Flemming Posted September 2, 2009 Posted September 2, 2009 Aw man, i forgot about the new integrated SM :) that would definitely be a nice option!! I never used it, mainly because the VSTs cannot be used outside FL. I didn't know we were waiting for version 9, i'm running beta 8.5... And yes, i'm registered and a forum member at image-line, but i very very seldom visit - maybe because i never have complains about FL ;)
Labelwhore Posted September 2, 2009 Posted September 2, 2009 I never used it, mainly because the VSTs cannot be used outside FL. That's because the FL version doesn't actually create VSTs, but rather native FL plugins. The standalone can export actual VSTs.
Flemming Posted September 2, 2009 Posted September 2, 2009 That's because the FL version doesn't actually create VSTs, but rather native FL plugins. The standalone can export actual VSTs.I know.. thats why i do not use it ;)
TheAncientOne Posted September 9, 2009 Posted September 9, 2009 An Idea:There are a vast range of digital potentiometer chips available, (Farnell show 300+ in the volatile type, and 140 or so in the non-volatile type).If an I2C/SPI version were chosen, the aout could be dispensed with, though since most are 256 step, there might be zipper noise issues in doing AM.A small board of 8 duals would fit nicely in the MB 6582, as well. there are also SMT singles that would fit nicely tooI've used the older Maxim/Dallas ones to implement a remote volume control for poweered speakers, which used opto isolated RS485 loop to control the chip via an 8 pin microcontroller, (I can't remember which one it was - I did the spec and initial design, the customers micro wizard did the programming).The pots come in Log models too.I might have a look once I get back to building.
lucem Posted September 10, 2009 Posted September 10, 2009 The microchip ones are quite good, too...plus, the also come in double packages :)
Smithy Posted September 10, 2009 Posted September 10, 2009 Hi TK,im sorry to bother you but i was wondering if there was a quick way of hacking the existing CC/NRPN chart,and replacing it with my own CC/NRPN numbers for the desired parametrs?If you could point me to the file which needs to be edited, and recompiled it would be great.Cheers.
TK. Posted September 10, 2009 Author Posted September 10, 2009 Following files have to be modified:http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsynthesizers%2Fmidibox_sid_v2%2Fsrc%2Fsid_par_table.incandhttp://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsynthesizers%2Fmidibox_sid_v2%2Fsrc%2Fsid_cc_table.incBest Regards, Thorsten.
Smithy Posted September 11, 2009 Posted September 11, 2009 Following files have to be modified:http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsynthesizers%2Fmidibox_sid_v2%2Fsrc%2Fsid_par_table.incandhttp://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsynthesizers%2Fmidibox_sid_v2%2Fsrc%2Fsid_cc_table.incBest Regards, Thorsten.Thanks TK, youre a star! :D
