armandhammer Posted April 8, 2021 Posted April 8, 2021 And I’m done! Seriously this was so easy (once I figured out that I needed to reflash the bootloader) thanks to Midiphy sourcing of quality components and a straightforward instruction video. It was fun picking out different color LEDs for the status indicator. Not shown are the first 4 (F1, F2, G1, G2) which are cool white, warm white, red, orange — then green, blue, pink, cool white in the pic. Now let’s see what this thing can do :) (note in the pic the screen looks weird due to the refresh rate of the OLED vs my iPhone camera)
latigid on Posted April 8, 2021 Posted April 8, 2021 Excellent job! Regarding the light|shield/standoff collision, I had the same experience but like you say, it is simple to just cut out a little bit. I also found that it was useful to cut out a bit of the waveshare JTAG header (the side near the crystal) to avoid collisions with the THT resistors on the back of the base PCB.
armandhammer Posted April 8, 2021 Posted April 8, 2021 Ohh one last thing for now: what's the best procedure to install the plastic OLED protector? I thought about hot glue, but maybe there's some better way...
latigid on Posted April 8, 2021 Posted April 8, 2021 It should press fit but Peter has a technique to use Scotch tape to hold it in place before lowering the case. For me, I slightly roughen the back powder coating (say 120-grit sandpaper) and apply drops of superglue to the corners, away from the edge. Then I carefully place the protector in. If you mess this up though, you'll get a nasty smear on the plastic, so tape is probably safer and sufficient.
silverlight2004 Posted May 12, 2021 Posted May 12, 2021 Hi Peter and team, I have a feature request for next update...would it be possible for LoopA to record multiple midi channels per track? Also a previous request i still am interested in would be for dynamic allocation of memory, so for example, all 36 clips could share a common total note pool and the user may allocate them as preferred. many thanks for your work Dave
Hawkeye Posted May 12, 2021 Author Posted May 12, 2021 @silverlight2004 Thanks a lot for the suggestions, Dave! The dynamic memory allocation feature is on the to-do list (but it's not easy to implement...) Multi MIDI channels per track/clip unfortunately most likely cannot be supported, as the whole architecture of LoopA is based on having a single MIDI OUT or a single instrument per track - basically all code relies on that. Supporting notes with potentially different MIDI channels within a single clip would both consume more memory (which is quite maxed out already) and would make it super difficult to visualize what is going on using the OLED. Supporting this would also make it impossible to remap existing clips to other instruments (which have only a single OUT/CHN pair). Ultimately, i think it could confuse users, when some notes in a clip are played, back while others are not played (i.e. because there is no synth listening to "their" MIDI channel). For multi-recording two synths at once (i.e. two keyboards), it would be easiest to rely on a second LoopA, that is MIDI-synced to the first - which also doubles the amount of parallel tracks available. I know at least one power user (not me), that uses two LoopAs for this :). Many greets, Peter
silverlight2004 Posted May 13, 2021 Posted May 13, 2021 thanks for the quick reply Peter! hope you do manage to work out the dynamic memory...and i fully understand your answer about multiple midi channels...it makes a lot of sense actually would be pretty confusing considering the overall design and workflow of loopA. But you gave me a great idea to think about using 2 loopAs in parallel for 12 tracks of sequencing...maybe for the future... dave 1
Hawkeye Posted May 28, 2021 Author Posted May 28, 2021 Thanks Dave, also for this fantastic sequencing demo from you! Glad to see a LoopA used properly, how it was intented to be used: Best regards and have a happy weekend! Peter
silverlight2004 Posted May 29, 2021 Posted May 29, 2021 (edited) 3 hours ago, Hawkeye said: Thanks Dave, also for this fantastic sequencing demo from you! Glad to see a LoopA used properly, how it was intented to be used: Best regards and have a happy weekend! Peter Thanks to you Peter and Michael who built LoopA for me and for the continuing support you offer. It's a great sequencer...look forward to working more with it and as it gets even better with continuing updates! Best regards from Bali...Dave Edited May 29, 2021 by silverlight2004
Arnold Moon Posted May 31, 2021 Posted May 31, 2021 Loving LoopA and SeqV4+, it'd be super awesome if we can sync the two! the only super minor wish I have with LoopA is external program/scene change (sounds this is already planned!) with an option to reset playhead when changing scene. there is an edge case for my need, that is I have a scene that is not aligned with measure, ie 16bar loop but sig change at last measure, something like 15*4/4 + 5/4. As sig change per/mid clip is not possible (even if it was I guess LoopA is not keeping track of them..), I just set clip length to be ie 65. It works well for the scene, but that is affecting scene change timing and also where the playhead should be when transitioned to next scene, (well it is expected behavior as my scene is not aligned) I think when external program/scene change gets implemented, with option of restarting global scene timer, seqv4 can manage song structure with all the seqv4 glory, and get non-step based fluid sequencing of LoopA to rule them all. thanks for all the hard work and dev again, super appreciated!! Arnold
Phatline Posted June 2, 2021 Posted June 2, 2021 On 5/31/2021 at 6:50 PM, Arnold Moon said: Loving LoopA and SeqV4+, it'd be super awesome if we can sync the two! the only super minor wish I have with LoopA is external program/scene change (sounds this is already planned!) with an option to reset playhead when changing scene. there is an edge case for my need, that is I have a scene that is not aligned with measure, ie 16bar loop but sig change at last measure, something like 15*4/4 + 5/4. As sig change per/mid clip is not possible (even if it was I guess LoopA is not keeping track of them..), I just set clip length to be ie 65. It works well for the scene, but that is affecting scene change timing and also where the playhead should be when transitioned to next scene, (well it is expected behavior as my scene is not aligned) I think when external program/scene change gets implemented, with option of restarting global scene timer, seqv4 can manage song structure with all the seqv4 glory, and get non-step based fluid sequencing of LoopA to rule them all. thanks for all the hard work and dev again, super appreciated!! Arnold hab so gelöst: in der app.c vom loopa: ///////////////////////////////////////////////////////////////////////////// // This hook is called when a MIDI package has been received ///////////////////////////////////////////////////////////////////////////// void APP_MIDI_NotifyPackage(mios32_midi_port_t port, mios32_midi_package_t midi_package) { //909 Phatline /// MIDI Control & Program-BANK LOAD STORE #define CC_PC_Bank 32 // Bank for Program-Changes in order to use more then 128 songs.... static u8 Bank = 0; // Bank 0 = PC 0-127, Bank 1 = PC 128-255 .... #define CC_SCENE 33 // SCENE 0-5 #define CC_Save 24 // external store signal, so this app save @ same time like external (only one save button in setup) switch( midi_package.cc_number ) { // each Bank has 128 Programchanges... case CC_PC_Bank: Bank = midi_package.value * 128; break; // Program-NR + Programbank case CC_Save: saveSession(midi_package.value + Bank); break; case CC_SCENE: if(midi_package.value < 6) { sceneChangeRequested_ = midi_package.value;} break; break; } } //909 Phatline /// P R O G R A M C H A N G E Program if( midi_package.type == ProgramChange) { loadSession(midi_package.evnt1 + Bank);} i remote all my self developed gear with Bank CC32.... and to SAVE i use for ALL: CC24 .... so i only have to press SAVE on the MAIN-Gear and all slaves do the save. For Scene Select i took CC33. This SceneChangeRequest is in SYNC! - and i did not change any part of the LooPa -it is already there... except of the part i postet here.
Arnold Moon Posted June 2, 2021 Posted June 2, 2021 7 hours ago, Phatline said: hab so gelöst: in der app.c vom loopa: ///////////////////////////////////////////////////////////////////////////// // This hook is called when a MIDI package has been received ///////////////////////////////////////////////////////////////////////////// void APP_MIDI_NotifyPackage(mios32_midi_port_t port, mios32_midi_package_t midi_package) { //909 Phatline /// MIDI Control & Program-BANK LOAD STORE #define CC_PC_Bank 32 // Bank for Program-Changes in order to use more then 128 songs.... static u8 Bank = 0; // Bank 0 = PC 0-127, Bank 1 = PC 128-255 .... #define CC_SCENE 33 // SCENE 0-5 #define CC_Save 24 // external store signal, so this app save @ same time like external (only one save button in setup) switch( midi_package.cc_number ) { // each Bank has 128 Programchanges... case CC_PC_Bank: Bank = midi_package.value * 128; break; // Program-NR + Programbank case CC_Save: saveSession(midi_package.value + Bank); break; case CC_SCENE: if(midi_package.value < 6) { sceneChangeRequested_ = midi_package.value;} break; break; } } //909 Phatline /// P R O G R A M C H A N G E Program if( midi_package.type == ProgramChange) { loadSession(midi_package.evnt1 + Bank);} i remote all my self developed gear with Bank CC32.... and to SAVE i use for ALL: CC24 .... so i only have to press SAVE on the MAIN-Gear and all slaves do the save. For Scene Select i took CC33. This SceneChangeRequest is in SYNC! - and i did not change any part of the LooPa -it is already there... except of the part i postet here. Thanks for sharing! I'm super new to midibox land, I'll look into cloning the git repo and play around! Arnold
Phatline Posted January 16, 2022 Posted January 16, 2022 (edited) currently untestet concept for a eurorack panel for the caseless LoopA. http://wiki.midibox.org/doku.php?id=loopa-eurorack-panel Edited January 16, 2022 by Phatline
Hawkeye Posted February 5, 2022 Author Posted February 5, 2022 New LoopA firmware version 2.09 released The newest LoopA firmware contains fresh features like - force-to-scale mode - new stave notes display mode - integrated midi keyboard mode and keyboard transposition - note duplication and clip reversals - integrated six track volume mixer - LoopA remote control via MIDI Program Change and CC - MIDI Program Change synth patch loading after session load Enjoy and many greets! Peter
JuanJerez Posted September 19, 2022 Posted September 19, 2022 (edited) On 5/28/2021 at 11:13 PM, Hawkeye said: Thanks Dave, also for this fantastic sequencing demo from you! Glad to see a LoopA used properly, how it was intented to be used: Best regards and have a happy weekend! Peter Good evening, forgive my clumsiness but...how is it possible to delete the notes by turning the value knob? I have the latest firmware version 2.09 and I can only delete the notes one by one click by click. It's not important, I'm just curious. Edited September 19, 2022 by JuanJerez
latigid on Posted September 19, 2022 Posted September 19, 2022 One way is to use the punch in footswitch mode, but that's not exactly the same. Unless Peter knows of another way, maybe it could work to have scrub+footswitch (punch in) also delete notes under the cursor when the sequencer is not running? Also an idea is to allow an "off" footswitch setting, for example if you only have a mono footswitch.
Hawkeye Posted September 22, 2022 Author Posted September 22, 2022 @JuanJerez as LoopA's notes are reconded sequentially, deleting a note will auto-advance the note cursor to the next recorded note, so you can do it by selecting the start point and then pressing DELETE multiple times quickly - i just tried it on a complex chord clip and it works fast enough and also allows for good precision when reaching the end point. LoopA's user interface is a bit too small for "range selection" commands without getting too complicated. But as Andy wrote, another good alternative is to use the punch-out footswitch function, which allows you to just clear a part of the sequence while the time cursor passes over it. Many greets and enjoy! Peter
Hawkeye Posted February 25, 2023 Author Posted February 25, 2023 Hi there, just wanted to let you know that we continued development of the LoopA - it has a new and quite powerful song mode now: Best regards and enjoy! Peter
zfigz Posted August 20, 2024 Posted August 20, 2024 (edited) all done! Edited September 3, 2024 by zfigz
Tony Posted January 11, 2025 Posted January 11, 2025 Hello ! I'm the new, proud and happy user of a LoopA. I do improvised live sets and its autoloop recording is an amazing feature that opens up a whole other vibe to what i can do in terms of tempos and atmosphere. I read through the manual twice and there are a couple of features that i was looking for and didn't find, i don't know if i have missed them or if they are not implemented. The first one is the possibility to start, on a given track, the recording of a new clip immediately after the playback of the current clip has ended (say if i'm looping on an intro and want to start recording and looping a verse), like i can do on a Keystep Pro. Is there any way to do this with scenes for instance? The second one is to link another sequencer with the LoopA, in my case the Keystep. I really love the ability of the LoopA to determine a tempo without having to think about it, and the fact that it can support long and weird chord changes, and i would love to chain the Keystep so i can use sequences with my Eurorack case. Any way to do this? And on the side note, for a future firmware update, it would be great to be able to configure the BLM port so that it can be used as an extra Midi in or out. Thanks for your feedback!! Antoine
