1,774 -
Everything posted by cimo
hi this brings back the same old problem of the different pads/trace size for diy etching or industry grade pcb. My little-big "dream" would be to create a set of libraries and eagle setup so that you could easily change a "normal" .brd into a diy customized version. Simone Thanks Nils i ll build one, sometime..
hi yesterday it happened to me as well,puzzled for 5 minutes without really understanding what was going on.Those are the small details that are so easily overlooked when you are busy with main things, please follow the link on Stryd_one signature, you ll find some good infos and tips about how to avoid this in the future. Simone
hi it may be that in MIOSStudio you have to address the PIC with the proper header, in your case set the "Device ID" to "0" and change accordingly if your changing the header again Simone EDIT: also remember that using the device_id_xx.hex files that you can find in the changee_id folder after unpacking will set the lcd flag to 0 = clcd
in a few years XFCE may be ported to OSX/darwin
hi is there any NLite like stuff for OSX ? Simone
cool ! Pedro introduced us to the ginja ritual while talking about field recordings and the situation of modern Portuguese electronic scene, after 4 or 5 we were all very happy ;) and Lisboa is BEAUTIFUL !! too bad we missed a gig we were suppose to play in Bairro Alto at the Ze something, it looked like a nice place.. Simone
This is a big step forward for MBHP, no more need for bulky commercial interfaces, awesome, thanks Thorsten!
hi www.voti.nl usually stocks encoders for all the rest here in Spain there is a "sub-company" of rs-components called www.amidata.es but you can also buy from www.conrad.com although their web is not really user friendly i see you live in Lisboa, there are a couple of shops in Lisboa center i don t remember the name of the street but i can tell you that they are in the same street as "casa do alentejo" or something similar, and there is also one of those famous ginja shops ;) the street could be called Rua das Portas de Santo Antão. I am listening to Tsuki, nice stuff, i have a friend in Lisboa, Pedro, he runs the test-tube label, do you know it ? Simone
Random chars after PIC header change and rc20 upload
cimo replied to cimo's topic in Testing/Troubleshooting
Hi i ve filled the 4 pairs of pads with a solder blob so they should be connected to pins 9,10,33,34 Simone EDIT: is there any reason why i should change the header for custom lcd on PICs 2,3 and 4? EDIT: it is now working, but unfortunately i didn t understand what was wrong with it, i ve just reuploaded ID_change and SIDv2 -
hi this is MB6582 related but it could be probably moved to the SID forum, mods will tell After changing the PIC header to use the custom driver for lcd (i use a 8 bit lcd) and uploading the new rc20 to all the pics i get some garbage messages on my lcd it is something like: 0oo//?///?_00 etc etc any idea? Simone EDIT:
... in the OPL3 module page http://www.ucapps.de/mbhp/mbhp_opl3_orderlist.txt
i had the same thought but if there is a voltage drop that would affect the whole box, wouldn it ? and, now that we get to this point: are you suppplying the pots with the same rail as you use for the CORE and AINs? if you would use different supplies for pots/AINs/CORE and having random voltage drops that could explain your issues. Suerte! Simone
Ciao! mi chiedevo se per salita analogica intendi qualsiasi tipo di suono o se hai bisogno di MIDI fonts standard. Simone
hola Pablo no need for scaling!! you are having some kind of AIN issue, fight the problem at the root. To start with, measure the voltage at the right and left pin of the affected pot, check that the pots are OK ranging from 0 to 10KR, check the solder joints on the pots and use good cables to connect them (sometime shielded cables may be a better choice) Simone
Ciao Alessio benvenuto non capisco bene cosa intendi per vediamo se ho capito, tu vorresti per esempio avere un CC in un file midi e la possibilita di passarlo per un CORE ed ottenere un CV in uscita? se e cosi lo vuoi fare con o senza computer? Simone
It is ok for my needs thank you Simone
hi i need the measurement of the SID board sold by SmashTV tx Simone
hi can anybody convert .dxf to .svg ? this is the file i need to be converted http://www.hammondmfg.com/zip/500-0930.zip thanks Simone
i don t know of any 2 hours spent in Eagle that could be considered useless ;)
*cimo knows electronics
hi somebody else has advised 220R resistor to be used, i believe it is a matter of taste of this point, maybe a 220R and a 1KR resitor in parallel could be an idea. Simone
eh, es Bonnie que esta en Berlin sacando temas entre un after y otro. N hay forma (para mi deade aqui) de saber si el BSL esta corectamente cargado pero parece que lo hayas hecho bien. Pasamos a comprobar la parte del power supply: 1- como alimentas el core? 2- comproba que en la patita derecha del 7805 hayan 5 voltios 3- en la pagina del CORE te explican donde tienes que comprobar que hayan 5 voltios en varias patitas del socalo (si lo hiciste ya haz-lo otra vez ;) Por el momento pasa del modulo LTC y conecta la salida MIDI OUT del CORE al ordenador para monitorear, o utiliza el led Por cierto de donde viene la PCB ? http://es.wikipedia.org/wiki/Cortocircuito Suerte con el debugging, pero sal del laboratorio ante de empezar cualquiera viaje lisergico
puedes identificar el archivo que cargaste o sea que aquel tipo cargo en el PIC? que PIC tienes? nos sabrias decir que harware y que software fue utilizado para cargar el primer BSL? Simone
hola Jeshu esta parte me da mucho de que pensar: antes de todos: te repito: aclaramos este punto antes de seguir, si lo que escribes corresponde a la realidad entonces tienes en las manos un PIC que NO ESTA CORECTAMENTE CARGADO. Simone
uh oh! i never thought about trying to match the wavelenght of the display, nice idea though, my matter was just about brightness and i am using a pled display. txx lukas it seems like 1k is ok Simone
