SwinSID - a pin compatible alternative to the SID chip
SwinSID is still in development and the new version SwinSID X2 is almost ready now. It is designed to emulate  two SID chip working with one MB core.  In fact SwinSID X2 has two AVR connected with single DAC
Latest firmware provides better sound quality (low aliasing), new waveforms and nice features: simple FM synth, two oscillators per voice and white noise generator.
Firmware is quite stable now with all features working, but I need to design layout for new MB module. If you want to help with testing or designing layout then let me know.
I will consider releasing the source code.
  • Replies 145
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
amazing stuff,cool!
@Swinkels : Is it possible to add an option to switch the aliasing-filter off? Would be nice to have some "x-tra lofi-amount" by a flick of the switch. Waldorf did this in their microwave 2 engine and I like this feature very much!
Regards
Brother303
Yes you can do it by enabling double oscilator mode - in this mode anti aliasing is not supported.
Now I'm only waiting for the new stereo demos from TK :)
  • 1 month later...
Just wanted to keep this one alive and also wanted to know if there is any news on what parts to buy  ;D
my soldering iron need work to do  ::)
So, a SwinSIDx2 module? Sweet  ;D
So, do you have a circuit diagram and need a layout, or do you need both?
  • 2 months later...
Hi everyone if you like you can download and listen some one on one demos left the 6581 R4AR right the SwinSID with actual Firmware  ;D
http://rapidshare.com/files/111795777/6581SwinSIDnew.zip.html
http://rapidshare.com/files/111815078/6581SwinSID_Test2.zip.html
Have fun while listening... and always Remeber the SwinSID can do much more than only SID Sounds!
Here is the SwinSID playing alone with Digis ...
http://rapidshare.com/files/111795778/SwinSIDnew.zip.html
8)
Crisp: I can upload the files to the midibox server, do I have your permission?
@TK
ofcource can you... no problem
and as I saw Swinkels updated some part of his site with some new Demos  ;D
If anyone has a favorite Sidtune which he wants to listen played by the SwinSID please tell...
I'd love to hear:
1. mITCH & dANE - Melissa D
2. Dwayne Bakewell (DJB) - Old Friends
;D
Finally, my download page was updated with latest SwinSID firmware for MIDIBox and dual AVR schematics. There is source code too.
I'm working now on the new SwinSID 1024 card with 512KB RAM and 512KB ROM for storing drum samples and new cool sampled sounds.
Maybe some day it will work with midibox as a external sampler (when TK modify control firmware) but first, it is intended as a hardware MOD player for C64.
Hi Swinkels,
Congratulations and thanks for your work :)
Will you upload the new source code, too? On your page I only found the source for the old SwinSid SE. And do you consider using English for the source comments of the new version? My Polish is a bit rusty ;)
BTW, maybe I posted to the wrong thread last week, so may I draw your attention to this post: http://www.midibox.org/forum/index.php/topic,11258.msg89914.html#msg89914
S
Thanks for the PCB. I haven't mentioned on my site that this schematic is for C64 version. It uses 74HCT138 for address decoding of each AVR from C64 bus. With MB we can remove this chip and connect CS signal directly to the MB core module as with MBSid - master CS goes to MBHP_SID:J2:SO and the second one to MBHP_CORE:J14.
