doc Posted March 30, 2008 Posted March 30, 2008 Hi folks,I felt a bit bored this weekend while waiting on several parts for other boxes.But I wanted to solder something.In every control room of every studio you'll find nice clocks on the wall. I find them boring.So, what about a big MTC-Display on the wall, telling everybody whats going on?Thought .... done.My MTC display now is 85cm x 12cm large. It will be a nicer "wall-clock" than the usual ones.The Display is based on TKs Midimon Projekt. I only added transistor- and ULN Drivers for the digits.The digits didn't light below 8,5 V. So I powered them with 12V. I had to change the firmware a little bit to invert all DOUT outputs.The digits are 100mm hight each and very bright. I'm gonna put them behind a red acryl-front and I'm gonna build a nice case (the next time, I feel boring ...)The schematic and the changed firmware I'll post, after I've written it down.Have a midiboxing good time!DocSorry for the bad pictures. With flash it was too light and without it was too dark ... *argh*
doc Posted March 30, 2008 Author Posted March 30, 2008 ... and yes....It works also in daylight savings time (DST) ;D ;D
/tilted/ Posted March 31, 2008 Posted March 31, 2008 That's hot.I thought my 25cm long MTC was massive.Now you should build a 5 meter long 3 x MBLC, with 500mm motor faders, and industrial E-stop buttons for Mute/Solo/Record.Very handy when the Incredible Hulk is mixing...
doc Posted March 31, 2008 Author Posted March 31, 2008 Here's the schematic for driving the big digits:http://www.docstudios.de/midibox/megamtc-driver.pdfHave fun!Doc
nILS Posted March 31, 2008 Posted March 31, 2008 You could use 5000mm motorfaders and use the box as an elevator ;D That way the MTC display could easily be the floor display.
Sasha Posted March 31, 2008 Posted March 31, 2008 That is great. I love big displays! Are you sure they are big enough? ;DI did similar thing for cue management system, except I didn`t used factory displays. It was made 100% from scratch. Numbers are 200mm high and each segment have 20 super bright 5mm LEDs, and not multiplexed. ::) Separation is made using some kind of foam material. Of course, laser did precision work and I did boring part... wiring :-\
TheAncientOne Posted March 31, 2008 Posted March 31, 2008 I haven't got a picture, but in 1979 I build a time display for an athletics meeting for a local club. Each segment used 7 3 foot fluorescent tubes, giving 6 foot high letters, (it may have been 7x2 giving 4 foot - I can't remember). The tubes had transformer pre-heated end filaments, and triac control of the ballasts. To save money is was fed by a 20mA serial loop. opto isolated, and all the drive electronics were live. In those days an SSR (even a small one) was over £10, and we would have needed 28 of them. The drive was simply an SN7447 driving triacs through transistor buffers. To avoid mains clicks, the data was latched into 4x SN7475's on mains zero, to avoid the cost of zero volt switching of each triac. We had to put a wirewound resistor in parallel with each tube to avoid low current drop out. The cases were scrap aluminium panels from a local company that refurbished trucks. An electrical wholesaler who sponsored the club donated the tubes, ballasts and transformers, in return for their name on the front. We couldn't afford opalescent perspex, so used a 'mask' made of alloy, and baking parchment over the tube holes, then clear plastic on top. I still occasionally worry that it is in storage somewhere, and that some idiot will try firing it up again.That's a very cool display doc, though I think Sasha now has to make an MTC with a pair of his. It might motivate me to get my MTC and MIDImon done. Nice work!
TheAncientOne Posted March 31, 2008 Posted March 31, 2008 Sasha's display reads right either way up, and reminds me of an old English joke about a boating lake, (they had them in parks: you could hire a rowing boat).Man with loudhailer shouts out "Come in number 99 your time is up!"An assistant says to the man with the loudhailer ' But we've only got 72 boats'Man with the loudhailer shouts "Number 66 are you in trouble?"
Screaming_Rabbit Posted March 31, 2008 Posted March 31, 2008 ... beautiful! ... and now tell me, where you got those displays from, for a reasonable price. :oGreets, Roger
doc Posted April 1, 2008 Author Posted April 1, 2008 @sashaAs long as you only have 3 digits .... Yes, it's big enough! ;D@TheProfI'm sure that there are much bigger digits possible, but it's almost hard to explain why I made it that huge. ;)@Screaming_RabbitThe digits are from Kingbright (SA40-19SRWA). I've ordered them for about 10 EUR a piece.I don't know, if thats a reasonable price...If you like, I can order some for you or shall we do a bulk order? ;DgreetsDoc
Sasha Posted April 1, 2008 Posted April 1, 2008 If you like, I can order some for you or shall we do a bulk order? GrinBulk order..? Great idea! I really don`t see a reason why don`t we all make ourself 100mm MTC displays for our walls. The only problem for me would be going out on the roof so I can see the whole display trough window, but it is not big deal. Or better... make it remote and mount it on the building across mine. That would be cool! ;D
TheAncientOne Posted April 1, 2008 Posted April 1, 2008 Bulk order..? Great idea! I really don`t see a reason why don`t we all make ourself 100mm MTC displays for our walls. The only problem for me would be going out on the roof so I can see the whole display trough window, but it is not big deal. Or better... make it remote and mount it on the building across mine. That would be cool! ;DPerhaps not a good idea to use Red LED's if you are doing that - the neighbours might start getting the wrong kind of visitors!
Screaming_Rabbit Posted April 1, 2008 Posted April 1, 2008 Perhaps not a good idea to use Red LED's if you are doing that - the neighbours might start getting the wrong kind of visitors!... specially if your display shows 12:58:46:17 and people think it's the number of satisfied visitors :P
Jidis Posted April 5, 2008 Posted April 5, 2008 I wonder what happened with this one (40x20cm):http://www.midibox.org/forum/index.php/topic,6381.0.html
doc Posted April 7, 2008 Author Posted April 7, 2008 I wonder what happened with this one (40x20cm):I think, ...nothing.The guy was never active again since then.greetsDoc
Jidis Posted April 14, 2008 Posted April 14, 2008 I hadn't realized yours was that big. I glanced at the dimensions you stated and saved the picture, but just realized the other night that one of the things laying beside it was a 2x40 LCD. :oYou should get it to print messages, like "-record-" or something, triggered from MIDI messages. :)Good Job!
doc Posted April 14, 2008 Author Posted April 14, 2008 You should get it to print messages, like "-record-" or something, triggered from MIDI messages. Hey! Thats a good idea. I will implement this. Thanks
MTE Posted April 14, 2008 Posted April 14, 2008 Das Du da net früher drauf gekommen bist....tztztz.... ;D ;D und sowas schreit sich der Beste *pfff ;D ;D ;D
doc Posted April 14, 2008 Author Posted April 14, 2008 und sowas schreit sich der Beste *pfff Nicht der Beste ... Der SCHÖNSTE! ;D ;D
Screaming_Rabbit Posted September 12, 2008 Posted September 12, 2008 Super cheap giant digits at pollin.de - €1.95!!!I paid > €8/pce. for mine at reichelt. Only difference to those from Reichelt (as well as Doc's in his circuit design), they're common Kathode... so you have to change the transistors in Doc's design and program the software changes.http://www.pollin.de/shop/detail.php?pg=OA==&a=MjY0OTc4OTk=&w=OTg4OTk4&ts=0Greets, Roger
bugfight Posted September 13, 2008 Posted September 13, 2008 coool. too bad about shipping cost to usa...
