DavidBanner Posted January 22, 2007 Report Posted January 22, 2007 I need to make some sort of cover for an SL1200, so that I can plonk my laptop on there and not worry about the TT getting turned on and scrambling my HD. I'm currently using a bit of foam, which works great but I'm in constant fear of the TT power being switched on.The foam works great as it's flexible, works as more protection for the laptop in the bag and keeps everything nice and stable, so I would like to keep this aspect and maybe glue a flexible layer on the top of the foam.. - any ideas? Quote
moebius Posted January 23, 2007 Report Posted January 23, 2007 Why should You get any cover for SL1200´s? No laptop hurts those.Moebius Quote
DavidBanner Posted January 23, 2007 Author Report Posted January 23, 2007 hey Mike,Good call on the stand - but have you tried to get round the back of a lot of club consoles? also it won't work if the mixer is mounted in a hole in the console... Quote
DavidBanner Posted January 23, 2007 Author Report Posted January 23, 2007 Moebius>Why should You get any cover for SL1200´s? No laptop hurts those.other way round dude - I'm worried about the big electro-magnet in the SL1200's corrutping the HD on my laptop Quote
stryd_one Posted January 23, 2007 Report Posted January 23, 2007 I could be wrong about this but I think SL's are already shielded... I'm sure I remember seeing a foil lining inside there and I don't think it's just cause the designers like shiny things ;) Of course, that's nice, but the platter itself is subject to magnetism so I don't see any way around that.You might find it easier to shield the disk drive than the deck.... Quote
DavidBanner Posted January 24, 2007 Author Report Posted January 24, 2007 just for clairty as I've just got back from a tour so my head is still foggy and I might not have made things clear:the idea is to put "something" on the platter of a 1200 as a sheild and then the laptop goes on top of that "something"the SL1200 has a metal platter and a rather beefy looking electomagnet around the spindle.My laptop will be sitting pretty much dead center over the electro magnet.Also the HD in my laptop is my primary concern, so sheilding that is not really going to be very easy. I know the ideal solution is probably a Faraday cage; but I can't get my head round a practical application.of course in an ideal world every club would have 2 of the stands Mike B suggested (one for the lappy one for the controller) - but that's never gonna happen; even with a technical rider (I've turned up to gigs in some countries with a bag of records to find they don't even have turntables, just CDs!).The other issue is speed - I need to be setup asap. When the gigs are tightly timed I often only have a few mins after arriving at the club from the last gig before I need to take over... Quote
smashtv Posted January 24, 2007 Report Posted January 24, 2007 Heya DB!Think sandwich: thin sheet metal plate, foam on top + foam on bottom, metal plate a few inches smaller than the foam (soft edges), held together with some spray mount adhesive. (wont degrade most foam)Magnetism on this order usually needs a little more than thin metal foil/copper tape like used for rfi.Sometimes I almost miss repairing open-frame arcade game monitors.... ;)BestSmash Quote
DavidBanner Posted January 24, 2007 Author Report Posted January 24, 2007 Hey Smash,I see you are the one to come to the rescue once again.One more quick question - any suggestions on how to test this without applying it to a HD? using a compass perhaps?? Quote
doc Posted January 24, 2007 Report Posted January 24, 2007 using a compass perhaps??This would be the cheapest way.Another way would be to use a selfbuild "detector". Just a ring out of metal (10-20 cm diameter) with a shielded cable connected to your multimeter.The ring acts like a detector for magnetic fields. I could swear I saw something like this before ... must find the plans again.greetsDoc Quote
Screaming_Rabbit Posted January 24, 2007 Report Posted January 24, 2007 ... don't mix up rfi with magnetism.To shield magnetism, you can't just use any metal plate, it has to be a ferric plate.Just test it:Take an alluminum plate, hold two magnets on both sides about 1/2 Inch away from the plate and you'll see (... or better: feel), that the magnetic field goes almost unhindered through the alluminum.Do the same with an iron sheet metal plate... you'll see.Greets, Roger Quote
smashtv Posted January 24, 2007 Report Posted January 24, 2007 Whoops yeah I should have been specific.....too many years here in the US where the term sheet metal implies some sort of Steel formula.... ;)The ring detector thing works well, but beware that it has a relatively limited bandwidth, similar to a tuned antenna, where a real gaus meter built/tuned for mag (and related harmonics) will show reality.I made the mistake once of mentioning using DSP to tweak harmonic attenuation in real time to a tube amp pro buddy of mine.He whipped out some notes from his past days doing scalar EM lab research.....one look at the math involved on just the harmonics side of EM caused both of my remaining brain cells to hurt, and made me happy to be "just an audio engineer" with only standing waves, resonant frequencies, and air temperature to cope with..... ;)Whoop sorry to ramble!BestSmash Quote
kris Posted January 26, 2007 Report Posted January 26, 2007 hello i dont know if this will help but you can get this stuff called mylar silver one side gold the other flexible like plastic it was designed to shield satellites in space i know it shields from radio frequencies and radiation not shure about magantism but maybe as its just another em wave its available very cheaply from hydroponic grow shops as growers use it to line grow rooms reflects light into room shields from infra red detection if you get it the right way round also good way to protect computers from em pulse so if you wrapped your laptop in it it would still work after anuclear blast as long as it not a direct hit anyway hope this helps kris Quote
DavidBanner Posted February 1, 2007 Author Report Posted February 1, 2007 Hey Kris,Done some research on Mylar and it it turns out it's no good for low freq radiation like magnets, which is a damn shame cause it's light and flexible unlike steel which seems to be the only alternative.... Quote
Screaming_Rabbit Posted February 1, 2007 Report Posted February 1, 2007 steel which seems to be the only alternative....... watch out with steel! Steel only works, if it's got enough iron. High grade inox steel has lots of Cr and Ni in it, which makes it non-magnetic and as a result, it's also not really shielding magnetism anymore. Best is: Cheap iron sheet metal. - Paint it to prevent corrosion.Greets, Roger Quote
kris Posted February 1, 2007 Report Posted February 1, 2007 thats a shame about mylar as it is easy to work with and cheap oh well its still good to protect your computer from a nuclear blast Quote
DavidBanner Posted February 1, 2007 Author Report Posted February 1, 2007 oh well its still good to protect your computer from a nuclear blast] oh well its still good to protect your computer from a nuclear blastbut only if you've got the mylar grounded. but to be honest I think i'd be more worried about my skin falling off and the crowds of cannibal looters than firing my laptop up.... Quote
stryd_one Posted February 1, 2007 Report Posted February 1, 2007 lmfao, the exact thing i thought! Quote
kris Posted February 2, 2007 Report Posted February 2, 2007 i dont know where you live but its abit like that round here anyway and ill always need my music just think post armagedon midibox Quote
stryd_one Posted February 2, 2007 Report Posted February 2, 2007 Hah it's a bit like that on any planet inhabited by homo erectus. If I'm unfortunate enough to be around post armageddon I'll be stretching goatskins over wood. I learn from my mistakes ;)I was thinking though... If the turntable has enough room to reach the back and mount a record, the laptop would have a fair bit of separation - is the magnetic field still effective at that height? Might be worth trying smash's trick ... Quote
DavidBanner Posted February 3, 2007 Author Report Posted February 3, 2007 I live in East London, so every day/night can be a scene from 28 Days Later.and then My studio has 4 clubs within 20 seconds walk from the door, one of them has a party that starts 7am Sunday Morning... So you can imagine the state of the people I see when I come to the studio on a Sunday at kicking out time!! Quote
DavidBanner Posted February 3, 2007 Author Report Posted February 3, 2007 i'm going to try the Smash trick, just as soon as I get some time.... Quote
