hello
i made some 6582 panels for me and friends so there's some spares
50e +shipping with 1,5mm aluminium laser cut , front and back
thank you
Edited by reboot
  • 2 months later...
hello
if at least 10 persons need this panel i can order some more ...
let me know .
i'll post new pics soon
reboot
Edited by reboot
May be interested in a set here too, wondering though, the LED holes don't appear to be drilled on the photographs in the first post?
The whole thing looks like being covered with a Lexan overlay? Where did you order that?
hello
sorry for the delay ....
the lexan panels i had have a problem as i didn't checked my illustrator file .
i will organise a batch next week .
price will be around 80 euros max .
the lexan will have a window included like this ..
http://picasaweb.google.com/catchreboot/MBSID#5359182162824829698
not here
http://picasaweb.google.com/catchreboot/SidPanels#5509422095551359858
i can fix the lexan on the panel for you and spacers if you need .
ilmenator, you're right , the leds are not drilled , it's like opaque film .
same technique :
http://audio.chernis-grant.com/pictures/ebay/minimoog/DSC01863.jpg
Ize , i an do a panel in 2mm alu anodized or 1,5mm metal or 1,5 inox a bit like mirror but it can have imperfections .
your impressions are welcome
thank you
Edited by reboot
well, seems good but, the next batch will have that imperfection on the lexan?
about the imperfection, do you mean the one in the photo where the lcd button's holes in the lexan are not in place with the metal panel's holes?
i've noticed in the first post, left photo, the bottom left screw seems like had flex the panel like it is made of plastic or thin metal, can you explain? :)
thankyou.
G.
hello ganchan,
the next batch will not have the imperfection on the lexan , it concern just the laser cut .
the flex you see is because i screw a bit too much , the lexan is like a thick sticker , i can cut the holes in 4mm or more .
on the metal panel ,
the leds and buttons holes will be 4mm instead of 3 and 3,5mm , and window 1mm bigger.
in this case it's impossible to see the panel after lexan fixed .
pics very soon .
i like to see the panel with a led lighting in the back if it possible.
if you had screw too much and flexed the lexan i can assume that this is 2mm or more..
i've never see a sticker on meta flexed with a screw, is too thin :)
I already have a Aluminium Panel.. as i dont know exactly what lexan is, will i be able to fit it over my panel ? i have a red eloxated one, but i would like black, so can i just put a black lexan overlay on it ? How much would it cost. Thanks Patrick
