Nice SD Card board on ebay
Altitude
Thought I'd share this.
http://www.ebay.com/itm/1x-SD-Card-Module-mini-reader-socket-module-/170826337065?ssPageName=ADME:L:OC:US:3160
I just snapped up a couple of these and it should be an easy connection to a Core board (will report back confirming that).  They have a 3.3V/5V switch, regulator, and a micro SD slot on the back.  I like these a lot better than some of the other aurdino one since they have the holes on the side of the slot like seppomans board did so mounting it to the panel via L brackets is possible
These DO NOT work out of the box, the transistor buffers screw things up for some reason and need to be removed like here.  I used 0 ohm 0603 resistors but a piece of lead wire will work fine.  Once this is done, it works fine.
Edited by Altitude
Link to comment
Share on other sites
  • 2 months later...
  • 2 weeks later...
This one is missing the mounting holes at the front.
The one Alitude has linked is cheaper here:
http://www.ebay.com/itm/SD-Micro-SD-Card-Breakout-Module-5V-3-3V-Compatible-e-/281116152546?pt=LH_DefaultDomain_0&hash=item4173d412e2
Edited by Shuriken
Link to comment
  • 1 month later...
in my case i need it, since i make mine in a 1U rack case and like to bring it to the front. this one with holes would be more convenient than the sparkfun i have that requires cable tie mounting.
i'll come to finish Ambika soon, then i'll try with transistors first. they're easily wiped off if i need to mod.
the greater problem at least for me is that i'm not sure which pads on ambika go to which pin (different number of pins with the sparkfun, haven't checked this one yet)
Edited by rosch
Link to comment
  • 4 months later...
  • 1 month later...
Guest
Reply to this topic...
