Janis1279
287 -
Everything posted by Janis1279
Hi, The some Eagle files from the eight-oh-eight.org forum, i think. Regards, Janis 808_production_Individual_Files.rar
Hi, I have some changes in my MBSID a custom build CS part - have an additional button for ARPegio ON/OFF function DIN_ENTRY CS_MENU_BUTTON_Arp, 16+1, 4 ; **new** Arp button (Janis custom CS) It's workinkg fine . For better viewing the state - ARP ON/OFF I prefer to switch accordingly ON/OFF a led. I think is enough to make changes in two files, maybe: 1. cs_menu_leds.inc .... bsf TMP...,... 2. setup_mb6582.asm DOUT_ENTRY TMP...,..., 16+...,... ;; SR#, Pin# numbers are custom,have spare places for leds May be some of programmers can help to define an ARP led. Regards, Janis
C:\MIDIbox>cd midibox_sid_v2_043 C:\MIDIbox\midibox_sid_v2_043>cd midibox_sid_v2_043 C:\MIDIbox\midibox_sid_v2_043\midibox_sid_v2_043>make rm -rf *.cod *.lst *.err rm -rf *.hex gpasm -p p18f4685 -I./src -I ./include/asm -I ./include/share -I ./modules/j5_ io -I ./modules/aout setup_6581.asm src/main.inc:25:Warning [209] Missing quote. src/main.inc:25:Error [103] syntax error ./include/asm\macros.h:188:Error [113] Symbol not previously defined (MBSID_VERS ION_STR). make: *** [setup_6581.hex] Error 1 C:\MIDIbox\midibox_sid_v2_043\midibox_sid_v2_043> Hi, I got a mistake to tried to compile unzipped MBsid source file without any changes in it before. Another midibox sorce files compiled without mistakes. I have a custom MBsid CS part. Regards, Janis
Hi, In the Midibox64 by default you are able to switch on / off a led #1 with a GP button #1, etc. I tested this way up to the 16 GP buttons with the 16 appropriate leds. http://www.ucapps.de/mbhp/mbhp_doutx4_32leds.pdf http://www.ucapps.de/mbhp/mbhp_dinx4_32buttons.pdf Regards, Janis
Hi, You need to upload the latest mios_v1_9g http://ucapps.de/mios/mios_v1_9g.zip of course, for the MB64 application - setup_midibox64.hex Regards, Janis
[S] x0xb0x, MBFM built modules, PIC & SID boards, Waldorf Knobs
Janis1279 replied to rosch's topic in Fleamarket
Hi Roger, The Core pcb's and the pic controllers successfully arrived. Many thanks ! Regards, Janis -
Hi mikee, http://ucapps.de/pic16f_firmwares.html Maybe I am wrong. The schematic of the old pic16 based Core module is almost the same, only the MBHP_CORE module has to be stuffed with a PIC16F877 and a 20 MHz crystal. Regards, Janis
Hi, I do not know about your pcb sources. - I remember, on the Core board from Mike, I soldered 2 additional isolated wires for communication purposes, an additional cable between the CLK input of the SID and Core::J7:SO/PIC Pin #17 at least. http://ucapps.de/mbhp/mbhp_core_v3.gif - You need to recheck the connection cable between the Core module and the Sid module, too http://ucapps.de/mbhp/mbhp_8xsid_c64_psu_optimized.pdf Regards, Janis Reinholds
Arrived. Joonas, Thank you ! Best Regards, Janis
Hi, I understood the screw position changes did not take it job. may be it not working properly.Not a good contact inside it or somesing else. Is P1 50K , marked 503 and is P2 10K, marked 103 ? you need to regulate the both of screws for better result. Regards, Janis
You can also to measure the trimmers resistance changes with the multimeter in the various screw possitions without applied voltage. Regards, Janis
Hi, You can listen to a square waveform and some various waveforms here under an VCO article part: http://www.musicfrom...PW=1356&VPH=533 Regards, Janis
Hi, From the Wiki http://www.midibox.org/dokuwiki/lib/exe/fetch.php?hash=6e29d6&media=http%3A%2F%2Fwww.mb6582.org%2FsammichSID%2FsammichSID_Build_Guide_v1_0.zip Look at page 17, from here you can find some info about powering LCD backlight part. Regards, Janis
Hi, May be I am wrong. Could this be a problem with the some wire interconnections mistakes, shorts. If you are looking from the OPL3 board side, connector J2 2 address control wires to the Core module RB4 - RB7 port . from this diagram http://ucapps.de/mbhp/mbhp_opl3_interconnections.pdf Regards, Janis
Hi, Welcome. Try to read in the Wiki pages for the some info about sammichSID. you will need to read the Midibox sidv2 User manual chapters, it's what you need. Regards, Janis
Hi, It's not the same: , but the additional resistor can do more stable the merger work. Regards, Janis
Hi, Are You meant to initialize to get the default patch ? From the Sid2 manual pages: the patch should be initialized to get a defined start. Press&Hold the SHIFT (formerly LINK) button and press the select button below "Ini" to get the default patch: Regards, Janis
Hi, only +9V output for the 8580 chip . But the 7809 linear regulator i.c. can do it from +12V output easily. Regards, Janis
Are these two inverters functionally different?
Janis1279 replied to jjonas's topic in Miscellaneous
Hi, The function tables are look identical both, too. The each inverter Output logic level is inverted versus to its Input logic level: H goes to L and L goes to H. Regards, Janis -
Hi, Yes! all the four PIC18F4685s to be programmed with the IDs: 00, 01, 02, 03. An every engine has a unique ID. In the many Gallery pic's you can see that, too. Regards, Janis
Hi, here is another 4 inputs mixer http://www.next.gr/i...l074-l6661.html Regards, Janis
Hi, Are you could to measure 5 volt on the resistors network marked pins for the RN2 and RN4 parts? http://www.midibox.o...hSID_CS_PCB.pdf Regards, Janis
Hi, If you used MB64 setup connection diagramm looks like : http://www.ucapps.de...p/auaimbctg.pdf and asm setup file part looks like: ; Setup File of TK's MIDIbox64 ; ; Number of connected pots ; Allowed values: 1-64 #define DEFAULT_NUMBER_POTS 20 ; number of connected pots ; ; Multiplexers (AINX4 modules) connected? -> set this value to 1 ; No multiplexer connected= -> set this value to 0, allowed number of pots in this case: 1-8 #define DEFAULT_MUX_ENABLED 1 ; enable multiplexers ; Regards, Janis
Hi, A nice link. I do not recomended to connect the transformer two secondary windings in parallel. It can cause for more transformer heating ,than under normal usage conditions, no safe. Not every transformer manufacturer recomended do that way connections , the secondary windings are not so identical, I think. Regards, Janis
+1 I lost some time with those extra resistors in the slaves cores. My MB6582 board has 6N136 instead of 6N138 http://www.ucapps.de...136_variant.jpg Regards, Janis
