727 -
9
Everything posted by Rio
I'm talking about the visuals VU-Meters on slaves which are belongs to master, this could be annoying by choosing new sound elements on slaves and it's not a removing feature. It's my position and not more.
hey are you developing the asm-source? let TK decide. it's an inquery of one(!) flag!
Does i really need a PIC18f460 PIC for Midibox V2? So than I've to change the PIC18f452. I've some reservations about changing from V1 to V2: 1.Is it possible to run PIC18f452 and PIC18f460 together in one MidiboxSID? 2.Is it possible that Core-Boards with PIC18f452 (older) and PIC18f460 runs with same new application? 3.I don't know, how you would built up so many boards in one breadbox chassis ;) 4.The most new feature is the stereo feature, right? Will the old MidiboxSID-application developed further? (I don't want to change all my SID Creations - only max. one Core-Platine with 2 SID) 5. Can i use my old CORE-boards for new V2?
thats ok. But most sadly, i don't see the slave VU-Meters, so the VU-Meter option is for me secondary. 1. So how can i assembly the source, so that the VU-Meter is first at start of application are deactived and the settings for matrix are visibled. 2. It would be nice, if i choose the 2nd, 3rd, 4th SID, that the VU-Meter will be deactivated automatic, because its only a information of the master. If i go back to the 1st SID the VU-Meter should than be shown again. If no VU-Meter are activated on master, then nothing should happen on changing. ;)
I've tested beta_15, but don't know, whether this is corrected in last version. The LFO VU-Meter looks nice but works only for MASTER-Core-Board. If i choose the next core's (SLAVE ID:01,02,03) the VU-Meter aren't changing, representing the settings for MASTER-Core further. Another annotation is that all activated or deactived LFO/ENV VU-Meter are shown. It would be better, that only the active LFO enables the VU-Meter, which belonging to it.
würde mich mal interessieren ob die dinger auf dauer was taugen (haltbarkeit).
Ich weiss jetzt auch nicht genau welches Projekt genau deinen Ansprüchen entspricht (vielleicht das MIDIbox64) aber belese dich dazu erstmal. Die Software ist dann für die genannten Bausätze schon vorhanden. Also wenn du weisst was du bauen willst, dann existiert dafür auch schon die Software. Die PIC Software ist in ASM - kein Basic (zum glück!!!) Zu deiner Frage mit MIDI am PC. Es gibt doch USB-MIDI-Interfaces für den PC zu kaufen ;) An MIDI-IN und MIDI-OUT Stecker hängst du die Core-Platine mit dem PIC. Bankstick Speicher ist ein Speicher durch EEPROMs und ist notwendig um Einstellungen deiner Applikation speichern zu können (empfehlenswert und nicht so schwer zu bauen). Der wird auch mit dem Core Modul verbunden.
ja Problem ist, das ich nicht gerade vor dem Test PC sitze. Die Fehlermeldung meint dass der MIOS range überschritten wird und daher die hex in keine syx umgewandelt werden kann. Probiert es selbst bei dem neuen MIOS 1.9 download unter ->PIC18f452->MIDI->und dann die 3 hex-dateien konvertieren (nur die ein funzt, welche vom alten MIOS aufs neue MIOS updated). Das die Fehlermeldung kommt kann natürlich auch an dem begrenzten 7 Bits Datentransfer (statt 8 Bit) liegen. Ich habs nun mit dem MIOS Studio gemacht, auch i.O.
ich mag es lieber auf die alte weise, darum nutz ich eher midi-ox als all den Javakrempel. nun ist ja das mios 1.9 draussen und ich habe einen PIC mit bootloader 1.2. Ich kann aber nicht mit hex2syx die dateien mehr convertieren. es wird ein fehlermeldung ausgegeben, das der MIOS Header oder so die größe überschreitet. ;( Kann einer helfen ? woran liegts? ich ab die neuste Active PErl installiert..trotzallem fehlanzeige !! Gibts irgendwo eine neue hex2syx version..finde hier auch nichts...
What is the difference between a vintage design and a V2 design?
How can I connect them to make them work together with SEQ
how many eeproms do you use for your bankstick? A stays for first eeprom (if you have 8 eeproms, then A is first, H is last [A,B,C,D,E,F,G,H]). Last settings are saved if you use a bankstick, so if you are choose an instrument on eeprom H, then you will stay on H if you turn the device on. the "pliiiing" sound is normal if you plug in your bankstick (every "pliiiing" stays for every identify eeprom).
C32 - Wind Blow let's you feel like in a spaghetti western, if you push first some keyboard keys together and then push single keys in upper area. PS: if anyone can improve these sounds he should contact me.
Wollt ihr jetzt jedesmal für das Ablöten von ICs und Bautteilen jemand das zuschicken? >:( Kauft euch einen entlötkolben (nicht teuer) und probiert das selbst!!! Die Methode funktioniert auch ganz gut. Aber übt das erstmal an irgendwelchen Schrottplatinen ;)
Kann man die beiden Envelops auch für das Volumen des SID (für die OSC) einsetzen? bisher geht das in der modulationsmatrix nur für tone-höhe, pulsewidth und filter.
Ich habe gleich zwei Fragen/Anregungen zur SID-Applikation: 1. Über das Control-Panlel kann man in der CFG das Volumen jeden einzelnen chip einstellen. Kann die SID-Applikation erweitert werden, so dass ein Rotary-Encoder über einen der freien DINX Anschlüsse dazu genutzt werden kann? wäre ziemlich praktikabel um nicht ständig im Menü rumzufummeln, wenn man die 4 chips aufeinander abstimmen möchte. 2. Wenn ich über ein anderes Synthie-Keyboard die SIDbox ansteuere, dann wird beim verändern der Instrumenteneinstellung des Synthie-K. die Instrumente der SID auch geändert. Das nervt ziemlich. Ich muss dann immer das midikabel kurz rausziehen und dannach wieder rinnschieben. kann das die SID-Applikation unterdrücken? Gleicher Wunsch gilt auch für alle analogen Signale. Wenn am Synthie-K. Veränderungen von Filter (Cutoff/Resonance etc.) gemacht werden, dann werden die analogen MIDI-Eigenschaften an die SIDbox weitergeleitet und es kommt dann nur noch wirrer klang von der SID-Box :(
Ja das ist mal so mal so bei den LCDs unterschiedlich und daher in der Beschreibung auch. Ich hatte selbiges problem. PS: IC8085 - was ist denn dis für n chip?, sicher der IC8580 ;)
chiptune gedudel was sonst :) Wie groß wird denn die Party und wo liegt denn gießen? und was kostet der spass.
Hallo, also wenn du eh eine Midibox SID mit 4 Sids baust, musst du gar nicht die J5 benutzen. Da würde ich lieber die erste DOUTX (von den beiden) an J8 verkabelt werden (Siehe Anleitung in Step C mbsid_dout_default.pdf). Wenn du an J5 die LEDs anschließen willst, dann müsste nach der Schaltung auf jedenfall zwischen A0 (... A7) und jedem LED (+) Beinchen jeweils ein 220 Ohm Widerstand löten. Die (-) Beinchen alle verbinden und an Vs anschließen. Hab es aber nicht so gemacht - kann dafür also keine Garantie geben. Ich glaub wenn du das gerät anschaltest sollten kurz alle LEDs aufleuchten. Teste deine LEDs vor allem mal, ob die noch funktionieren (manche Messgeräte können das). Das der SID 8580 ein bißchen warm wird ist bei mir auch so und glaub ich normal. Gruß Rio
If i found a very strange noise -> i ' ll send it to you.
Hallo, ...darf beides nicht passieren - überprüf mal deine verkabelung im bankstick.
4.) Mike brennt nach Wunsch vor dem Versenden schon die Bootloader auf die PICs. Das ändern der ID ist später auch per MIDI möglich.
Gibt es dafür irgendwelche Bauanleitung / Bausätze (PCB etc.)? Das Teil würde mich interessieren.
of course, no problem. Du kannst ja die englischen Teile schreiben und ich mich um den deutschen Teil kümmern. Dann kann man sich gegenseitig zuarbeiten, absprechen und jeweils die fertigen Teile richtig übersetzen. ich kann ja auch ein bißchen englisch.
wenn ich zeit hab, bin ich mit dabei (deutsches manual)
