Now it loads, with some special character bugs
According to the datasheet of your OLED, the ROMA character set will print out an ö instead of |
It seems that ROMC is better suitable.
The C code shows how to change it:
    Write_Command(0x72);  //Function Selection B. Select the character no. of character generator    Select character ROM
    Write_Data(0x01);  //CGRAOM 248 COGRAM 8   Select  ROM A
I guess that you've to Write_Data(0x09) instead (see http://www.buy-display.com/download/ic/US2066.pdf, page 29)
and reboot every 30 seconds
A reboot indicates that the USER_LCD_WaitUnbusy takes too much time.
In other words: sometimes extremely much time (> 100 mS) - not desired anyhow.
This could be caused by a protocol incompatibility with your display.
On the other hand: it seems that this LCD is so fast, that maybe the BUSY flag doesn't need to be polled at all! :smile:
Could you please check what happens if USER_LCD_WaitUnbusy just returns immediately without polling the status flags?
Thanks for reply, Thorsten.
Yesterday I found that i missed CAN interface diode. Soldered it and cyclic reboots are gone. Nex time I should better read paragraph [3] of your MBSID troubleshooting doc  :blush: .
"|" character started started look normal when i'm change
movlw	0x01        	; /////////////////////CGRAOM 248 COGRAM 8   Select  ROM A
	rcall   USER_LCD_Data
with this.
	movwf	USER_LCD_LAT_D
	rcall	USER_LCD_Strobe_Set
	rcall	USER_LCD_Strobe_Clr
	movlw	50			; 50 ms delay
	call	MIOS_Delay
	call	MIOS_Delay
Looks like USER_LCD_Data function not working correctly with this OLED.
Sending 0x09 instead to select ROMC makes no sense. Characters still ok.
T.K., the question is how should look the 4-bit equivalent of this?
        swapf USER_LCD_LAT_D, F
	call	MIOS_Delay
        call MIOS_Delay
	call	MIOS_Delay
post-9659-0-74262600-1383022894_thumb.jp
Posted (edited)
	rcall   USER_LCD_Data
with this.
	call	MIOS_Delay
	call	MIOS_Delay
	rcall	USER_LCD_Strobe_Set     ;
	rcall	USER_LCD_Strobe_Clr     ; transfer upper 4 bit
        swapf   USER_LCD_LAT_D, F       ;
	call	MIOS_Delay
        rcall   USER_LCD_Strobe_Clr     ; transfer lower 4 bit
        call    MIOS_Delay
	call	MIOS_Delay
Is that correct or I have to duplicate USER_LCD_LAT_D, F two times more?
I have some suspicions about 4-bit init fail.
app_lcd.inc
Edited by Schrabikus
Actually you would have to remove one strobe, because currently you transfer 3 nibbles instead of 2
And you transfer three times a 0 (-> would result into 0x000), because in 4bit mode only the data at the D7, D6, D4 and D4 pin will be taken over by the LCD.
The 4 bit protocol is: first strobe for the MSBs (data bits 7..4 directly visible at D[7:4]), second strobe for the LSBs (data bits 3..0 copied to D[7:4], e.g. via "swapf LATD, F")
You can see the difference in the original implementation: http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fmios%2Fmios_clcd.inc
General hint: if you do such experiments (with the danger that the LCD comes into an invalid mode), it makes sense to re-power the core after the code upload to ensure that it starts under "known conditions" (power-on reset).
In 4bit or 8bit mode?
Possible reason: USER_LCD_Data is only made for 8bit mode
Anyhow, currently I'm a bit confused about your posting. :-/
- are you planning to use the LCD in 4bit mode in future - and if yes: why? You've already all connections for 8bit mode
- is the LCD working correctly in 8bit mode now?
OLED is working fine! A little noisy, but
I think you're right, if it's working - no need change anything.
4-bit is good for hardware compatibility, but not so critical. I'm just wanna deal with it to adapt this display to another projects with no possibility of 8-bit connection.
Thanks again!
Hmm. This sounds like a good time to take another look at going after an OLED. So for a more standard OLED, all that needs to done is to solder the SMD pads and use the custom LCD driver?
Posted (edited)
wrt OLED noise: What worked REALLY well for me is to use a separate 5V supply just for the OLED (Wave 1 Rolf suggested this).  I just soldered in a 78L05 in the first two pins and added a 0805 100n between them and another 10uF on the other end and it dropped the noise by at least two-thirds.  I dont know how well it would work tapping behind a linear vReg (this was on a Shruthi build, the LT1054 has very good noise rejection) but i'll be using that set up when I give the 20x4 OLED another go for my MB6582 since I use a switching 5V vreg there anyway
Edited by Altitude
If 4bit mode is still for interest: you need a different USER_LCD_Data and USER_LCD_Cmd routine, because the one from the src/app_lcd.inc of the MBSID V2 application is only applicable for 8bit mode.
USER_LCD_Data should look like:
USER_LCD_Data
    ;; store byte in data latch
    ;; wait until display unbusy
    rcall   USER_LCD_WaitUnbusy
    ;; exit if current LCD not available due to timeout
    btfsc   USER_LCD_STATUS, USER_LCD_STATUS_CUR_DISABLED, BANKED
    return
    ;; select data register
    bsf     USER_LCD_LAT_RS, USER_LCD_PIN_RS
    ;; activate write
    bcf     USER_LCD_LAT_RW, USER_LCD_PIN_RW
    ;; strobe
    ;; transfer lower 4 bit
    ;; strobe and exit
    rgoto   USER_LCD_Strobe_Clr
and USER_LCD_Cmd:
USER_LCD_Cmd
    return
    ;; select command register
    bcf     USER_LCD_LAT_RS, USER_LCD_PIN_RS
    ;; activate write
    ;; strobe
    ;; strobe and exit
this is untested code!
Please also replace the (wrong):
	call	MIOS_Delay
	call	MIOS_Delay
by:
        rcall    USER_LCD_Data
and doublecheck later, if 0x09 is maybe the better value
  • 3 weeks later...
That's fantastic news!
I hit a snag related to having to support the OLED both in the bootloader, and in the app itself last I checked. Hmm. hopefully there's some time for this during the x-mas break...
  • 3 months later...
I think that Scifo and Schrab were in luck with their builds. It would be nice to get a blow-by-blow write up on how to get an OLED rolling. I got frustrated and left the OLED alone to pursue some other DIY projects for the longest.
:D
I saw that Newhaven had revised their datasheets for the 4x20 OLEDs so that the actual jumper section looks like it does on the display. That might be a great way to get one working in 8-bit or 4-bit mode as you see fit...
With some luck things will be more calm round here so that I could investigate a bit.
  • 2 years later...
On 22.7.2016 at 8:55 PM, Altitude said:
i was never able to get it to work
You need a hacking +10 stat in your character sheet to enable OLEDs or VFDs for the MB6582 ;-)
  • 7 months later...
Ah damn.. i should have checked the forum before buying a Newhaven Oled.. sad part is that i even paid a lot of import duties and shipping for it :(
Nobody got it working yet ? :(
Guest
Reply to this topic...
