dj3nk
    758
Everything posted by dj3nk
  1. if you choose e let let me see it on youtube ;)
  2. oh, sry, just thought its a standard lcd but now i think i see the difference between them. here are just the active dots lightning and no background. Am i right ?
  3. hmmmmm, could be :)
  4. I am getting some SIDs from Wilba. So he just can add the 24lc's to my package. So you would only have to pay Germany-France. And what about the c16 you wanted to have ? I could just send it with if you want. greetz add: sry Wilba. we just wrote the same time but youre surely right in what you say. ^^.
  5. why so expensive ?
  6. i am from germany and could send to france.
  7. you dont need to search. a livedrive will work. I had an audigy with an audigy drive and later i bought an audigy 2 zs and wanted to use my old audigy drive. so I went through the internet a couple of hours just to see that creative has changed the pinout with audigy2. But live and audigy are the same. I think it was because Aud2 has 24bit. You can use some parts of an Audigy- /Live drive on an Audigy2, but not all. (just for info) Audigy and live have an "AUD-EXT" connector (http://pinouts.ru/Multimedia/creative_int_pinout.shtml) , Audigy2 has an "AD-EXT" connector (http://www.driverheaven.net/audio-general-technical-discussion/51279-creative-audigy-2-ad_ext-pin-assignment.html) greetz
  8. Rischdisch Geil !
  9. Mach doch en Feuerchen ^^ löl Ne kP bin ned aus der Gegend. greetz
  10. Could it be something like the LiveDrive as a DIY version? I have to search, but I have the pinouts of the livedrive-connector for Live,Audigy / Audigy2 series if you need .
  11. dj3nk
    Midi Hub???
    hi vj "ohne Strom" gehts nich. Aber du hast ja ohnehin 5V an einem MidiOut. Also kannst du dir ne kleine Box bauen ohne extra Stromanschluss. Darin versteckt sich dann ein oder mehrere 74HC00 welche/n du mit den 5V aussem Kabel versorgen kannst. grüüse
  12. hey, you've stolen my SIDs cs ;)
  13. hmm kann sein das es an meiner wlanverbindung liegt. wenn die mal kurz abbricht merkt man es bei mp3s meist ned. ich denk ich lads nomma runter dann isses komplett. aber erst nachher. muss erst noch weg. greetz
  14. week ?????????????????? It could get "ever" I say ! Incredible work what you have done with that little space! Do you already know if and when you want to publish the pcb files? What was your hole cost for it? (with casing etc) greetz
  15. @lyle: dont we all have to learn sometime by our own ;) I like midibox brandings ^^ (if they arent mines surely) You just need to check the ~ marked pins. The others will be right automaticaly. But what already lyle said... dont forget the big caps polarity . greetz
  16. kommt auf jeden fall agnz gut rüber ! Finde aber das man bissl viel die Komprimierung hört. Es könnten auch noch ein paar hihat od. percusion sounds kommen und der basedrum bissl mehr Punch geben Das allerschlimmste.......die mp3 hat nur knapp 2 minuten bei mir :/ Gudd wörk ! greetz PS. Wie hast das vocal stottern gemacht? mit glitch zufällig ?
  17. [quote name=lylehaze link=topic=9134.msg64922#msg64922 watch your fingers.
  18. Jo das stimmt dann so. V0 ist mitte vom Poti. greetz
  19. Klar wird der angeschlossen.... Schau mal hier http://ucapps.de/mbhp/mbhp_lcd.pdf Das wird dann wohl dein Problem sein. greetz
  20. Also der bootloader war/ist schon drauf? Dann hast du via midi mios hochgeladen und wärend dem uploadvorgang die checksums fliegen gesehn? ;) Dann sollte mios sein. Wie schauts mit deinen uploadrequests? Haste die mal kontrolliert ob sich wasgeändert hat? nach erfolgreichem aufspielen des pics sollte nämlich nur noch beim anschalten deiner box EIN (1) upload request erscheinen. greetz @Thorsten: Evtl. könnte man noch die Sache mit dem Uploadrequest zu der obigen Grafik hinzufügen. Evtl werde ich (wenn ich die Zeit finde) beim Bau meiner MBSID vieeeele tolle Clips machen und die in der wiki einsetzen. Ich denke da besonders an die Grundlagen wie richtiges Löten, Coreaufbau, Pic brennen, Mios aufspielen, ......
  21. 3x 8580 if still available :D please pm greetz
  22. I think you have forgotten to solder the wires at the bottom. Look at the bottom of the core page and youll see what I mean. greetz
  23. dont you have a midicable in your audigy? theres another optocoupler inside, so youll need one. its the same circuit which is on the core so you can duplicate and diy it. Taking the SubD isnt possible when you want to use midi in AND out. perhaps try to unplug your midi-in of the core, just to check if a proper upload request will be send. greetz
