brother303
    79
Everything posted by brother303
  1. Hi, ok,I`ll check the wiring once again.I´ll search for solder blobs and shorts too... Is there maybe a different display driver needed for the optrex? Or do I have to change the code somewhere? Greetz Brother303
  2. Hi Stryd, thx for the answer. VEE was the only thing I had left to solder,so I think it`s VO. Backlight is working fine,the only characters I see are black blocks in the upper row. I`ve tested it with 2 different (and working!!) cores,one V2 with a SID-application and one V3 with fresh uploaded Mios. I spent on testing the whole weekend now with the result that I`m totally confused now. I had an old 2x16 Displaytech here and hooked it up just to see what happens. And guess what,it worked! All fine,with both cores,and with the lcd-test tool of MiosStudio I was able to write and send messages to the display. After that I hooked up a 4x20 wich results to the following display entries (with a mbfm application uploaded): Gns.>k>Rvcj-Ncog"" KoC"3">3>C""3>Rjofgs ??? After switching back to the 2x16 still the same entries,and what confuses me most,on both cores!!!(One Sid and one fm application) The wiring is absolutely correct,triple checked this! :'( Any ideas? Greetz Brother303
  3. Hi all, I have posted this question in the optrex bulkorder thread,but here is a better place I think... I hooked up my display on a tested and working core v3 yesterday. But sadly it doesn`t works! Here is my wiring,could some of you guys here confirm that the wiring is ok please? Optrex - Core 1.VSS - VS 2.VCC - VD 3.VEE - V0 4.RS - RS 5.RW - RW 6.E - E 7.0 - 0 8.1 - D1 9.2 - D2 10.3 - D3 11.4 - D4 12.5 - D5 13.6 - D6 14.7 - D7 15.Cathode - B- 16.Anode - B+ Anything faulty here?!? ??? Greetz Brother303
  4. Hi all, hooked up my display on a tested and working core v3 yesterday. But sadly it doesn`t works! Here is my wiring,could some of you guys here confirm tjat the wiring is ok please? Optrex - Core 1.VSS - VS 2.VCC - VD 3.VEE - V0 4.RS - RS 5.RW - RW 6.E - E 7.0 - 0 8.1 - D1 9.2 - D2 10.3 - D3 11.4 - D4 12.5 - D5 13.6 - D6 14.7 - D7 15.Cathode - B- 16.Anode - B+ Anything faulty here?!? ??? Greetz Brother303
  5. Hi Styrd,hi Nebula, good help,good link,thanks lot once again! ;D Greetz Brother303
  6. Hi Nebula, can you (or anyone else) please give me a hint how to wire the display to the core. There are 3 points I`m a bit confused : The Optrex datasheet says VSS,VCC and VEE. To wich points on the core they should be connected? Every thing else is pretty clear... Thanks lot! Greetz Brother303 :)
  7. hi styrd, I didn`t finish the mbfm so far,so i can`t check if it still works right now. Think I´m going to upload the application and check first. Anyone else any experiences with this issue? Thanks lot... Brother303
  8. Hi everybody, yesterday I accidentaly put +/-9V on my opl-pcb for about 5 seconds until I noticed my error. The opl-chip got pretty hot,the yac512 stayed cool. My question is: Is there any chance for the opl3 to survive that accident or should I desolder it and put in a spare? And what about the yac512? May they be damaged too? As I mentioned above,these chips stayed cool. ??? Any suggestions? THX Brother303
  9. Hi Stryd,hi Wilba, thanks for the information,think it`ll help! Cool! ;D Greetz Brother303
  10. Hi to all, just started building a mbfm. I want to put it into the same pactec-case as the mb6582 with a frontpanel from Schäffer. Now I want to know if it`s possible to run the fm with a 4x20 display instead of a 2x40. Any drivers required? Or change something in the asm? Thanks lot! ;D Greetz Brother303
  11. Goblinz, did you receive my paypal? I miss my name on your list posted above... ??? Greetz Brother303
  12. Hi, Brother303 - 1Display (Germany) THX lot! ;D
  13. Hi Nebula, have you sent the paypal-invoices for the overseas-orders yet? didn`t receive anything... :( Cheers Brother303
  14. Hi, I`ve ordered the transparent ones,but the grey ones are fine too. PM sent! Cheers... ;D Brother303
  15. Hi Smash, I`m in for a complete base pcb kit with pics. Thanks lot! ;D Brother303
  16. Hi, I`m in for a set of the alternate design. Looks great! ;D Greetz Brother303
  17. Hi Seppo, really nice work! Count me in for one please. This is exactly what I´m looking for to control my ASM-2. Great! ;D Greeeetz Brother303
  18. Hi Altitude, as I mentioned above,count me in for one display. I`m interested in the CFAH2004A-YTI-JP. Greetz Brother303
  19. Hi, if this offer is for the european builders too,count me in for one! THX Brother303
  20. Hi, please count me in for one case. I`m located in Europe. THX! ;D Brother303
  21. Hi, as I mentioned above,count me in for the base pcb and if possible for a control surface pcb! I´m interested in a group-buy too. Any group-buy activities planned for the housing and/or the frontplate? Greetz Brother303
  22. Hi there, great work! If possible count me in for the pcb. THX! Greetz Brother303
  23. Hallo, erstmal danke an alle für die Infos. Nur weiß ich jetzt immer noch nicht mehr als vorher... Wie habt ihr den die Presets aufgeladen? Midi-Ox? Serge? Bitte einmal eine genaue Beschreibung des Vorgangs,vielleicht habe ich nur nen ganz blöden Fehler gemacht oder was übersehen... Danke nochmal an alle! :)
  24. Hallo, in Mios Studio sehe ich,wenn ich auf Sys gehe,einfach nur den Schriftzug "todo",kann aber keine Files öffnen. Mios und die Sid-Applikation gingen problemlos drauf...
