Phatline Posted July 22, 2018 Report Posted July 22, 2018 (edited) 15 hours ago, Phatline said: is the rest of layout the same as the files you released here? (V0)(specially the j89 10 11... and the mounting holes?) (i ask because i would then project around this- to simple plug your core into my UI... i would then if i get it fit - need some of those cores.) if you make a run how many is minimum. and what is priceing. do the place machine pick all smd parts on top? @FantomXR ? thx for info 10 hours ago, slo said: @Phatline With Midi I/O module connected you get 2 in and 2 out midi connections you are right, was late last night... maybe i only saw HiSpeed and... didnt see: 9 hours ago, Antichambre said: What is the features of this board? Which legacy ports are available? What is the size of the board? download the files (if you have eagle) and see: Size V0: 98,5mm x 48,5mm ? Features, Legacy ports: see screenshot, (there is the SD-Slot Missing, since @FantomXR said, he changed something?... and for me it is NOT necessery, in this picture, because i need only the Pin-Headers for a Sandwitch- Footage-Kicad-Part to import.) PURPOSE: (by looking @ shematic) J8/9 SRIO (for normal shiftregisters) Midi A+B (+HiSpeed? )(need external Optocoppler), J30 Displays(need external HC595), Bootloader-Switch(for program-alphas...debug), onboard-Voltage-Regulator (5V input regulated to 3,3V), Micro-SD-Slot(flat on board), USB over Pinheader (no onboard-socket), USB-Power-Jumper J6+J7 - Pedals+Fader are a bit J19-ish (AOUT-SPI) but thru a MCP3208? used as: "for an AINSER64-like-analog-scanning" (connect there a AIN64? dont know) SWD-Header (to program BOOTLOADER into board by using for a example a Discovery-Board), Reset-Header ... @FantomXR are the Connectors and Mount Holes still the same in current Version? Edited July 22, 2018 by Phatline Quote
FantomXR Posted July 22, 2018 Author Report Posted July 22, 2018 Since I just received the PnP machine last week I don't have enough experience yet to give you informations about prices. But yes: The PnP machine places all SMD parts which are not too high f.e. electrolytic capacitors. I didn't try double-side-partmounting yet. Regarding your comments: I use external optocoupler for MIDI I/O Micro-SD Slot is on the back of that PCB J6 & J7: I made some pcbs with faders which I connect directly to that connectors. There is no "current" version. It's a proof of concept, which worked. So I used the circuit around the STM provided in this design here in my other projects. 1 Quote
Phatline Posted July 29, 2018 Report Posted July 29, 2018 (edited) On 21.7.2018 at 9:09 PM, FantomXR said: On 22.7.2018 at 4:06 PM, FantomXR said: there is no "current" version. It's a proof of concept, which worked. and improved the design which I populated here. ? then files for the "improved" design. ? or the info: are any connector positions(xy) have changed thx mike Edited July 29, 2018 by Phatline Quote
FantomXR Posted July 30, 2018 Author Report Posted July 30, 2018 To be honest I can not follow you. I improved the design which I published here and used that in my other designs which I don't want to make open source. For example I changed the oscillator to SMD, I changed all none-VDD-traces to 0.2032mm, I changed all vias to round-style and 0.32mm diameter. I removed the ID-pin from USB. I added an inductor behind the USB connector for EMC-improvements. Also I changed all 0603 SMD parts to 0805. Those are a few changes I made in my other designs. Quote
Phatline Posted July 30, 2018 Report Posted July 30, 2018 @AntichambreC "could we help you to improve it?'" if you have ideas... i definitivly would be in for some "minimal boards" work in that trace wide and smd quarz changings and maybe microsd footprintchange. dont know how many bords also depends on the price of course (have not much clue about pick and place and the time for stuffing that machines...) i find it practicable when the IO connections are in one row specially j89 and the midi . to plug it into a small io (10x10 for example) so they dont cross the middle of ui where are matrices buttons or leds. what improves you thought? Quote
Antichambre Posted July 31, 2018 Report Posted July 31, 2018 @Phatline Yes a small and generic board could be a great thing, I'm always tempted to use the LPC for its size but I need the STM features for some applications :/ This must be a clever alternative to the wCore, not a concurrent but an answer where the wCore can't fit our design. There's a lot of way to think about it, we can maybe start a new tread and begin to discuss about it... 1 Quote
FantomXR Posted July 31, 2018 Author Report Posted July 31, 2018 I'm happy to help you if you need some assistance. You are welcome to start a new thread I'll join in. 1 Quote
Phatline Posted July 31, 2018 Report Posted July 31, 2018 3 hours ago, Antichambre said: @Phatline Yes a small and generic board could be a great thing, I'm always tempted to use the LPC for its size but I need the STM features for some applications :/ This must be a clever alternative to the wCore, not a concurrent but an answer where the wCore can't fit our design. There's a lot of way to think about it, we can maybe start a new tread and begin to discuss about it... agreee... so what we call it? miniCore32, 10x4CORE, RFcore(reduced formfactor)....-names based in formsize. or a name based on the limited/reduced ports- fundimentalCore, basisCore, baseCore... or a name as tributs based of the inital designer - XRcore . while x as variable for size . f for formfactor... or something with midi in it. since core is a common widely used name also in other genres... midicore (not the smallest not the tallest the medium.,. and of course midi as protocoll view) new thread with choosen corename then in design concepts again. i have some time left. and have interest and use of it. so what we call it... and start Quote
Antichambre Posted July 31, 2018 Report Posted July 31, 2018 (edited) mnmlCore for minimal maybe, I don't know like you want ;) The perfect thing could be to get the exact same ports as the Core8, with a smaller package of the stm32f407on a DIP-40 formatted board. => this will allow to upgrade all old midiboxes easily, increase processes and speed of @latigid on 's BLM for example... => we've got it for other new tiny application. Just an idea, but it's maybe impossible to get the exact same pinout and everything on a DIP40 board, don't know... Edited July 31, 2018 by Antichambre Quote
FantomXR Posted August 1, 2018 Author Report Posted August 1, 2018 I took a look at the Core8 and I'd say that it should be possible to create a PCB with the STM with that size and the same pinout. Not sure if it makes any sense though. Anyway: If we want to use my pick & place machine it's good to have 5 PCBs or more of the same type at the same type. Are you guys familiar with routing and creating PCBs? Who wants to do it? Quote
Phatline Posted August 1, 2018 Report Posted August 1, 2018 i am familiar, with it, etched and drilled my single sidet pcbs ano 2008 or so... had expirience with the old eagle, now a bit with the new autodesk ones (import export run scripts to get footprints and shemes them to kicad ;) ), have more skills on the kicad 4... the not released yet offical kicad 5 can import whole eagle projects (so this core for example can be ported)... but i never prepered a file for external fabrication (design rules for specific fabricators... but know soldermask... whatching the eevblog) - i want to do it... or at least try it with kicad 5 (how good this eagle import really works) --- start by comparing core 8 with core32, --- but for me pinout core32 makes more sense, --- hand drawing for small Projects usecases: where are the ports situated, to make it sandwitch-able, what about midiports and so on...core 8 had midi onboard, which makes sense, the midisocket makes no sense of course (since you can built the device in rack or desktop... AND this thru holes optos take to much space for such tiny pcb - and make routing around very hard... > so for me it is in the early concept phase - maybe use smd-sockets for the thruhole optos - or solder smdoptos directly on board, ...the midi pcb itself would be as slim as the socket, and could be situated on the same pcb with break-drills/cuts to break it away (rack desktop, middle of ui, back of the uipcb-situations) ... and so on - i start a new thread soon. for talking more about concept. Quote
Phatline Posted August 2, 2018 Report Posted August 2, 2018 (edited) i made a new topic: i made a wiki: http://wiki.midibox.org/doku.php?id=mnmlcore#pcb_fabrication_pick_and_place @FantomXR i imported your files into kicad5, the board looks like this: The Airwires which are "ground" going to ground, since you fill everything with ground - i understand ... but what is it about the rest of that airwires ( i see the same in eagle) for example-the bootloader-header - it has a 3,3V airwire, dont think you made a 3,3V Plane there? (no isolation on the ground side) --- only ask - because maybe i have to turn on anything in eagle to show up... or you didnt need them - thx for info. Edited August 2, 2018 by Phatline Quote
slo Posted February 17, 2019 Report Posted February 17, 2019 (edited) I made a display addon for this minimal core. This was my first attempt at Eagle and while the resulting PCB had a few errors I was able to kludge the first version and get it working. The display addon snaps into the original minimal core board with standard .100" male/female headers. I also made a reduced Midi I/O with a thru section using TRS jacks, (thanks Andy for the footprint) this also works well. My goal is a small scale SCS box to run a small synth switcher/routing unit. I will upload the files when I've time to fix the errors. @Fantom XR thanks for the core board and inspiration. Edited February 17, 2019 by slo Quote
