dj3nk
    758
Everything posted by dj3nk
  1. I suppose this from an usb device but standard midiplugs :? But its very curious that it works when your powerbutton is OFF.
  2. @Rio: sry aber ich find die nicht. kannst du vielleicht nen link zur liste oder seite posten wo du die gefunden hast ? greetz
  3. 12V is too much for your regulator. whats "ashd"? greetz
  4. Das mit den Schrauben ist doch kein Thema. Ich würd mir solche Kappen wie es für Schrankschrauben gibt holen und die dann anbringen. greetz
  5. measure the caps. high (endless) resistance ==> fine low (no) resistance ==> shit whats the input voltage at the regulator ? greetz
  6. Fine! Thats good. Look at your analogmeter. Anywhere on the case the internal resistance should be printed. But 0 is too low to read :). Your analogmeter acts like an additional resistor in the circuit. And its really uncomfortable to calculate back. But with R=U*I you can do. Write it down with your readings. Dont forget your analogmeters resistance! Now, to get the REAL U you have take away the "additional resistor" from R ..... now you can calculate how much volts there are. But you see you have to know the other exact values to get usable results. So spending some euros or dollars to a nice digital multimeter should be ok if you dont have one ^^. greetz
  7. What we want ? I want a 3 against 4 polyrhytm. Basedrum with percussion. Cant wait to hear ^^ greetz Is the song roxanne polyrhytm ?
  8. Should be enough, but with a backlighted lcd 9V is the better choice I think. The polarity matters a lot! Look at the pictures on this site and you see the right direction. greetz
  9. Porto mitrechnen !!! Da kann man schonma die teurere version einer kappe kaufen wenn man das porto spart. greetz
  10. I have the same problem. Check if running DIRECTX as sounddriver works! I've got a Soundblaster Audigy and when I switch from the original soundblaster asio drivers to the kX asio drivers it works fine ! greetz
  11. A ANALOG multimeter has its own resistance what means you have to calculate back. A digital multimeter has an enormous resistance of some MOhms, so it shows you directly the real value. greetz
  12. do you use a 9V PSU? Sounds to me like your 7805 is broken. solder it out and check the incoming voltage. Should be between 7V and 10V. (In the case your using a 9V psu its surely 9V). then solder a new 7805 in your core and measure for shorts. no shorts ==> test again greetz
  13. Also keine Panik ;)
  14. Yes thats right. As far as I know the LC doesnt support ain modules. Surely you can build a MB16 into your case, but it needs its own midi plugs. greetz
  15. http://ucapps.de/midibox_fm.html MB FM already has a control surface. greetz
  16. GREAT WORK !!!!!!!! Thinking of modding my guitar, too ^^ . What about a tremolo to control a cc? I think you could get really great sounds this way. greetz
  17. Konnt ich mir ja fast denken ^^ greetz
  18. Do you have a AC or DC psu? I cant see it really good on the pic, but J1 connected to ground isn't it?? J1 should just go to the rectifier.
  19. do you use midi ox and the merger is on ?
  20. echt ? sry, ich finde sie sieht aus als würde sie in der mitte übereinanderliegen. kann natürlich auch täuschen vom bild her. greetz
  21. Sieht gut aus. Würde aber eher ne durchgehende Frontplatte nehmen. greetz
  22. update your java. had the exactly same problem greetz
  23. eeaasyyyyyyyyy
