373 -
16
Everything posted by eptheca
Panel meny unresponsive and shifting without touching it.
eptheca replied to arneborgan's topic in MIDIbox SID
I am not sure what you want to do. If you have sound, I guess the firmware and patches are uploaded. MIOS Studio is only needed for uploading firmware etc. Which chips do you have? If you have 6581's, the noise is normal -
Great \o/ Happy to help, especially a fellow Norwegian :) -
the sammichSID has two shift registers on the front CS PCB http://www.schickt.de/mb.org/sammichSID_CS_PCB.pdf they are 74HC165's next to them are the Resistor Networks they are the 10K pull-up resistors they have a "dot" by the pin that is the drain, an has to be soldered the correct orientation the dot goes in the square hole, Ground -
on the MBHP DIN module http://www.ucapps.de/mbhp_din.html where are you located Arne? If you're in Oslo, I could have a look at it -
I think because Zephyrin is only using one MIDI I/O board with 2 MIDI IN, the BLM can use the 2 MIDI INs that's left. I don't have this setup, so I can't confirm it, but that's how I understand TK's answer in the thread you linked to
I know you're on holiday TK, but maybe for when you come back :) or someone else I have my CV V2 connected to the SEQ V4 like you suggested. When I run the SEQ (press play) the CV V2 displays "MIDI protocol TIMEOUT" Any suggestions?
yes, that will work fine
thanks for the suggestions guys :)
I have ran out of solder, and my local electronics shop has closed down. Can anyone recommend a solder suited for the typical through hole and surface mount PCB's for MIDIbox projects? I have always used a Multicore 60/40 ERSIN 362 solder, but for no particular reason. I have no knowledge about the different options. I am about to order some stuff from Mouser, so something from their assortment would be great. Anybody using a Kester 63/37 type solder? Cheers
Yes, that did the trick :smile: Thank you Can I rename them? Edit: Yes I can in seq_midi_port.c \o/
I was a bit quick with the "all working" On the sequencer, in the MIDI router menu, and the other menus where MIDI port can be changed, only the standard MIDI ports are listed. -Def. -USB 1-4 -OUT 1-4 -IIC 1-4 etc. The "extra" MIDI ports, IIC 5-8 are not listed
Thanks again TK :smile: 4xMIDI IN, 12xMIDI OUT,all working \o/
From the album: eptheca
4xMIDI IN, 12xMIDI OUT -
All MIDI I/O comes up in MIOS terminal -
OK. Thanks TK. I will change the connections and check in the MIOS terminal.
I have now built the SEQ V4 with 2x MIDI I/O boards and 2xQuad IIC boards. The two Quad IIC boards are connected to the STM32F4 module. Number 1 to J4A and number 2 to J4B The first has standard IIC firmware on the PICs, the second have modified firmware. I have also changed MIOS32_IIC_MIDI_NUM to 8 in mios32/mios32_config.h and recompiled. midibox_seq_v4_88 In the SEQ V4 menu still only the standard MIDI outputs come up, Default - - - IIC4 Anything I have missed? Best regards Halvor
freddy's FPD file has a 1,5mm. corner radius on the 16x16mm cutouts for the button caps. For the Marquardt button caps this is too sharp, the radius should be 0,75mm. Here is the altered file BLM_16x4.fpd
Hi, Which Core does it have? Type of LCDs, buttons and LEDs Picture? Best regards Halvor, also located in Norway :)
I have the same concern. On my MBCV V2, I have cut off the other end (not the Micro side) and soldered a USB type B female socket to it that is attached to the case. The solution I am going for now is this cable/adapter that TK suggests http://www.reichelt.de/DELOCK-83183/3/index.html?&ACTION=3&LA=446&ARTICLE=126860&artnr=DELOCK+83183&SEARCH=DELOCK+83183 With this OTG is possible I have just posted some questions related to the cabling here
Great :) How does the cables need to be set up? Can I use a USB Micro-B male to USB 2.0 A female OTG cable/adapter on each STM32F4 http://www.reichelt.de/DELOCK-83183/3/index.html?&ACTION=3&LA=446&ARTICLE=126860&artnr=DELOCK+83183&SEARCH=DELOCK+83183 and connect them with a USB 2.0 A male to USB 2.0 A male cable http://www.reichelt.de/USB-Cables/AK-670-2-1-0/3/index.html?&ACTION=3&LA=2&ARTICLE=45870&GROUPID=6099&artnr=AK+670%2F2-1%2C0 or can I only use the OTG cable/adapter on one Core, and a "standard" USB Micro-B male to USB 2.0 A male cable on the other. http://www.reichelt.de/USB-Cables/AK-676-AA2/3/index.html?&ACTION=3&LA=2&ARTICLE=132999&GROUPID=6099&artnr=AK+676-AA2 If so, does it matter which Core has the OTG cable/adapter? What about power? Can the MBCV V2 be powered over USB from the SEQ V4, if the SEQ is powered by external 5V power supply, and J17 is bridged? I am not sure how much the SEQ V4 (Wilba panel, Smash TV green LEDs) + 2x Optrex LCD (max 480 mW each) and the MBCV V2 (AOUT module, DINx3, 4xScope OLEDs) draws. My 5V supply can take 2,5 A. Enough? Cheers, Halvor
I think it's a misunderstanding :) I am looking for a BLM 16x4 PCB, like this http://www.midibox.org/dokuwiki/doku.php?id=16x4blm_pcb I hope you haven't soldered encoders to it
Hi, Does anyone have a spare one?
4xMIDI IN, 12xMIDI OUT just waiting for some screw dimensions before I order the back panel -
back panel design in FPD
