brother303
79 -
Everything posted by brother303
Hi, ok,I`ll check the wiring once again.I´ll search for solder blobs and shorts too... Is there maybe a different display driver needed for the optrex? Or do I have to change the code somewhere? Greetz Brother303
Hi Stryd, thx for the answer. VEE was the only thing I had left to solder,so I think it`s VO. Backlight is working fine,the only characters I see are black blocks in the upper row. I`ve tested it with 2 different (and working!!) cores,one V2 with a SID-application and one V3 with fresh uploaded Mios. I spent on testing the whole weekend now with the result that I`m totally confused now. I had an old 2x16 Displaytech here and hooked it up just to see what happens. And guess what,it worked! All fine,with both cores,and with the lcd-test tool of MiosStudio I was able to write and send messages to the display. After that I hooked up a 4x20 wich results to the following display entries (with a mbfm application uploaded): Gns.>k>Rvcj-Ncog"" KoC"3">3>C""3>Rjofgs ??? After switching back to the 2x16 still the same entries,and what confuses me most,on both cores!!!(One Sid and one fm application) The wiring is absolutely correct,triple checked this! :'( Any ideas? Greetz Brother303
Hi all, I have posted this question in the optrex bulkorder thread,but here is a better place I think... I hooked up my display on a tested and working core v3 yesterday. But sadly it doesn`t works! Here is my wiring,could some of you guys here confirm that the wiring is ok please? Optrex - Core 1.VSS - VS 2.VCC - VD 3.VEE - V0 4.RS - RS 5.RW - RW 6.E - E 7.0 - 0 8.1 - D1 9.2 - D2 10.3 - D3 11.4 - D4 12.5 - D5 13.6 - D6 14.7 - D7 15.Cathode - B- 16.Anode - B+ Anything faulty here?!? ??? Greetz Brother303
Optrex 40 X 2 alphanumeric LCD bulk order (closed)
brother303 replied to nebula's topic in Bulk Orders
Hi all, hooked up my display on a tested and working core v3 yesterday. But sadly it doesn`t works! Here is my wiring,could some of you guys here confirm tjat the wiring is ok please? Optrex - Core 1.VSS - VS 2.VCC - VD 3.VEE - V0 4.RS - RS 5.RW - RW 6.E - E 7.0 - 0 8.1 - D1 9.2 - D2 10.3 - D3 11.4 - D4 12.5 - D5 13.6 - D6 14.7 - D7 15.Cathode - B- 16.Anode - B+ Anything faulty here?!? ??? Greetz Brother303 -
Hi Styrd,hi Nebula, good help,good link,thanks lot once again! ;D Greetz Brother303 -
Hi Nebula, can you (or anyone else) please give me a hint how to wire the display to the core. There are 3 points I`m a bit confused : The Optrex datasheet says VSS,VCC and VEE. To wich points on the core they should be connected? Every thing else is pretty clear... Thanks lot! Greetz Brother303 :) -
hi styrd, I didn`t finish the mbfm so far,so i can`t check if it still works right now. Think I´m going to upload the application and check first. Anyone else any experiences with this issue? Thanks lot... Brother303
Hi everybody, yesterday I accidentaly put +/-9V on my opl-pcb for about 5 seconds until I noticed my error. The opl-chip got pretty hot,the yac512 stayed cool. My question is: Is there any chance for the opl3 to survive that accident or should I desolder it and put in a spare? And what about the yac512? May they be damaged too? As I mentioned above,these chips stayed cool. ??? Any suggestions? THX Brother303
Hi Stryd,hi Wilba, thanks for the information,think it`ll help! Cool! ;D Greetz Brother303
Hi to all, just started building a mbfm. I want to put it into the same pactec-case as the mb6582 with a frontpanel from Schäffer. Now I want to know if it`s possible to run the fm with a 4x20 display instead of a 2x40. Any drivers required? Or change something in the asm? Thanks lot! ;D Greetz Brother303
UK/Europe Bulk order of "Waldorf" knobs for the MB-6582 (CLOSED)
brother303 replied to Goblinz's topic in Bulk Orders
Goblinz, did you receive my paypal? I miss my name on your list posted above... ??? Greetz Brother303 -
SHIPPED: LCD 20x4 for MB6582, red-on-black: Europe order
brother303 replied to Kartoshka's topic in Bulk Orders
Hi, Brother303 - 1Display (Germany) THX lot! ;D -
Hi Nebula, have you sent the paypal-invoices for the overseas-orders yet? didn`t receive anything... :( Cheers Brother303 -
Also paid!! ;D -
Hi, I`ve ordered the transparent ones,but the grey ones are fine too. PM sent! Cheers... ;D Brother303 -
Hi Smash, I`m in for a complete base pcb kit with pics. Thanks lot! ;D Brother303
Vote what Frontpanels for the MB6582 you would like
brother303 replied to Twin-X's topic in Bulk Orders
Hi, I`m in for a set of the alternate design. Looks great! ;D Greetz Brother303 -
Hi Seppo, really nice work! Count me in for one please. This is exactly what I´m looking for to control my ASM-2. Great! ;D Greeeetz Brother303
Hi Altitude, as I mentioned above,count me in for one display. I`m interested in the CFAH2004A-YTI-JP. Greetz Brother303
Hi, if this offer is for the european builders too,count me in for one! THX Brother303
PacTec PT-10 Bulk order for Europe, (case for MB-6582). CLOSED
brother303 replied to TheAncientOne's topic in Bulk Orders
Hi, please count me in for one case. I`m located in Europe. THX! ;D Brother303 -
8xSID MB-SID PCB (aka. MB-6582) - request for comments
brother303 replied to Wilba's topic in Bulk Orders
Hi, as I mentioned above,count me in for the base pcb and if possible for a control surface pcb! I´m interested in a group-buy too. Any group-buy activities planned for the housing and/or the frontplate? Greetz Brother303 -
Hi there, great work! If possible count me in for the pcb. THX! Greetz Brother303 -
Hallo, erstmal danke an alle für die Infos. Nur weiß ich jetzt immer noch nicht mehr als vorher... Wie habt ihr den die Presets aufgeladen? Midi-Ox? Serge? Bitte einmal eine genaue Beschreibung des Vorgangs,vielleicht habe ich nur nen ganz blöden Fehler gemacht oder was übersehen... Danke nochmal an alle! :)
Hallo, in Mios Studio sehe ich,wenn ich auf Sys gehe,einfach nur den Schriftzug "todo",kann aber keine Files öffnen. Mios und die Sid-Applikation gingen problemlos drauf...
