napierzaza
442 -
Everything posted by napierzaza
I just moved apartments and was shocked to see that the LCD screen for my under-construction Stereo SID was smashed. I'm wondering where the best place for buying a 20x2 LCD would be. I'd like it to ship to Canada really cheaply if possible! I had all my parts together and this is a big set-back if it's going to cost 50$ for me to get my SID going.
I really just want to minimize interconnections and panel mounting because I am making it all by hand. Thank you very much!
http://www.futurlec.com/LED/LCD40X4BL.shtml Would this work with the SEQ V3? I'd be interested to not have to wire two separate screens.
Okay thanks, I think I might not go with a joystick then. I appreciate the information.
Oh my, yes, correct again. Sorry sorry sorry. I've lost much sleep. So then... Is there a way to have TWO of J5 work as AIN and the remaining 6 work as a functional DOUT?
This is correct. I'd like to install a joystick into my box. Assuming 4 AOUT connections, or two for each pot. After that I need the last 4 pins for DOUT for some LEDs for the Filter module.
Thanks very much for the answer Thorsten. So does this mean that I can add one Pot to J5 and then Assign it dynamically through the CS menus? This is good. Is there anyway to activate only 4 J5 pins for AOUT, and use the other for for DOUT?
Okay, so I've been thinking, and possibly having a LFO or Filter joystick control might be very interesting. However I'm getting a lot of static on my searches because most of the stuff about it are from 1.7 or lower SID firmwares; and from what I can tell it's remarkably different now. I basically have one joystick I might use for LFO(because I have no panel controls for that) or the Filter (maybe replacing some of my panel controls?). Does anyone have any pertinent SID 2.0 information? EDIT: from what I can tell there are options in the setup_*.asm for different AOUT options. However I noticed that everything is separated. What I'd like is to have one joystick, and let's say, oscilator select buttons to shift what it's controlling. That way I might even be able to control LFO, OSC, and Filters by including a joystick and the selection buttons one the panel instead of 12-ish sticks.
So you can use J5 for DIN as well? How useful is using it for analog inputs? I was thinking of possibly a joystick but there isn't much on that in the documentation. Has anyone been very successful with this? I'd like to know how useful it might be.
Argh, you're right, I can't find it. Perhaps I was remembering that it said you could use the 2x16 and then saw the really small hole in the panel design layout.
Oh, well the SID page said that it was default for 2x16 and the default items were 5. Anyhow it doesn't matter, I didn't really think I need more than five anyhow. The front panel uses a much smaller LCD from what I can tell though, way shorter than mine. Thanks.
I only have a LC 2x20. Should I bother changing the number of items to 7 or is 5 enough? I'm not sure I want to bother with it but I've never seen the interface. I don't have anything other than a 2x20 though.
So do I need to affix 220 Ohm resistors if I'm using J5? I hope not, I'm out!
I guess it makes me lame for thinking this might be a bug!
Okay, going through all the pin assignments. What the devil is with this: <code> ;; additional CS encoders ;; SR Pin Mode ENC_ENTRY 3, 0, MIOS_ENC_MODE_DETENTED2 ; Osc delay/transpose/assign #1 ENC_ENTRY 3, 2, MIOS_ENC_MODE_DETENTED2 ; Osc attack/finetune/assign #2 ENC_ENTRY 3, 4, MIOS_ENC_MODE_DETENTED2 ; Osc decay/portamento/assign #3 ENC_ENTRY 3, 6, MIOS_ENC_MODE_DETENTED2 ; Osc sustain/release/assign #4 ENC_ENTRY 3, 8, MIOS_ENC_MODE_DETENTED2 ; Osc release/pulsewidth/assign #5 </code> It says that there is a 8th pin for that SR? Looking at it I believe that it's showing only even because encoders take two pins to function. So I think this ASM is implying that this is a 10 pin encoder. It says there are only 8 pins though... correct?
Thanks for the verbose answer Wilba. I really appreciate it! I made my own double-PCB based on your designboard, and so my SID is on the audio ground. So far the design I made is going well, just trying to correct any mistakes I might have made before actually putting my 6581s inside. I don't want to damage them. I'm using two transformers for my power, so the only connection between 12v and GND is through the SID. I was wondering whether something bad wound happen though considering that it's taking 5v and not grounded to the same level. I'm glad to hear that it will not be a problem, I will remove my ground pin jumper!
Herm, okay, I'll have to do this. I have two seperate transformers so ultimately I guess there is no really appropriate ground connection.
So... 14 is the regular 5v ground... and which is the audio ground? I was told to seperate the 12v and the 5v ground, but I don't know where they should actually go. Or is it that the IC is completely 5v. But the the audio is 12v? If I have two separate power supplies and wire it like that, there should be no issue?
Okay, so if the SID has a 5v, and a 12v (or 9v) input, AND two grounds... Which ground is which? I have no seen any info on this but I believe Wilba suggested having them seperate. In is design they are together though: Can anyone shed a light on this?
I've been hijacked! Can someone post a link for control surface schematics before he posts more photos?
Your setup is pretty low key. You had to use a DIX4x? This is interesting, I may want to do the same. BTW, I don't believe I see any links to wiring schematics. Many, the panels that you guys have made! I can barely afford to get the actual hardware together, much less a shiny panel
Yes, well I have the 7812 on my SID board and I assume that's adequate enough! Looks like it's working, but I haven't checked after my 7812 yet as I'm still in the assembly phase. But I will most definitely be checking before plugging in my SIDs.
I have made a SID that is comprised of one CORE and two SIDS attached to it (in the same way that Wilba wired two SIDS together on his unit. I have looked at the different control surface options and am wondering, what do I really need for my unit? I appears as if Control Unit C is too complex for me, and B is more so about if you have multiple slaved SIDs. So if I want a decent control of my sid does surface B offer me any benefit? Also, I can't find any schematics for wiring on the site. I found this one, but am unsure which Step it is. Also, does this work with SID v2? http://ucapps.de/midibox_sid_cs/2x20_enc_multi_w_j5.pdf
