Altitude
    1,184
    30
Everything posted by Altitude
  1. So I've decided to let this go. Its a rev 2 PCB so there are a lot of bugs all of which have been fixed EXCEPT the cymbal. It works, but its not right. I have the eagle stuff and schematics but I just dont have time to work on this anymore so its sold AS IS. (not all the jacks are installed, they will be when I ship) its 115V AC powered Includes an extra overlay, i had 2 made just in case $450 (less than half what I've spent on it) CONUS preferred.
  2. nice. Need to start paying more attention here, lots of great projects slipping under the radar
  3. any 10 pin female header that style will work, the height on that one wont matter
  4. no compensation needed. I know how these things go. I wish I could have found the actual spot where it was shorting, it definitely wasn't a board problem since I did inspect the underside pins after I cleaned it off and it worked with the new header so that only leaves the solder bridge and that fits the symptoms. Checking for shorts to adjacent I/O pins would have identified the issue, might be worthwhile to spot check a couple in inventory to make sure it was just a fluke and not a batch thing. anyway, that's that.
  5. Solved! And this is some crazy ass shit too: I was friction fitting the core with the mainboard to see if removing the TVS fixed it (it didnt) so the plan was to try the temporary headers like andy suggested with the minimal setup but my trimmed down, solder coated ones were not fitting the sockets i had so I decided just to put new headers on the core, not a big deal, suck out the solder and pull the pins out one at a time. When I did the first row and pulled off the plastic header there was a fair amount of solder where the plastic was (like it puddled there). I just ignored it thinking it was from the desolder gun and cleaned it all up but after the clean up, and new headers, it fired right up. In hindsight, there was way more solder there than should have been, I was sucking out solder through one end and pulling the pin out through the other, what was left there after I removed the plastic was in the shape of the plastic header like a mold, there is no way that came from the desolder gun especially since it sucks solder out or from any other soldering I did since those were on the other side of the header. I checked all the IO pins for shorts to ground and +5 but NOT to each other which seems to be what was happening here, must have happened in the wave machine when those headers were soldered on at the factory. Just dumb luck i decided to replace those, I would have never found it otherwise, should have taken a picture
  6. good idea. I want to triple check everything before I put the core back on. I use the same diode in a couple device i sell but the list of possible suspects is getting short.
  7. was the alt-page thing ever fixed? so you could scroll up and down in note view?
  8. I cant find anything wrong with the connections on the mainboard, no shorts, no weird resistance. Here's pics of the core. Yes I am aware its set to USB (i was testing it without the mainboard)
  9. >..Before you desoldered the Waveshare daughterboard, i would have guessed the STM32F4 might have been a dud, maybe bad flash memory... But if it starts up and boots the app when powered by mini USB, that's clearly working. And as you said, it must be some connection to the USB port... I thought that too so I swapped the STM chips and it behaved the same way so it wasnt the chip. That was further proven when I took the core off and that worked by iteself. Its something on the mainboard thats hanging it up.. >did you have the onboard Waveshare power switch moved from "USB" to "5V In", when it was installed in the LoopA core? yes. now that the core is off I'll trace back to the USB socket when I get some time. Either its something stupid that I missed (likely) or some weird edge case issue (unlikely)
  10. > Was the v407 breakout actually soldered in? If so, impressive that you managed to get it out so well! Yeah, it wasnt fun. Hot air FTW
  11. ok, some more developments. > Could you try to use another computer and another USB cable for uploading? tried it, no change in behavior. > could you try to enter bootloader hold mode and try to reflash from there? Just got this tip from Robert. You'd need to populate JPA0 and R101 and R102 on the core board and jumper JPA0 - then you should see the bootloader in MIOS studio and could hopefully try to upload again. Just to clarify, I have always been able to see the bootloader ports and upload code. It will occasionally (like 1 out 20 times) start the app with the miniusb directly connected to the core otherwise only the main usb goes as far as the bootloader ports showing and accepting an upload but beyond that its not working right, I cant send commands through MIOS studio. It just does nothing when I enter commands other things i tried: wipe the core, reflash the bootloader with the STlink (no change in behavior) Change the STMF407 (no change) I finally pulled the core off and that tried that by itself and it fired right up with the mini USB (Loopa midi ports available), and normal MIOS Studio terminal behavior so it looks like the issue is somewhere on the main board that's halting the core. Ive gone over it several times and dont see where the issue is, need a fresh set of eyes.
  12. Im not sure where to go from here. 1. Power good. 5V and 3.3V where marked 2. rehit all joints on the header, no change 3. Orientation of TVS is correct 4. 22R resistors are fine 5. Tried various USB cables/multiple computers Other observations: the app started once. This was with the mini USB direct to the core, i could not repeat this behavior I can no longer get the miniUSB to do anything, it will start the device since the power led will fade in and out but no USB devices show up nothing is coming out of the midi ports with the main USB connected, I get the upload request over USB and feed back when I send the hex but I cannot send any other console commands to the bootloader (i.e."help" does nothing) Does your core = the STM discovery core? As in does it take the same bootloader?
  13. Tried all those already including reflashing the bootloader. I'll go over the core header again
  14. > could you check if you're using the newest MIOS Studio 2.4.9? Check. >Another idea - are you by chance using a Mac no >connect a mini-USB Cable to the waveshare daughterboard Ok, here's where it gets weird. That DOES work. The app will boot and I will get the Loopa ports now. So that means that the main USB seems to be working but there is something hanging up the core preventing it from starting correctly.
  15. yeah, its right. This is weird, its like there is something up with the hex file.
  16. when I'm programming the core, I cant seem to get the program to stick, I see the ports in the MIOS studio, I can query the core, get the upload request and I can send the project hex but after its done and I power cycle it, i'm right back to the bootloader like there is no app, thoughts? PS: Peter, you should look into a side hustle doing ASMR stuff
  17. 12v is fine.
  18. Nice. That's exactly what I had in mind. PM'd
  19. very cool. PM me an SVG of the cutout for the display and I'll layout a snap in window Are there options for the switch caps? (i.e. a source)
  20. @latigid on I didnt get that far. The TI parts good and proven (all the MI stuff, OC, Performer etc) so I wanted to use those parts. They would need a driver for sure but again, given all the STM based hardware out there using them, I figured they would be a good choice since those could be used as a guide
  21. I'd just use my aout euro panel, that has all the shift registers, jacks, and line driver already on there, the old aout just plugged into that
  22. OC is VERY similar to yarns but those are all 4 channel devices.. The way I went about it it was just like this thing: https://github.com/westlicht/performer-hardware/blob/master/sequencer.pdf 8 channel 16 bit DAC (DAC8568) and same output stage as Yarns using the internal reference of the DAC (Not the power rails like AOUT, yarns uses an external reference also). I started working on the board but other things got in the way and its on hold. It was a small modular type device that was supposed to be plugged into the back of my 10hp breakout
  23. My euro design really fell apart since the orginal AOUT design used the power rails as references for the trim and offset pots and while that worked fine on the bench supply, when you put that in a big rack the noise on the +/-12 power rails made the device unusable. Hopefully you dealt with that accordingly. I did revise mine based on Yarns (actually, the same circuit is used in the Performer which is just an 8 Channel DAC with the same opamp staging) but never finished it.
