is look really good! I`m interested in TP/40WOOD price. I`ll send you diagram tomorow, wires are the same like regular srio (J8,J9). In SM_NotifyToggle section
Can anybody tell me where is the best place to store files for share? eventually I can send you email with scheme (worst case) Please don`t do a secret of it ;) SounDuke can you give any link for the keyboards, and prices?
super :) zrobi? co? samemu to jest to! gratuluj?! ... ciekawe jak b?dzie wygl?da?o ca?e urz?dzenie...?
