cimo
Programmer
    1,774
Everything posted by cimo
  1. cimo
    Hola a todos
    la de mi despedida? emmm ... ... .. perdi el avion! estoy en Dinamarca
  2. This just appeared on my gmail account rss: http://synesthesiacorp.com/?_kk=usb%20midi&_kt=43430055-8a03-4f97-a737-d00d311936f3&gclid=CN7jv8K_q5QCFQWL1QodnXo4tA
  3. cimo
    Hola a todos
    hola bienvenido Amando !
  4. Italians do it better! this is a bit offtopic but a little gem in itself http://youtube.com/watch?v=hZZZ8G7AzxI
  5. yeah!!! My Bloody Valentine ended the concert and the possibility to hear any other concert with a 22 minutes rumble/noise wall powered by the excellent Arena s sound system and a mulitstack of marshalls and godknowswhat.. the band was as in good shape as 20 years ago AAAA+++, after more than 12 hours my earing sytem is still shocked (no S1, i didn t use earplugs, i am masochist) after that and a needed pause i went, just out of curiosity to see the Chemical Brothers, they were as lame as usual so really nothing to say. . . oh well i could say &%#/&% you! ... i d like to mention DJ Scotch Egg and his crazy bunch of Gameboys and, i ve just arrived from Supersilent, a noise/jazz experimental band from Norway, thumbs for them ... oh fuck, my ears!
  6. Battles rock! if i may use only one word to describe their act is synchronization, a real pleasure to look at for the hardware geeks out there. Drum player sitting in the front line, keeping up with a DL4 of a guitar player. I was late but i got also 30 minutes of Mogwai and their excellent sound. Tonight My Bloody Valentine, don t really know what to expect. Simone
  7. ... the poor man advise, have you tried to just reload MIOS and start all over from scratch? (got beers in the fridge?)
  8. i ve got the 5mm and the 3mm and they are both ok for the SparkFun rubber buttons.
  9. cimo
    Botones
    dudo que tus botones sean mas feos que yo... tengo pensado en comprar 1kg de silicona bicomponente este verano por si quieres una parte..
  10. si sigues referiendote a algo relacionado con MIOS y/u MBHP lo que escribes es incorrecto: la unica forma de actuar es preguntando directamente al propietario del IP. Simone
  11. cimo
    Botones
    con una cnc no cortas placas de siliconas, tampoco si es laser, solo moldes
  12. cimo
    Botones
    la silicona tiene problema a secarse cuando no hay aire suficiente, el plastico de pistola suele ser demasiado denso para que se moldee (??) (los he probado!) ademas los dos se deterioran con el tiempo la unica solucion es silicona bicomponente
  13. in this case i would trade 0.0005% tolerance cut resistor leads for Kryptonite, or, for what it matters, it could be Kryplateintheevening, i am not in a hurry you know... I ll PM you with details
  14. if I see this guy within 50 meters from Sahira i d take out my sharper knife... now get this:
  15. .. you know i own a favor or two but this stuff is hot, too hot.Need to think about it ok? EDIT: yep my noise to signal ratio is too high, this stuff is amazing, i was wondering if 1.8" HDD motors can be used.Maybe not cause the chassis is embedded in the HD. What about my idea of using "touch" sensitive capacitance system for the wheel?
  16. cimo
    encoders bulk order
    hola RM y bienvenido se agradece ver gente nueva (no que haga falta en verdad) y activa pero alli dice y la fecha es 04 12 2007 o sea hace seis meses, un poco tarde no? lo tendre en cuenta si habran mas bulk order para los encoders Simone
  17. ledtuning.nl common anode though
  18. 25 kits without 0.0005% cut resistor leads for me.
  19. really you have to see these people live, the stuff they released isn t so good, but everybody who s seen them had told me that they give their best in concerts.I m gonna tell you friday night.. Oh well now i go and see Radiohead..
  20. uh! i think i know that scratch wheel down there on the right
  21. NO! ;) ok read carefully: -You need the data sheet for the PLED you want to use.You ususally get it just typing the "model number+producer+data sheet" in Google or if you can access the web site of the producer, then it should be dowloadable there -When you get the data sheet look for the page where the pinout is showed -look up at the pins on J11 on the CORE and connect the PLED Simone
  22. funny enough i don t know any other "solo" work of Sakamoto, but i consider his co-work with Alva Noto among my favorite electronic productions seconded oh well, now going offtopic but
  23. what matters is the driver (and the pinout), it doesn t really matter if it is LCD o PLED -the driver has to be compatible with MIDIBox http://ucapps.de/mbhp_lcd.html -get the data sheet for the pinout
  24. if you are talking about audio+video then the best ever it s been for me Alva Noto with Ryuichi Sakamoto @ Roskilde 2006, footage to be found so it s impressed in my mind, forever.I ve never seen anything like that before.. Any random Meat Beat Manifesto show of the last years kicks ass. (yes it is real time processing of on scene video cameras)
