diablojoy Posted June 11, 2008 Posted June 11, 2008 Making good progress so far havent come across anything i couldn't figure out eventually myself :)so i thought i would share some pictures with any who are interestedThe knobs i made myself from some 12mm ally round stock and anodised blue i still have to provide a soft grip on themand will probably try some silicone tube in a bright blue colourIMG_4011.JPG
Narwhal Posted June 11, 2008 Posted June 11, 2008 Looks very nice! I'd love to see some closer details of your knobs and light rings.
Futureman Posted June 11, 2008 Posted June 11, 2008 Cool! Looks sharp!I recognise those buttons, I was looking at those in Jaycar (A electronics store in Australia) the other day.Also, the centre button, I was looking at getting some of those, but was unsure about it specs etc..How hard is it to press the centre button? Is the LED 12volt? (does it have a limiting resistor in it?)RegardsMike
nILS Posted June 11, 2008 Posted June 11, 2008 Welcome abord diablojoy!That's one pretty seq! Awesome work ;D
Sasha Posted June 11, 2008 Posted June 11, 2008 Hi diablojoy, congratulations on your sequencer and welcome aboard. It looks very, very good by now! I appreciate DIY-ing of those knobs! Illumination looks very even (no spotlights). Can you please post more internal pictures?
stryd_one Posted June 11, 2008 Posted June 11, 2008 Yeh, nice! Can you tell me about the LCDs too? Blue 2x40, that's rare as... Only one I know of is the optrex and those aren't them...
nILS Posted June 11, 2008 Posted June 11, 2008 Can you tell me about the LCDs too? Blue 2x40, that's rare as...Seriously? I'm having more trouble finding red [or orange] ones. Blue ones are in stock at reichelt for example.
stryd_one Posted June 12, 2008 Posted June 12, 2008 Blue ones are in stock at reichelt for example.2x40 = 42,80 €2x20 = 82,00 € :oMaybe not.Damn if you manage to find orange youre deing better than I. I've seen red ones as surplus but that's all. Optrex do them in white, and I thought about a cellophane filter...
diablojoy Posted June 12, 2008 Author Posted June 12, 2008 Hi peoples the blue L.C.D's are available from futurelec JHD402A USD $24.90 EACH :) had no problems dealing with these guysdelivered to australia under 2 weeks as for the earlier question about the center switch i should have mentioned its for poweron / off dpdt 240volt 3 amp rated with a 12 volt lamp that glows blue from jaycar the other switches are also from jaycarand have a blue led which shines through a small clear ring in the top was wondering if anyone has had much luck with theUSB module on a SEQ in a windows XP enviroment . I am still miles away from finishing this particular project i still haven'tfinished making the cct board for the switches on the right bank not happy with my first attempt so re-doing itIMG_4020.JPG
stryd_one Posted June 13, 2008 Posted June 13, 2008 Looks like you winged int on mystery LCDs and got lucky, they look good... Could I see more pics? Like, with text and from angles and such?
dcer10 Posted June 26, 2008 Posted June 26, 2008 That beast is HOT!I have the same blue lcd in my V1 SID, very nice... You can buy them at crest technologies stryd_one. I think they are about $65 but dont quote me on the price.
diablojoy Posted June 28, 2008 Author Posted June 28, 2008 sorted the silicone grips for the knobs only taken me six months ::)finally worked out car vacuum tubing from the local super cheap auto store would workvery nice feel very grippy see attached pics will be stripping the unit down completely next so i can powdercoat the chassis blue and white will post more pics after i have finished and got it up and running.knob closeup.JPGIMG_6913.JPG
stryd_one Posted June 28, 2008 Posted June 28, 2008 Those knobs are AWESOME dude, way to DIY!!!Edit: it was WELL worth the 6 months.
diablojoy Posted June 29, 2008 Author Posted June 29, 2008 there are orange L.C.D listed at newhaven displays but i dont know if they will work as the controllis listed as ks0066u ??? if anyone knows definitive answer i will keep researching this as i am also looking fora couple of orange displays for pair of midibox cv"s i want to start soon.
stryd_one Posted June 29, 2008 Posted June 29, 2008 there are orange L.C.D listed at newhaven displays but i dont know if they will work as the controllis listed as ks0066u ??? if anyone knows definitive answer i will keep researching this as i am also looking fora couple of orange displays for pair of midibox cv"s i want to start soon.Try a wiki search for ks0066 ;)...or the recommended controller, hd44780 ... either search will get you to a comptibility list, that says that the ks is all good. Just watch out for negative contrast voltages and higher voltage backlights.
diablojoy Posted July 1, 2008 Author Posted July 1, 2008 yes i actually did that today and also elsewhere it seems that the ks0066u controllers are compatible allthough there are slight changes to some wait timesthe backlight voltages are fine as are the contrast voltage so looks like it"s all ok good enough for me to try them out for the next project at least anywaycrystalfonts also have their version as well it also looks likely so orange not so bad after all. p.s they also stock red.
diablojoy Posted August 3, 2008 Author Posted August 3, 2008 Not a lot of time lately but here is a couple of pics of the inside for those that requested themIMG_2287.JPG
ilmenator Posted August 3, 2008 Posted August 3, 2008 Good work!Looks like there is heaps of hot glue on the IIC modules - what for?
diablojoy Posted August 5, 2008 Author Posted August 5, 2008 my not so good first idea for holding everything in place while soldering :-[ ::first boards i have touched in over 20 years and i remembered some boards from back then [ NEC i think ] using something similarnow i just use tape ::)
diablojoy Posted November 2, 2008 Author Posted November 2, 2008 up and running !have not found any issues so far, all good .IMG_8215.JPGIMG_8215.JPG
stryd_one Posted November 2, 2008 Posted November 2, 2008 Is there an MBOTW post for this yet, or should I move it?
diablojoy Posted November 4, 2008 Author Posted November 4, 2008 Is there an MBOTW post for this yet, or should I move it?I had not considered doing that , if you think its worthy by all means move it .However i am not yet happy with the way the front panel labeling has come out .I used the process i normally use on guitar headstocks which requires quite a few coats of lacquerover the top, not so good on ally as you can't build it up as thick and it comes out very shiny [see attached pic ]I can dull it down but it is a very slow and tedious process . unfortunately i don't have the time at present to do thisTo many other projects including a figured maple dining room table for the missus which i promised her as a trade off so i can build a large modular synth .IMG_8311.JPGIMG_8311.JPG
