1,285 -
72
Everything posted by Phatline
From the album: TriggerMatrix
handmade -
BLM16x16+xGPIO -
after initialize: void APP_Init(void){ int pin; for(pin=0; pin<16; ++pin){ MIOS32_BOARD_J10_PinInit(pin, MIOS32_BOARD_PIN_MODE_INPUT_PU);} } getting pin 0-7 is workin ok, but 8-15 give me no output: void APP_SRIO_ServicePrepare(void) { // get GPIO-Pins u8 x = 0; for(x=0; x<16; x++) { if(MIOS32_BOARD_J10_PinGet(x) != flag.j10PinState[x]) { MIOS32_MIDI_SendDebugMessage("pin: %d value: %d", x, MIOS32_BOARD_J10_PinGet(x)); flag.j10PinState[x] = MIOS32_BOARD_J10_PinGet(x); } } why?
always in need for core and Midi IO ;) - CORE STM32F4 with STM32F4DISCOVERY - MIDI IO price? where you from?... mike (austria)
Hi, i want to modify the blm_scalar app a bit http://svnmios.midiboxorg/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fblm_scalar%2FREADME.txt i want to use it in standalone and via midi/sysex... so my question: how to call the BLM internally? when i want to display a "array[16][16]=0 or 1 or 2;" i know i can call it like below but is there a more direct way to use it? thx. mike void APP_Background(void){ u8 chn = 0; u8 note = 0; u8 velocity = 0; for(chn=0; chn<16; chn++){ for(note=0; note<16; note++){ velocity = Seq[chn][note]; if( note <= 0x0f ) { //note<=15? // BLM16x16 LEDs led_mod_ix = chn >> 2; led_row_ix = ((chn&3) << 1) + ((note >> 3) & 1); led_column_ix = note & 0x7; //7 modify_led = 1; } else if( note == 0x40 ) { //note==64 // extra column LEDs led_mod_ix = 4; led_row_ix = (chn&3) << 1; led_column_ix = chn >> 2; modify_led = 1; } else if( chn == 0 && note >= 0x60 && note <= 0x6f ) { //Chn0, note>=96, note>0111 // extra row LEDs led_mod_ix = 4; led_row_ix = 1 + ((note >> 1) & 6); led_column_ix = note & 3; modify_led = 1; } else if( chn == 0xf && note >= 0x60 && note <= 0x6f ) { //Chn15, note>=96, note>0111 // additional extra LEDs led_mod_ix = 4; led_row_ix = 1 + ((note >> 1) & 6); led_column_ix = 4 + (note & 3); modify_led = 1; } if( modify_led ) { u8 led_mask = 1 << led_column_ix; // 90 xx 00 is the same like a note off event! // (-> http://www.borg.com/~jglatt/tech/midispec.htm) if( velocity == 0x00 ) { // Note Off or velocity == 0x00: clear both LEDs blm_scalar_led[led_mod_ix][led_row_ix][0] &= ~led_mask; #if BLM_SCALAR_NUM_COLOURS >= 2 blm_scalar_led[led_mod_ix][led_row_ix][1] &= ~led_mask; #endif } else if( velocity < 0x40 ) { // Velocity < 0x40: set green LED, clear red LED blm_scalar_led[led_mod_ix][led_row_ix][0] |= led_mask; #if BLM_SCALAR_NUM_COLOURS >= 2 blm_scalar_led[led_mod_ix][led_row_ix][1] &= ~led_mask; #endif } else if( velocity < 0x60 ) { // Velocity < 0x60: clear green LED, set red LED blm_scalar_led[led_mod_ix][led_row_ix][0] &= ~led_mask; #if BLM_SCALAR_NUM_COLOURS >= 2 blm_scalar_led[led_mod_ix][led_row_ix][1] |= led_mask; #endif } else { // Velocity >= 0x60: set both LEDs blm_scalar_led[led_mod_ix][led_row_ix][0] |= led_mask; #if BLM_SCALAR_NUM_COLOURS >= 2 blm_scalar_led[led_mod_ix][led_row_ix][1] |= led_mask; #endif } } } }} // END - FOR - LOOPS
store 16bit variable to 8bit FILE_Writebuffer
Phatline replied to Phatline's topic in MIOS programming (C)
hm i get a error: app.c:1094:13: warning: implicit declaration of function 'wmemset' [-Wimplicit-function-declaration] if(edit & (1<<0))wmemset(loop[track].PB, (u32)((8192<<16) + 8192), (sizeof (loop[track].PB))/4); // reset Pitch Bend when i then add: #include <wchar.h> to app.c then error: should i change this: typedef struct storage { u16 PB [512]; u8 SEQ[512] [8]; u8 MSQ[512]; char leader:1; char virgin:1; u8 length; u8 decay; u8 rythm; u16 bpm; } store_t; to this: typedef struct storage { wchar_t PB PB [512]; u8 SEQ[512] [8]; u8 MSQ[512]; char leader:1; char virgin:1; u8 length; u8 decay; u8 rythm; u16 bpm; } store_t; hm what size has this wchar_t? -
if(edit & 0x0f)memcpy(&loop_copy, &loop[track], sizeof loop_copy); clever i like that but i planned it more like: check which things have to copyied, so i can copy PB+NOTES, but not CC+Loop-Information, (for default) if i get it right: in your thought i can always copy only one thing: PB, All, Notes or Loop-Info but i can still use memcpy with for example: if( (edit[0]==1) && (edit[1]==1) && (edit[1]==1) && (edit[1]==1) ) memcpy(&loop_copy, &loop[track], sizeof loop_copy); THX for your help guys! for the rest i will take me time on 23.12... today we make fire in the snow, and celebrate the 21.12 to restart the sun-circle happy new sun year, skol! -
aja a < 8 of course, thx! Edit: read/write on SD-Card is working fine! MUTEX_SDCARD_TAKE; //Write to File sprintf(file_path, "msp/%d-%d.msp", track, clip); FILE_WriteOpen ( file_path, 16 ); FILE_WriteBuffer( (u8 *)&file_type, 4 ); FILE_WriteBuffer( (u8 *)&loop[track], sizeof(store_t) ); FILE_WriteClose (); MUTEX_SDCARD_GIVE; @ Background-tasks function example which make a hardfault when using 1024, when calling it... i call it once a time with a button press on the UI (DIN) > see code below but also will need such things for mooving sequencer data forward in loop, or backwards, or copy step 0-15 to all other 512 steps in a musically way > means could be a wild button orgie... in App.h: typedef struct storage { // to optimize SD-Load-Time, each clips data is stored in this struct u16 PB [512]; // Pitchband inital = 8192 = No Pitchbend! u8 SEQ[512] [8]; // 512Steps, 8NotePolyphony u8 MSQ[512]; // Motion-SEQ of one CC ...eg.:Control-Wheel of Keyboard char leader; // Programchange able? - only 1 of 4 Song-Clips can send Programchanges via BLMatrix char virgin; // is there any data in the clip? need to display on a ButtonLed Matrix-Launcher u8 length; // 1x16, 2x16... u8 decay; // 60ms... could be set with Encoder, but I dont need a variable, since the melody out will be used by the Triggermatrix... u8 rythm; // 4x4=16, 5x3=15 usw... to calculate maximal duration per UI-matrix page u16 bpm; } store_t; extern store_t loop[8]; in app.c: u16 SEQ_copy[512][8] = {{}}; //Copy actual Track into ClipboardBuffer u16 MSQ_copy[512] = {}; //Copy actual Track into ClipboardBuffer u16 PB_copy [512] = {}; //Copy actual Track into ClipboardBuffer u16 tact_info_copy[32] = {}; //Copy bpm, loop length, tact and so on // E D I T C L I P D A T A static void Edit_Clip(u8 track, u16 clip, u16 job){ u16 c = 0; u16 x = 0; switch(job) { // Clear case 0: for( c=0; c<512; c++ ) { if(edit[0] == 1) { loop[track].PB[c] = 8192; } // = no Pitch Bend if(edit[1] == 1) {for( x=0; x<8; x++ ) { loop[track].SEQ[c][x] = 0; } } // = no Note if(edit[2] == 1) {loop[track].MSQ[c] = 0; } // = no Control Change } break; // Copy case 1: for( c=0; c<512; c++ ) { if(edit[0] == 1) { PB_copy[c] = loop[track].PB[c];} // PB if(edit[1] == 1) { for( x=0; x<8; x++ ) { SEQ_copy[c][x] = loop[track].SEQ[c][x]; } } // NOTE if(edit[2] == 1) { MSQ_copy[c] = loop[track].MSQ[c];} // MSQ } if(edit[3] == 1) { tact_info_copy[0] = loop[track].leader; tact_info_copy[1] = loop[track].virgin; tact_info_copy[2] = loop[track].length; tact_info_copy[3] = loop[track].decay; tact_info_copy[4] = loop[track].rythm; tact_info_copy[5] = loop[track].bpm; } break; // Paste case 2: for( c=0; c<512; c++ ) { if(edit[0] == 1) { loop[track].PB[c] = PB_copy[c];} // PB if(edit[1] == 1) { for( x=0; x<8; x++ ) { loop[track].SEQ[c][x] = SEQ_copy[c][x]; } } // NOTE if(edit[2] == 1) { loop[track].MSQ[c] = MSQ_copy[c]; } // MSQ } if(edit[3] == 1) { loop[track].leader = tact_info_copy[0]; loop[track].virgin = tact_info_copy[1]; loop[track].length = tact_info_copy[2]; loop[track].decay = tact_info_copy[3]; loop[track].rythm = tact_info_copy[4]; loop[track].bpm = tact_info_copy[5]; } break; } } also the code above is working ifne ;) -
ok understand, i let the the file describtion in.... oje... there is something wrong with the code, http://wiki.midibox.org/lib/exe/fetch.php?media=phatline:seq-melody-footboard-beta.zip when i make arrays with 8x512, or arrays with 8x1024, the Files on SD-Card is always 5,6kb size, also on 1024 i got hardfaults when copy those structs into arrays (copy paste clear clips), by 512 no hardfault typedef struct storage { u16 PB [512]; u8 SEQ[512] [8]; u8 MSQ[512]; char leader; char virgin; u8 length; u8 decay; u8 rythm; u16 bpm; } store_t; no difference in SD-File-Size! typedef struct storage { u16 PB [1024]; u8 SEQ[1024] [8]; u8 MSQ[1024]; char leader; char virgin; u8 length; u8 decay; u8 rythm; u16 bpm; } store_t; also i initialize all Arrays, but actual most of them (all except the first member loop[0] in the program are 0-out void APP_Init(void){ //initalize 8 Clips with standart values u8 a = 0; for ( a=0; a>8; a++ ) { loop[a].leader = 0; loop[a].virgin = 1; loop[a].length = 1; loop[a].decay = 60; loop[a].rythm = 4; loop[a].bpm = 120; //initiate Pitchbend u16 b; for(b=0; b<512; b++) { loop[a].PB[b] = 8192; } }; //Initiate Pitchbend - copy paste buffer u16 b; for(b=0; b<512; b++) { PB_copy[b] = 8192; } } the 1024 thing i think is clear, it takes to long to calculate all the data, i would need something like a xtask... but i dont figured out how to make out of a i know: i use such things for counters in ms tact (decay-counters, blink blink...), but not for a function that gets called, work something out, and done... for example: static void Decay(void *pvParameters){ //Send Note OFFs after a while portTickType xLastExecutionTime; xLastExecutionTime = xTaskGetTickCount(); // Initialise the xLastExecutionTime variable on task entry while( 1 ) { vTaskDelayUntil(&xLastExecutionTime, 1 / portTICK_RATE_MS); for(DcyNteCount = 1; DcyNteCount < 128; DcyNteCount++) { for(DcyTrkCount = 0; DcyTrkCount < 8; DcyTrkCount++) { if (MeloDecayTIMER[DcyTrkCount][DcyNteCount] != 0) { MeloDecayTIMER[DcyTrkCount][DcyNteCount] --; if (MeloDecayTIMER[DcyTrkCount][DcyNteCount] == 0) { MIOS32_MIDI_SendNoteOff(MelPortOut, MeloOutCh[DcyTrkCount], DcyNteCount, 0); MIOS32_MIDI_SendNoteOn (MelPortOut, MeloOutCh[DcyTrkCount], DcyNteCount, 0);}} }} }//End While }//End TICK 0 >>> 1ms Task... -
would assume that all my tracks saved in a single file, and thats not the case, since i need to load the clips independendly for launching via BLM, but also need to load the clips via Program-change also so it ends up with: case 2: //LOAD all Clips - FOR P R O G R A M C H A N G E for( t=0; t<8; t++) { MUTEX_SDCARD_TAKE; sprintf ( filepathL, "sq/%d-%d.sq", t, clip ); FILE_ReadOpen ( &midifile_fi, filepathL ); FILE_ReadBuffer ( (u8 *)file_type, 4 ); FILE_ReadBuffer ( (u8 *)loop[t], sizeof(store_t) ); FILE_ReadClose ( &midifile_fi ); MUTEX_SDCARD_GIVE; //Calculate new Loop Lengths Loop[t] = loop[t].length * MainLoop; } by the way, do i need that FILE_WriteBuffer( (u8 *)file_type, 4 ); //"SQ01" = 4 Positons for what platforms do i need a filetype? compiler says for the line: FILE_WriteBuffer((u8 *)loop[track], sizeof(store_t)); : -
i am stucking @ the moment, while i know how to use it instead of my normal arrays, i dont know how to write the whole struct into file... ok here my struct: store_t loop[8] , how can i read/write them now into my FILE? a struct is not named in MIOS32 functions doku app.h (so all functions have access on it typedef struct storage { // to optimize SD-Load-Time, each clips data is stored in this struct u16 PB [512]; // Pitchband inital = 8192 = No Pitchbend! u8 SEQ[512] [8]; // 512Steps, 8NotePolyphony //loop[c].SEQ bevore u8 MSQ[512]; // Motion-loop[c].SEQ of one CC (Control-Wheel of Keyboard //loop[c].MSQ bevore u8 CC [32]; // Save all other Variables into this Array - for SD-Card... //loop[c].CC bevore char leader; // Programchange able? - only 1 of 4 Song-Clips can send Programchanges via BLMatrix char virgin; // is there any data in the clip? need to display on a ButtonLed Matrix-Launcher //loop[c].virgin bevore u8 length; // 1x16, 2x16... //loop[c].length bevore u8 decay; // 60ms... could be set with Encoder, but I dont need a variable, since the melody out will be used by the Triggermatrix... //loop[c].decay bevore u8 rythm; // 4x4=16, 5x3=15 usw... to calculate maximal duration per UI-matrix page //loop[c].rythm bevore u16 bpm; } store_t; app.c , initalize data //Card-Clip-Container store_t loop[8]; void APP_Init(void){ //initalize 8 Clips with standart values u8 a = 0; for ( a=0; a>8; a++ ) { sprintf( loop[a].file_type, "SIGL" ); loop[a].leader = 0; loop[a].virgin = 1; loop[a].length = 1; loop[a].decay = 60; loop[a].rythm = 4; loop[a].bpm = 120; //initiate Pitchbend u16 b; for(b=0; b<512; b++) { loop[a].PB[b] = 8192; } // 8192: inital No Pitchbend! }; app.c , store data //S T O R E Single Clip MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); //write struct FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free 4 access break; //L O A D single Clip MUTEX_SDCARD_TAKE; sprintf(filepathL, "sq/%d-%d.sq", track, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_type, 4); //write struct FILE_ReadClose (&midifile_fi); MUTEX_SDCARD_GIVE; //Calculate new Loop Lengths Loop[track] = loop[track].length * MainLoop; break; -
thx good to know! i will try them structs code is for MelodienSpeicher, where arrays[8][512] polophonic played in 16th (Pitchbend, NoteOn/Off), and also hope that dont hurts when using structs u16 PB[8][512] = {{}}; // 8192: inital No Pitchbend! u8 Sequence[8][512][8]={{{}}}; //8Tracks, 512Steps, 8NotePolyphony u8 CC_MSQ[8][512] = {};//Motion-Sequence of one CC (Control-Wheel of Keyboard s16 TrackClipboard[512][8] = {{}}; //Copy actual Track into ClipboardBuffer u8 StepClipBoard[8][8] = {}; //Just a memory container to copy paste Sequencer Steps -
to be prepared, today read a lot about structs, and memory-save/performance/code-readable much to optimize .... it seems that there are things to keep on eye, to avoid heavy bus-load ...like order variable by byte size, and others which i cant summize a "i understand"... importend for me is that the the program goes fast thru, i dont have memory problems, i think, since it is a sequencer timing is No1 by using struct it will slow down program-process? a normal variable-array is slower? > time not so importend - in case of loading from SD-Card to RAM, but for RAM-Access-time in the Program, hope that question make sense? then there where people who said, that when i dont use 32bit types, the program have to calc my 1bit 8bit or 16bit into 32bit -memory-slots- and access time will go not so good, other saying that this is only for x86, arm a nother story... dont know: should i use "int" as standard (except for the big sequencer Arrys > memory to low i expirienced today more a 8 or 16bit...) or should i use u8 or u16 instead? i mean when i dont use structs for all those "not clip related"-variables, just single u8 variables make it any differnce at all? -mike -
thx has worked: FILE_ReadBuffer((u8 *)Sequence[track], sizeof(Sequence[track])); //u8 Sequence[8][512][8] FILE_WriteBuffer((u8 *)Sequence[track], sizeof(Sequence[track])); //u8 Sequence[8][512][8] call: SD(track, clip, job); for example: SD(6,1,2); //track 6 dont matter, ProgramChange 1, Load all Clips SD(0,7,1);//track 0, ProgramChange 7, Load single Clip (clip 7-0.sq) SD(0,1,3);//track 0 , ProgramChange 1, Store single Clip (clip 1-0.sq) SD(2,1,4);//track 2 dont matter, ProgramChange 1, Store all Clips SD(2,1,5);//track 2 dont matter, ProgramChange 1 dont matter, Copy track 0-0.sq 512x8 times on SD-Card = Make filestructure = initalize SD-Card > take 20 Minutes full code: http://wiki.midibox.org/lib/exe/fetch.php?media=phatline:seq-melody-footboard.zip relativly stripped down the SD-Management is done by: u8 clip_is_virgin = 1; u16 BPM = 120; u8 Rythm = 4; u8 SetDecayTime[8] = {60,60,60,60, 60,60,60,60}; us u8 Loop_Length[8] = {1,4,1,4, 1,4,1,4}; u8 CC_SD[8][32] = {}; //Save all other Variables into this Array - for SD-Card... u8 CC_MSQ[8][512] = {}; u8 Sequence[8][512][8]={{{}}}; xSemaphoreHandle xSDCardSemaphore; // take and give access to SD-Card xSemaphoreHandle xLCDSemaphore; // take and give access to LCD static file_t midifile_fi; //used to read files from SD-Card #define MUTEX_LCD_TAKE { while( xSemaphoreTakeRecursive(xLCDSemaphore, (portTickType)0) != pdTRUE ); } //a Mutex reserve LCD/SD for a task, until it is given away... #define MUTEX_LCD_GIVE { xSemaphoreGiveRecursive(xLCDSemaphore); } #define PRIORITY_SD ( tskIDLE_PRIORITY + 3 ) //3:Mios standart static void SD(u8 track, u16 clip, u16 job); void APP_Init(void){ xLCDSemaphore = xSemaphoreCreateRecursiveMutex(); // create Mutex for LCD access xSDCardSemaphore = xSemaphoreCreateRecursiveMutex(); //create Mutex for SD-Card access FILE_Init(0);// initialize file functions } void APP_Tick(void){ //@1mS rate SDCardCount++; //CHECK SD-Car every 2sec. if(SDCardCount > 2000) { SDCardCount = 0; SD(0, 0, 5); } //2s Counter > send Check-SDCard-Commant to StoreLoad-Function (u8 track, u16 clip, u16 job) } // S T O R A G E - SD - C A R D /// read write clips/programchanges static void SD(u8 track, u16 clip, u16 job){ //Job1=load all, Job2=store all, Job3=initalize card u8 t = 0; //track counter initation switch(job) { // R E A D /////////////////////////////////////////////////////////////////////////////////////////////////////// case 1: //LOAD single Clip MUTEX_SDCARD_TAKE; sprintf(filepathL, "sq/%d-%d.sq", track, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_typeBank, 4); FILE_ReadBuffer((u8 *)CC_SD [track], sizeof(CC_SD [track])); FILE_ReadBuffer((u8 *)CC_MSQ [track], sizeof(CC_MSQ [track])); //Control-Change-Motion-Sequence FILE_ReadBuffer((u8 *)Sequence[track], sizeof(Sequence [track])); //u8 Sequence[8][512][8] FILE_ReadBuffer((u8 *)PB [track], sizeof(PB [track])); FILE_ReadClose (&midifile_fi); MUTEX_SDCARD_GIVE; //Paste Variables from Array Rythm = CC_SD[track][1]; Loop_Length[track] = CC_SD[track][2]; BPM = CC_SD[track][4]; SetDecayTime[track] = CC_SD[track][5]; //Calculate new Loop Lengths Loop[track] = Loop_Length[track] * MainLoop; //SEQ_BPM_Set(BPM); NeedSync = 1; //update ClockCounter when ready... SongNrStor = SongNrLoad; //transfair load nr 2 store nr. break; case 2: //LOAD all Clips - FOR P R O G R A M C H A N G E for( t=0; t<8; t++) { MUTEX_SDCARD_TAKE; sprintf(filepathL, "sq/%d-%d.sq", t, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_typeBank, 4); FILE_ReadBuffer((u8 *)CC_SD [t], sizeof( CC_SD [t])); FILE_ReadBuffer((u8 *)CC_MSQ [t], sizeof( CC_MSQ[t])); //Control-Change-Motion-Sequence FILE_ReadBuffer((u8 *)Sequence[t], sizeof(Sequence[t])); //u8 Sequence[8][512][8] FILE_ReadBuffer((u8 *)PB [t], sizeof( PB[t])); FILE_ReadClose (&midifile_fi); MUTEX_SDCARD_GIVE; //Paste Variables from Array Rythm = CC_SD[t][1]; Loop_Length[t] = CC_SD[t][2]; BPM = CC_SD[t][4]; SetDecayTime[t] = CC_SD[t][5]; //Calculate new Loop Lengths Loop[t] = Loop_Length[t] * MainLoop; } //SEQ_BPM_Set(BPM); NeedSync = 1; //update ClockCounter when ready... SongNrStor = SongNrLoad; //transfair load nr 2 store nr. MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "PROGRAM LOAD - Finished"); MUTEX_LCD_GIVE; Update_LCD_s = 1; //normal LCD-Labeling in back again in a second break; // S T O R E ///////////////////////////////////////////////////////////////////////////////////////////////////// case 3: //S T O R E Single Clip //Fill CC-Array of Clip CC_SD[track][0] = clip_is_virgin; CC_SD[track][1] = Rythm; CC_SD[track][2] = Loop_Length[track]; CC_SD[track][4] = BPM; CC_SD[track][5] = SetDecayTime[track]; MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD [track], sizeof(CC_SD [track])); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)CC_MSQ [track], sizeof(CC_MSQ [track])); //Control-Change-Motion-Sequence FILE_WriteBuffer((u8 *)Sequence[track], sizeof(Sequence[track])); //u8 Sequence[8][512][8] FILE_WriteBuffer((u8 *)PB [track], sizeof(PB [track])); FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free 4 access Update_LCD_s = 1; //normal LCD-Labeling in back again in secunds SongNrLoad = SongNrStor; //transfair load nr 2 store nr. break; case 4: //S T O R E all Clips - FOR P R O G R A M C H A N G E for( t=0; t<8; t++) { // store file once by once //Fill CC-Array of Clip CC_SD[t][0] = clip_is_virgin; CC_SD[t][1] = Rythm; CC_SD[t][2] = Loop_Length[t]; CC_SD[t][4] = BPM; CC_SD[t][5] = SetDecayTime[t]; MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", t, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD [t], sizeof(CC_SD [t])); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)CC_MSQ [t], sizeof(CC_MSQ [t])); //Control-Change-Motion-Sequence FILE_WriteBuffer((u8 *)Sequence[t], sizeof(Sequence[t])); //u8 Sequence[8][512][8] FILE_WriteBuffer((u8 *)PB [t], sizeof(PB [t])); FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free 4 access } SongNrLoad = SongNrStor; //transfair load nr 2 store nr. MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "PROGRAM STORE - Finished"); MUTEX_LCD_GIVE; Update_LCD_s = 1; //normal LCD-Labeling in back again in secunds break; // I N I T - S D - CARD //////////////////////////////////////////////////////////////////////////////////7////// case 5: //SD-Card Initalize MUTEX_SDCARD_TAKE; //SD-Card is now only for the following LINES reserved: statusSD = FILE_CheckSDCard(); switch(statusSD) { case 2: MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "NO SD-Card"); MUTEX_LCD_GIVE; break; case 3: if (!FILE_SDCardAvailable() ) {MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "Insert-FAT-Formated-SD-Card"); MUTEX_LCD_GIVE; break;} if (!FILE_VolumeAvailable() ) {MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "Format SD-Format to FAT first!"); MUTEX_LCD_GIVE; break;} break; case 1: // YES CARD! >>> next: check Card-content statusDir = FILE_DirExists("sq"); //ask file.c: exist a folder "t/" on the CARD? if(statusDir == 1){MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "good SD-file structure");MenueUpdateFlag = 0;MUTEX_LCD_GIVE; break;} if(statusDir == 0){MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "create 4096 Files on SDC it takes 20min - really!-wait!!! ");MUTEX_LCD_GIVE; //Fill CC-Array of Clip CC_SD[track][0] = clip_is_virgin; CC_SD[track][1] = Rythm; CC_SD[track][2] = Loop_Length[track]; CC_SD[track][4] = BPM; CC_SD[track][5] = SetDecayTime[track]; FILE_MakeDir("sq"); //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD[track], 32); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)CC_MSQ[track], sizeof(CC_MSQ[track])); //Control-Change-Motion-Sequence FILE_WriteBuffer((u8 *)Sequence[track], sizeof(Sequence[track])); //u8 Sequence[8][512][8] FILE_WriteBuffer((u8 *)PB[track], sizeof(PB[track])); FILE_WriteClose (); //copy-prototype file to 512x8 clip files on SD-Card for(t=0; t<8; t++){ s16 clipcount = 0; //declare and set the Bank Counter inital value to 0 for(clipcount=0; clipcount<512; clipcount++){ //countes 2 511 and do following commandos 511 times in a loop: char copyfilepath[16]; sprintf(copyfilepath, "sq/%d-%d.sq", t, clipcount); //make a new filename depending on the counter value 1.sq, 2.sq, 3.sq...511.sq FILE_Copy ((char *)"sq/0-0.sq", (char *)copyfilepath);} //copy the File 0.tm to all other 511 files... } //SD-Card is now free 4 apbess MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(0); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "SD-CARD - INIT - FINISHED"); MUTEX_LCD_GIVE;MenueUpdateFlag = 0;} break; } MUTEX_SDCARD_GIVE; } } maybe that helps anyone, or me in the future... -
should it does it the same? incl(track) (step) cant wait to try it at home.many thx.4that. mike. -
how ever the endgoal is: 128 Program-Change/Songs a 4clips = 512clips 8tracks a 512 clips fileformat: [track]-[clip].sq >>> each clip is a single file which can be called when i Programchange, it loads the first row of clips >>> clip = PC*4 >>> to load a other clip i need to built a 8x8 blm first: the plan is: ----------------tr0 tr1 tr2 tr3 tr4 tr5 tr6 tr7 last PC x - Play-Clip from last Song empty grid x x x x x x x x - Indicate that there is no Song to choose clip.row0 x x x - Play Clips[tr0][cliprow0] of actual song.... clip.row1 x - clip.row2 x clip.row3 empty grid x x x x x x x x next PC x - Play Clips from next song.... so its a bit of ableton like... but more song structured. -
file is up to date in wiki: http://www.midibox.org/dokuwiki/lib/exe/fetch.php?media=phatline:seq-melody-footboard.zip when cleaned up this are the Functions involved > 1.APP_DIN_NotifyToggle >>> set a Flag to 1 (Hi) 2.TASK_Blink_Decay >>> wait 250ms, then send a Call to: SD(SaveNextFlag, SongNrStor, 2) = TRACK0, Song-PC0, store command 3.SD(u8 track, u16 clip, u16 job) >>> writing, reading, or initalizing files... // local prototype of the task function static void TASK_Blink_Decay(void *pvParameters); static void SD(u8 track, u16 clip, u16 job); void APP_DIN_NotifyToggle(u32 pin, u32 pin_value){ //1.STORE-LOAD-BUTTON-ACTION if(pin_value == 0) { switch(pin) { case 6: StoreFlag = 1; break; case 14: LoadFlag = 1; break; }}} static void SD(u8 track, u16 clip, u16 job){ //3.Job1=load all, Job2=store all, Job3=initalize card //STORE if(job == 2) { //Fill CC-Array of Clip CC_SD[0] = clip_is_virgin; CC_SD[1] = Rythm; CC_SD[2] = Loop_Length[track]; CC_SD[3] = BPM; CC_SD[4] = SetDecayTime[track]; MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD, 32); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)Sequence[track], 2048); //u8 Sequence[8][256][8]={{{}}}; //8Tracks, 256Steps, 8NotePolyphony for(i=0; i<256; i++)FILE_WriteHWord (PB[track][i]); //write Pitchbend u16 values directly FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free 4 apbess SongNrLoad = SongNrStor; //transfair load nr 2 store nr. SD_Done_StoreFlag = 1;} //LOAD if(job == 1) {//Load all Data- whole Program-Change-Patterns MUTEX_SDCARD_TAKE; //NOTE-Data of Clip sprintf(filepathL, "sq/%d-%d.sq", track, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_typeBank, 4); FILE_ReadBuffer((u8 *)CC_SD, 32); FILE_ReadBuffer((u8 *)Sequence[track], 2048); //u8 Sequence[8][256][8] for(i=0; i<256; i++)FILE_ReadHWord (&PB[track][i]); //read Pitchbend u16 values directly FILE_ReadClose (&midifile_fi); MUTEX_SDCARD_GIVE; //Paste Variables from Array clip_is_virgin = CC_SD[0]; Rythm = CC_SD[1]; Loop_Length[track] = CC_SD[2]; BPM = CC_SD[3]; SetDecayTime[track] = CC_SD[4]; //SEQ_BPM_Set(BPM); NeedSync = 1; //update ClockCounter when ready... SongNrStor = SongNrLoad; //transfair load nr 2 store nr. SD_Done_Load_Flag = 1;} //SD-Card Initalize - Files if((job == 3) && (clip < 8)){//CHECK SD-Card/Initalize Card .... .... }//End While }//End TICK 0 >>> 1ms Task... -
u16 PB[8][256] = {{}}; dont working, LCD hangs.... by just sending a ... SD(0,0,2 or 1) .... i decoppelt already the Load/Store button to directly act on the SD-Function (with counters in milliseconds) which solved issues but not the pitchbend thing... static void SD(u8 track, u16 clip, u16 job){ //STORE if(job == 2) { MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD, 32); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)Sequence[track], 2048); //u8 Sequence[8][256][8]={{{}}}; / for(i=0; i<256; i++)FILE_WriteHWord (PB[track][i]); //write Pitchbend u16 values directly FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free SD_Done_StoreFlag = 1;} //LOAD if(job == 1) { MUTEX_SDCARD_TAKE; //READ FILE sprintf(filepathL, "sq/%d-%d.sq", track, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_typeBank, 4); FILE_ReadBuffer((u8 *)CC_SD, 32); FILE_ReadBuffer((u8 *)Sequence[track], 2048); //u8 Sequence[8][256][8] for(i=0; i<256; i++)FILE_ReadHWord (&PB[track][i]); //read Pitchbend u16 values directly FILE_ReadClose (&midifile_fi); MUTEX_SDCARD_GIVE; SD_Done_Load_Flag = 1;}
