bugfight Posted August 28, 2007 Posted August 28, 2007 transparent png is a known bug i ie6try ie7...
audiocommander Posted August 28, 2007 Posted August 28, 2007 Hi stryd,well, doesn't look that bad like I expected ;Dto img1:- the "misc" box should be right-aligned; if you decrease your window width it would be rendered normally (then the left floating box becomes larger). a quick workaround for this would be to add a horizontal <hr> right before the "Misc"-Box, but that would add a fixed vertical space (as to be seen in http://www.midibox.org/dokuwiki ... MBHP <-> MIOS ...dunno if this would be better in this case). Maybe this could be also solved by tweaking the CSS properties for the floating boxes; I'll have to check this...to img2 & 3:- as jimp just said nearly simultaneously, the grey images are a result of transparent PNGs, these are not supported by IE < v7. The only "workaround" for this would be transparent GIFs :-X - for the box position in img2 it's the same as described aboveBest,Michaelps: Thanks for the kind feedback to jimp & MTE :)Edit:http://www.midibox.org/dokuwiki/projectsbetter now? ;D
bugfight Posted August 28, 2007 Posted August 28, 2007 there is another workaround for transparency in ie6, but it's too painful to suggest...
audiocommander Posted August 28, 2007 Posted August 28, 2007 clearing the background by painting on the display surface with TippEx? ;D
stryd_one Posted August 28, 2007 Posted August 28, 2007 transparent png is a known bug i ie6try ie7...Bug or unsupported feature? http://support.microsoft.com/kb/294714I need IE6 for work, and this is not a matter of fixing my problem, it's a matter of ensuring that all visitors to the wiki will have the same experience.I think transparent gifs should be fine, no?well, doesn't look that bad like I expected ;DNo, I keep telling you guys over and over it looks great! Please don't hate me and ignore my compliments just because I have found some bugs too :'(to img1:- the "misc" box should be right-aligned; You've fixed that in all three instances for me :)You didn't mention the alignment of the icons with the text though...You mentioned a workaround, and although I am comfortable with that, a lot of newbies say that the wiki is too hard to deal with as it was before, so I don't think that we should introduce any new complexities and push people further away. Anything that requires a workaround should be fixed or removed.to img2 & 3:- as jimp just said nearly simultaneously, the grey images are a result of transparent PNGs, these are not supported by IE < v7.Yep, GIFs... But you made that sound like a bad thing?
bugfight Posted August 28, 2007 Posted August 28, 2007 follow stryd's link and you find the "ugly" workaround: alphaimageloader...(ugly code, not display)
Wilba Posted September 12, 2007 Posted September 12, 2007 I really don't want to be as picky as stryd_one ;D but who turned on the ugly switch on the wiki?
stryd_one Posted September 12, 2007 Posted September 12, 2007 Too bad Wilba, I already pointed that one out so you are as picky as me! bwahahahah
audiocommander Posted September 12, 2007 Posted September 12, 2007 who turned on the ugly switch on the wiki?From what I see in the picture' date=' I guess you mean the fuzzy rendered headlines?I honestly don't know what to do about this, other than [i']<angry redfaced uncontrolled emotional outburst>trashing the f**ing ugly IE</arueo> or <taking a deep breath gaining back self-control />arguing with stryd about the serifs in the capital "I".You see:-> I can't use Verdana or Lucida Grande or any serif-font, because stryd does not like the slab-serifs in the "I"-> I can't take Arial Black, because it obviously renders non-aliased in IE -> so what should I do? I'm running out of options, when I'd like to have a non-serif xtra bold font (a thin one is looking totally shitty!)I know that we're not going to make everybody 100% happy... but it's not really helpful to say "it's ugly" ... so please make your alternative font-suggestion instead;give me a bold sans-serif font (with no serifs on the "i") that is rendered normally in IE.
NorthernLightX Posted September 12, 2007 Posted September 12, 2007 From what I see in the picture' date=' I guess you mean the fuzzy rendered headlines?I honestly don't know what to do about this, other than [i']<angry redfaced uncontrolled emotional outburst>trashing the f**ing ugly IE</arueo> or <taking a deep breath gaining back self-control />arguing with stryd about the serifs in the capital "I".You see:-> I can't use Verdana or Lucida Grande or any serif-font, because stryd does not like the slab-serifs in the "I"-> I can't take Arial Black, because it obviously renders non-aliased in IE -> so what should I do? I'm running out of options, when I'd like to have a non-serif xtra bold font (a thin one is looking totally shitty!)I know that we're not going to make everybody 100% happy... but it's not really helpful to say "it's ugly" ... so please make your alternative font-suggestion instead;give me a bold sans-serif font (with no serifs on the "i") that is rendered normally in IE.How about the Calibri font? It's the new standard MS font in office 2007 afaik, don't know hoe it will render though...
Wilba Posted September 12, 2007 Posted September 12, 2007 I know that we're not going to make everybody 100% happy... but it's not really helpful to say "it's ugly" ... so please make your alternative font-suggestion instead;give me a bold sans-serif font (with no serifs on the "i") that is rendered normally in IE.Sorry... :-[ It was a brief comment on how it wasn't ugly before and now is ;D and did not really want to get into a big argument about which font is best. What was there before was OK as far as I recall.
ilmenator Posted September 13, 2007 Posted September 13, 2007 I can only say that I second that - it was okay before and now it looks... at least not very readable to my eyes. Yes, I think that's it - the letters are not easily identified. :-\I have no idea what font that is now, what it was or what the others mentioned here look like. It was just okay before.Best regards, ilmenator
audiocommander Posted September 13, 2007 Posted September 13, 2007 I attached an update where I set the main font and the headlines to "sans-serif", so it falls back to the font you chose as "sans-serif" in your browser.I also fixed the <li> spacings in the toc.MidiBox DokuWiki Style AC Edit4.zipMidiBox DokuWiki Style AC Edit4.zip
audiocommander Posted September 13, 2007 Posted September 13, 2007 one more thing:I just had a look on NothernLightXes user page and was very happy to see the new features used... :)in contrast, I noticed that Wilba isn't using the headlines as they were supposed to be, I mean starting with h1, then h2, h3 and so on... You started with h1 and then proceed directly to h3 and h4. I think it's quite clear that the fontsize is getting smaller and smaller the lower the heading gets - and moreover the indents are not very continuous.If the TOC is the reason for this, you can disable it completely by typing[tt]~~NOTOC~~[/tt]
stryd_one Posted September 13, 2007 Posted September 13, 2007 I attached an update where I set the main font and the headlines to "sans-serif", so it falls back to the font you chose as "sans-serif" in your browser.I also fixed the <li> spacings in the toc.CHEER!!!! Thanks man It's lookin good. Hangon... the icons in the boxes seem to be misaligned :( I swear they were in line like they should be just a minute ago... Yeh, like that...wait now it's broken again... hahahahah what are you doing :)
audiocommander Posted September 13, 2007 Posted September 13, 2007 I haven't changed anything regarding the image positioning, just the fonts and the toc padding.
stryd_one Posted September 13, 2007 Posted September 13, 2007 Hmm it's still doing it.. sometimes when I refresh the icons are inline (like the IE screenshot I posted before) and sometimes they are not) like the FF shot)It may have always been doing this, I never sat there refreshing the same page over and over before...I just opened it in IE and there are still no transparent gifs...Darn I got excited :(
audiocommander Posted September 13, 2007 Posted September 13, 2007 Not sure what you're doing exactly stryd, but maybe we should wait until the Admin(s) have updated the css.if you're keen on transparant gifs instead of pngs, you can dl and convert them. We have then to update all sources that use them (from *.png to *.gif)Best,Michael
bugfight Posted September 13, 2007 Posted September 13, 2007 i don't know if it's still true, but there used to be some licensing issue with gifs.also the creator doesn't know how to pronounce it correctly...
cimo Posted September 20, 2007 Posted September 20, 2007 S1 i dunno if this can explain anything but i use MAMP (sql virtual server) to create pages offline and when i make a change in the css or swap some images the browser won t update immediately whe i refresh the page but .. sometime.. i didn t find a real logic in it, yet....anyway i think that the browser is caching infos and will reuse them untill it decides to see if anything has changed in the source, as i ve written i use a virtual server in the same machine where i edit the page and it still does it so it s not possibly server dependant..cheerssimone
stryd_one Posted September 22, 2007 Posted September 22, 2007 Thanks Cimo, but that's not it. I tried refreshing and reloading, tried clearing cache, etc etc. Tried it from two browsers on two PC's.Are you still working on this AC? It's gone really quiet, but it's not quite done yet...
audiocommander Posted September 22, 2007 Posted September 22, 2007 Are you still working on this AC? It's gone really quiet, but it's not quite done yet...I'm currently on the road ;)(back next week...)but afaics the latest css update where I changed the headline-fonts has not been updated by an admin (see page before)What problems besides the gifs and "it's-uglier-than-before" do you have?(btw: anyone is free to convert the pngs to gifs)If you mean the box-sizes: => they are related to the size of your browser window...best,Michael
stryd_one Posted September 25, 2007 Posted September 25, 2007 It's just general browser compatibility issues... text and image alignment are the big ones.... We'll talk when you're back into it.
smashtv Posted November 17, 2007 Posted November 17, 2007 Hi guys....I was editing the wiki (moving linked files to local namespaces, moving dictionary entries to their own namespace, etc.) and somehow managed to corrupt the start page css. I did update the "box" plugin, but did not expect it to overwrite changes in such an evil way.Sorry for any extra work this creates, and I will happily put the time in to fix it if anyone has the edited CSS handy.BestSmashTV
