verpeiler
    55
    2
verpeiler last won the day on August 7 2024
verpeiler had the most liked content!
About verpeiler
  • Birthday 03/05/1981
  • Gender
    Male
  • Location
    Germany, Leipzig
Recent Profile Visitors
verpeiler's Achievements
MIDIbox Newbie
2
  1. Thank's for the tip! What I'm looking for is either the fpd file which fits the Heidenreich case or maybe a ready made panel. The fpd file I found in the Wiki seems to be not specifically made for the Heidenreich case. I prever a fpd file which is proven to fit into the Heidenreich case before trying to adapt Wilbas files to the case.
  2. Hello fellow MIDIboxers, as I was out of the DIY stuff during the last years, I completely lost track. Now I want to finish my SEQ. I have a Heidenreich case laying around as well as a MBHP_CORE_LPC17 v1.0, the CS board from Wilba (the blue one, no revision printed on the board, just the year 2009) and also a MBHP_AOUT_NG R1 (but I don't think that it will fit into the case). To continue I need a frontpanel (and probably the backpanel). Could someone of you point me to the .fpd-files, please? Thanks a lot in advance!
  3. The PO10 has nothing to do with Midibox. PO10 stands for "Posing Controller Level 10". SCNR
  4. I'm looking for a rocker switch as well. You can find some at eBay from time to time (search for c64 switch, I think they will fit but I'm not 100% sure). Currently a seller in Germany has some of them, but 9 Euro for a used part... Have you seen Hawkeye's great Building the MB-6582 Control Surface - Photo Tutorial ? It's very helpful and contains part numbers. BTW: For the base to cs connections I would recommend to just follow Wilba's instructions and use the stiffy flat flex cable. It's more than sufficient. Once you are done you will open the case maybe 5 times. A detachable solution is always nice but not worth the effort.
  5. verpeiler
    Work in progress :)
    I like to build a similar enclosure. So I'm definitely interested how you solve it. Good luck!
  6. Looking for one or two Salecom T80-R rocker switches for a MB6582 build. Like this ones.
  7. Have a look at this wiki page
  8. verpeiler
    The buttons are really nice! :) What kind of switches did you use?
  9. I opened a similar some time ago. I have no fan in my MB-6582. Stuffed with 8x6582 I have no problems so far. But I will add heatspreaders to the SIDs next days.
  10. Not sure if I understand what you have written. Do you get 5V at Pin1 of the LF33, or not? As ground I would use Vs at J2 or the metal parts of the USB or the 7805. From the pictures I would propose to reheat the solder joints of the LF33, they look ugly. Also you should reheat all other solder joints which look like "bubbles", as this is an indication of cold solder joints. Then try to measure at the solder side and also at the upper side! It's also a good advice to clean the board (see my comments in ) as you can distinct a lot better between good and bad solder joints.
  11. Pin 1 is the Input of the regulator LF33. If you don't have 5V between Pin 1 and Pin 2 (Ground) you won't get anything out of the LF33. Maybe there is a short anywhere between the ground and the 5V lines? Could you measure the resistance between the Pins at J2? There should be no(!) continuity between the Pins Vs/GND and 5V. Could you post some pictures of your PCB (both sides, hires prefered)? Maybe some other pair of eyes see something.
  12. Jumper J17 is set? Measure the voltage at the LF33 (IC7). You should get 5V between Pin 1 and Pin 2 and 3.3V between Pin 2 and Pin 3.
  13. Since I created/initialized a "Session", the error message "SD Card Error !!! E 11 (FatFS: D 9)" does no longer appear and I can save settings like the Default Port. I did not know that the Default Port is saved in the session files. Unfortunately this took a while since the error message is a little bit too generic. I also had to learn that the session name "Default" is a reserved word for a "special" session. Once created, I can't delete it with the Seq (but I can delete the files with the Filebrowser). The other problems with MIOS Filebrowser still exist (upload works, download doesn't) but I guess this is a problem with my old Windows XP installation?! Now I'm learning how this thing works. Seems to be a very powerful and useful device. Thanks TK and Midibox folks!
  14. No MagJack hence no OSC here, just some ideas... I would check basic ip conectivity at first. Is your core and your OSX at the same ip subnet? If so you could try to ping and/or verify your OSX has an entry in it's arp-cache for your core. You could watch if your OSX receives something from the core with tcpdump. Could you post the output of an ifconfig -an from your OSX and the output of the network command from your core?
